Forum Index : Microcontroller and PC projects : MMBasic - When Does INKEY$ get reset to ""?
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 883 |
Hi, Firstly I can work around this "feature" with KEYDOWN but I'm trying to understand when INKEY$ is reset. If I have: . . . Do: Loop While INKEY$ = "" '1st Do Loop 'Print INKEY$; Do '2nd Do Loop something Loop While INKEY$ = "" something else ... MMBasic (at least on my CMM2) skips through the second Do Loop as though it has remembered the first INKEY$. Shouldnt it be reset at the begining of the second Do loop? BUT if I insert something that requires an evaluation of INKEY$, like a Print statement, it works fine. Cheers, Andrew (Im using CMM2 5.05.05b19) |
INKEY$ removes the next character from the console input queue and returns it. If there is nothing there it returns an empty string. Whenever you use INKEY$ (even in a conditional test) you will remove the next character from the queue. Normally you would use it like this: DO s$ = INKEY$ WHILE s$ = "" PRINT s$ Geoff Geoff Graham - http://geoffg.net |
Thanks Geoff. I DO normally use a variable (eg S$) but for some reason I didn't this time. Your explanation helps tremendously. Cheers, Andrew |
Hi again Geoff, If I use the following and if I hit ENTER for each anykey this fails too (ie it just Texts the first "1" in the second loop and then ends - any other key works. Is that what you would expect? Andrew {Just thinking after I posted this, is ENTER treated as CR & LF ie as two characters? Then the second character makes T$ not "" so it passes through??} 'INKEY$-Play.BAS ' Seeks to resolve odd Inkey$ behaviour dim integer I = 0 cls do '1st Do loop S$ = Inkey$ I = I + 1 Text 0, 100, "Press a key to move on " + Str$(I), "LB",2,1 ,RGB(green) Pause 500 'Just to slow it down loop while S$ = "" 'S$ = "" I = 0 do '2nd Do loop T$ = Inkey$ 'Changed to T$ incase repeat of S$ was a problem I = I + 1 text 0, 300, "Press a key to end " + str$(I), "LB", 2, 1, RGB(Cyan) pause 500 'Just to slow it down loop while T$ = "" End Edited 2020-08-24 13:50 by Andrew_G |
I tend to flush the keyboard buffer after using INKEY$ if extra stray keys are a problem. do i$ = inkey$ loop until i$<>"" DO : LOOP UNTIL INKEY$ = "" select case i$ ... Jim VK7JH MMedit |
Thanks Jim, That would do it! Is this tip worth putting in a manual or something?? Cheers, Andrew (KEYDOWN works but is a little more involved) |
| shaputer Newbie Joined: 25/07/2020 Location: United StatesPosts: 38 |
Could you elaborate on the KEYDOWN command ? I was trying to figure out what was the best way to move a sprite when I press the arrow keys. I get it to work with KEYDOWN, but in will only go in each direction ONCE. I can't go RIGHT over and over. The LOOP seems to be ignored even if I hold the KEY down without letting it go. I couldn't get any movement at all using the INKEY$ command. Thanks for any help. ![]() If what you are doing is bringing out the worst in you than stop doing it. |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11513 |
Have a play with the attached. Over the top but gives you an idea of one approach option explicit option default integer dim pressed(3) settick 25,keyint dim i do for i=0 to 3 if pressed(i) then text i*mm.info(fontwidth),10, chr$(pressed(i)) else text i*mm.info(fontwidth),10, chr$(32) endif next i loop 'routine to monitor keypresses and maintain a list of up to 'four that are pressed at any one time sub keyint local i,j local clearkey local keys(7) ' take a local copy of the keydown function for i=0 to 4 keys(i)=keydown(i) next i if keys(0) > 4 then keys(0)=4 'limit of 4 keys can be pressed ' first clear any keys that were pressed that are no longer for i=0 to 3 clearkey=1 if pressed(i) then for j=1 to keys(0) if keys(j)=pressed(i) then clearkey=0 'still pressed so don't clear keys(j)=0 'remove the key so it isn't used as a new press endif next j endif if clearkey then pressed(i)=0 endif next i ' now establish if there are any new key pressed for i=0 to 3 if pressed(i) then continue for 'slot already used for j=1 to keys(0) if keys(j) then pressed(i)=keys(j) keys(j)=0 'make sure a key isn't processed twice endif next j next i end sub |
Shaputer, G'day and welcome. I most definitely defer to Peter's far more comprehensive code above but this is what I adapted for version 2v6 of LunarLander here. It has a number of limitations but it works for me. I'd suggest having a play with Jim's tweak of INKEY$ above too. Cheers, Andrew 'KEYDOWN Play.BAS ' 'Plays with the use of KEYDOWN Dim Integer I cls print "Press left, right, space or ESCAPE key" 'MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM - Start of main loop do ' test for keypresses if keydown(0) then 'At least 1 key pressed IF TIMER > 200 THEN 'EXPERIMENTAL Not essential but change to alter response to subsequent key presses TIMER = 0 'print Keydown(0); " "; 'KEYDOWN(0) is the number of keys pressed for I = 1 to keydown(0) 'Only interested in 1 and above 'print Keydown(0); " ";keydown(i);" "; 'See Appendix F of manual for codes if keydown(I) = 27 then Exit Do 'ESCAPE so bail out if keydown(I) = 130 then GoLeft 'Left if keydown(I) = 131 then GoRight 'Right if keydown(I) = 32 Then GoSpace 'Space bar ' . . . next I endif End If Loop 'mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm - end of main loop Print "Goodbye" End Sub GoLeft print "Left" End Sub Sub GoRight print "Right" End Sub Sub GoSpace print "Space" End Sub |
INKEY$ works on both the USB keyboard and any attached terminal. Using INKEY$, you have to be aware that what gets sent when the Enter key is pressed will depend on a user OPTION for the USB keyboard and Terminal program settings on the PC console. KEYDOWN only works on the USB keyboard so it's use would exclude any user who is using their PC rather than a USB keyboard. If you are not interested in multiple keys down at once, INKEY$ is easier to handle. If you are likely to be interested in SHIFT-Arrow or Ctrl-Arrow etc, then KEYDOWN is required. Jim VK7JH MMedit |
Thanks Everyone ! ![]() If what you are doing is bringing out the worst in you than stop doing it. |
Well, I would never connect the CMM2 to a PC. It defeats the purpose in my opinion. I write and edit all programs directly using the keyboard connected to CMM2 that's connected to a monitor. I have no interest in using more than one key to trigger the sprite. The arrow keys. Keydown works perfectly, but the sprite still only moves once. I will have to work on how to manipulate sprites. Thanks, again everyone ![]() If what you are doing is bringing out the worst in you than stop doing it. |
Hi Shaputer, This is now my standard INKEY$ code. I trust it helps. Cheers, Andrew 'INKEY$_Play v2.BAS ' 'Plays with the use of INKEY$ 'TassyJims example ' do ' i$ = inkey$ ' loop until i$<>"" ' ' DO : LOOP UNTIL INKEY$ = "" ' select case i$ ' ... ' Dim Integer I dim String In cls print "Press left, right, space or ESCAPE key" 'MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM - Start of main loop do do ' test for keypresses In = INKEY$ loop Until In <> "" DO : LOOP UNTIL INKEY$ = "" 'This is Jim's game-changer Select Case asc(In) Case 27 'ESCAPE Exit Do Case = 130 'Left GoLeft Case 131 'Right GoRight Case 32 'Space bar GoSpace End Select 'In = "" Not necessary as it gets set to "" in the first pass in the DO Loop 'mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm - end of main loop Print "Goodbye" End Sub GoLeft print "Left" End Sub Sub GoRight print "Right" End Sub Sub GoSpace print "Space" End Sub |
