Forum Index : Microcontroller and PC projects : Possible Bug in FIELD$ function in MMBasic 5.05.03
William Leue
Posted: 04:31pm 19 Aug 2020
The manual says that the string2 argument to FIELD$ can hold more than one delimiter. I interpret this to mean 'you can use any character in this string as a delimiter." (This is the usual way such a parser works in other language runtime libraries.)
However, this does not work as I expect:
rstr$ = "100, 100, 100"
dstr$ = " ,"
c1$ = FIELD$(rstr$, 1, dstr$)
c2$ = FIELD$(rstr$, 2, dstr$)
c3$ = FIELD$(rstr$, 3, dstr$)
If the delimiters in rstr$ are just spaces, then FIELD$ returns the correct fields for all 3 items. But if rstr$ has commas or any combination of spaces and commas, then only the first item is correct and the other two are null strings.
Does anyone see the same thing? Is my interpretation of the desired behavior wrong?
Thanks!
darthvader
Posted: 04:54pm 19 Aug 2020
Hi ,
i just tested with v5.05.05b11 and it seem to work :)
Posted: 10:04pm 19 Aug 2020
Works OK for me in V5.05.x but there is a mistake in the manual, not relevant to you problem.
I tried all combinations of space and comma and it works as per the manual.
The mistake is in the example:
  Quote  s$ = "foo, 'boo, zoo', doo"
r$ = FIELD$(s$, 3, ",", "'")
will result in r$ = "boo, zoo".
should be
r$ = FIELD$(s$, 2, ",", "'")
