Forum Index : Microcontroller and PC projects : MMBASIC: Can I print a newline in the quoted part of string."
| chris Regular Member Joined: 24/08/2020 Location: United KingdomPosts: 56 |
Hi, I'm wondering if I can place a carriage return in a print statement? Is there a special escape code? Or do I have to use additional print statements for each line? I'm also wondering if when connecting CMM2 over serial, if there is a way to detect the width of the and height of the console window? Sorry for the questions, and if the answers are somewhere in the manual - I can't seem to find the answers. This is all new to me. Chris |
| KeepIS Guru Joined: 13/10/2014 Location: AustraliaPosts: 2175 |
print "123" + chr$(13) + chr$(10) + "456" Video Mode print MM.INFO$(MODE) MM.INFO options start on page 46 of User Manual. . Edited 2020-08-28 08:20 by KeepIS NANO:Inverter V 8.2ks - Linux AvrDude GUI script V4.1 |
Also print mm.vres ,mm.hres VK7JH MMedit |
| Bizzie Senior Member Joined: 06/07/2014 Location: AustraliaPosts: 192 |
Try this :- Dim CRLF As string = Chr$(13)+Chr$(10) Print "line1" Print "line2"+CRLF Print "line3" Output is:- line1 line2 line3 Is that what you want? I personally would use separate print statements, makes it clearer. Rob White |
