Forum Index : Microcontroller and PC projects : CMM not holding time
Herry![]() Senior Member Joined: 31/05/2014 Location: AustraliaPosts: 261 |
I wonder why? Using syntax TIME$ = "HH:MM". It holds but after power off it is lost. Yes battery is in. Senior?! Whatever it says, I'm a complete and utter beginner... |
Did you remove the jumpers on the Waveshare module? What do you get with > print pin("BAT") It should be close to " 3.02" Jim VK7JH MMedit |
Yes I did. the answer is 2.96... Senior?! Whatever it says, I'm a complete and utter beginner... |
Have you set the date as well? What do you get on the status line (lower right of screen)? Jim VK7JH MMedit |
haven't set date yet. Senior?! Whatever it says, I'm a complete and utter beginner... |
That was a hint to set the date if you haven't done so. Part of the startup checks the year and if it is before 2018, the system assumes that the RTC is not set. Jim VK7JH MMedit |
And that was it! All OK now. Incidentally, I couldn't find any reference to that in the manual. Maybe I did not look (or Ctrl-F) hard enough! Senior?! Whatever it says, I'm a complete and utter beginner... |
| ZXKIM81 Newbie Joined: 17/08/2020 Location: United KingdomPosts: 2 |
been playing on max-e-man and i love it |
