Local Time 18:17 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Adding firmware version checks to programs
realmnm
Posted: 11:06am 19 Aug 2020
I tried to add a minimum firmware version check to my software and found that it doesn't work as well as I would have liked.  This may just be floating point issue or ?I don't know what.
Here is what I tried.
dim MINFWVERSION as float
dim CMM2VERSION as float
MINFWVERSION=5.0505
CMM2VERSION=MM.INFO(VERSION)
if CMM2VERSION < MINFWVERSION then
 print:print "Sorry, appear to be running firmware version "+str$(CMM2VERSION)
 print "You need to be running firmware version "+str$(MINFWVERSION)+" or higher.":print
 end
endif
Let me know your thoughts.
Martin
This signature intentionally left blank.
yock1960
Posted: 11:24am 19 Aug 2020
Have you tried subtracting one from the other to see if you get the expected result?
Steve
CaptainBoing
Posted: 11:27am 19 Aug 2020
looks OK, fairly straightforward test
what don't you like? what was the result of you running this?
Need a bit more wood on the fire to help, print out the two variables so we can see what the If is working with.
I do a similar thing on the Micromite/ArmiteF4/H7 paltform but I use the string form MM.DEVICE$. I am not familiar with the idiosyncrasies of the CMM2.
Edited 2020-08-19 21:28 by CaptainBoing
Posted: 11:30am 19 Aug 2020
  realmnm said  I tried to add a minimum firmware version check to my software and found that it doesn't work as well as I would have liked.
What is the problem?  What is it that you "would have liked".
Posted: 11:31am 19 Aug 2020
Just a standard floating point rounding issue
Use MINFWVERSION=5.0504999999999
realmnm
Posted: 11:39am 19 Aug 2020
That’s what I thought it might be. Thanks.
realmnm
Posted: 11:42am 19 Aug 2020
Fireworks,  Coins pouring out like I had won a Jackpot.
mkopack73
Posted: 03:40pm 19 Aug 2020
Yeah this, and a number of other “best practices” really should be used when writing programs for this computer.
I’m starting to write these best practices up (literally started this morning) as a little book to help people write good, clean, portable and reusable code for the CMM2.
mkopack73
Posted: 03:41pm 19 Aug 2020
To deal with the FP precision issue you could try to round it up to the nearest .000x before doing the comparison.
Posted: 07:34am 20 Aug 2020
if MM.INFO(VERSION) < (5.0505-0.0001) then print "too old" else print "All good"
