Forum Index : Microcontroller and PC projects : Stopping linefeed programatically in MMSASIC on CMM2
Herry![]() Senior Member Joined: 31/05/2014 Location: AustraliaPosts: 261 |
After the print command in a program the cursor moves down for the next line. Is there any way to keep the cursor on the word just printed, such as printing a character to emulate the up arrow. I seem to remember that in MS BASIC following the printed word with a semicolon like this worked: PRINT "hello"; Senior?! Whatever it says, I'm a complete and utter beginner... |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6626 |
You remember correctly The semi-colon is your friend CLS PRINT "hello"; PRINT " there!" Jim VK7JH MMedit |
I tried it TJ and it did not work for me! PRINT@(100,200)"hello"; Senior?! Whatever it says, I'm a complete and utter beginner... |
Works for me. CLS PRINT@(100,200)"hello"; PRINT " there!" VK7JH MMedit |
| capsikin Guru Joined: 30/06/2020 Location: AustraliaPosts: 342 |
Worked for me, but you need to print another thing to see it's on the same line, did you do that? PRINT@(100,200)"hello"; Print "same line"; I'm surprised we didn't need a space before "hello". |
bigmik![]() Guru Joined: 20/06/2011 Location: AustraliaPosts: 2982 |
Hi Herry, Can you post a photo of what you get? I get the correct result from Jim's example? Kind Regards Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
CLS PRINT@(100,200)"hello"; PRINT " there!" Maybe it's because I am using: N$ = "hello" print @(100,200)N$; When I repeat that line, the cursor moves down (the screen moves up) (Thanks for bearing with me!) Senior?! Whatever it says, I'm a complete and utter beginner... |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12047 |
Works properly as expected CLS PRINT @(100,100)"hello"; PRINT " there!" |
Start with just the short demo program we gave you. There must be something else you are doing that is causing an extra PRINT statement. VK7JH MMedit |
Hi Herry, Can you post EXACTLY the lines of code that are causing you grief, and if possible a picture of what is happening ?.. Even your simple example above looks fine on my CMM2 Kind Regards Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
TJ and BM Thanks. Yes. I guessed something else was causing it. I'll struggle on for bit first now I can be sure about the ; Senior?! Whatever it says, I'm a complete and utter beginner... |
Thanks. Yes. I guessed something else was causing it. I'll struggle on for bit first now I can be sure about the ; If you're using @(100,200) on a 200 line screen like mode 3, that could do it. |
Thanks. Yes. I guessed something else was causing it. I'll struggle on for bit first now I can be sure about the ; If you're using @(100,200) on a 200 line screen like mode 3, that could do it. No, largest default screen setting. Found the problem. Elsewhere in the program! Thanks to all. Senior?! Whatever it says, I'm a complete and utter beginner... |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6194 |
Are you typing this from the commandline ? OR in a program. The ";" forces the cursor to stay at that location, ready for the next print. But if you type this command from the commandline, and type <enter> the whole screen may scroll one line (depending where you are typing). If this is happening in a program, that will not happen, and you will get the text as described by TassyJim and matherp. So, type "F4" (the editor), and type the 2 lines that where proposed. Then type "F2" to run them. Success.. PicomiteVGA PETSCII ROBOTS |
All fixed! Senior?! Whatever it says, I'm a complete and utter beginner... |
