Local Time 02:23 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 - <@> and <"> swapped, DISPLAY 48, 102 and code line numbers
Andrew_G
Posted: 03:40am 30 Aug 2020
Hi everyone,
I'm sorry if these questions are repeats from others but I have searched for answers (and even RTFM):
1) Is there a simple solution to the interchange of <@> and <"> key responses on my CMM2 keyboard, an "HP Keyboard 100". It is a plain bog standard one, new from Officeworks. I've got the CMM2 keyboard set to UK.
OK I can interchange my brain but I do run another (compliant) keyboard on my PC so I DO get confused (annoyance level 2 out of 10).
2) In the OPTION LIST there is a line "CURRENT DISPLAY 48, 102" what is DISPLAY in this context and what are the two numbers? (I have the default mode at 9 - for other modes the values change).
3) I prefer to use MMEdit to crunch and remove blank line when downloading to the CMM2. When I get an error of course it doesn't correspond to any line numbers I can recognise.
Is it possible to have an option in the CMM2 editor that turns ON its line numbers (or shows the faulty code). One could then compare the code with the MMEdit version and track down the mistake.
(Yes I have turned off the MMEdit crunch etc but this particular code (it graphs temperatures from 10 sensors via HC-12s) runs 24/7 and the error (divide by zero) may not occur again, or for some time. Prior to this event it had been running for several days).
I'm running version 5.05.05b21.
Cheers,
Andrew
Posted: 03:56am 30 Aug 2020
1) set the keyboard to US
2) Display is the number of lines and number of characters to a line.
It will vary with mode and default font size.
3) If you EDIT on the CMM2 after an error, it will have the relevant line number matching the error message.
MMEdit used to keep a translation table for before/after crunch but that became unworkable with the new systems so I have dropped it.
Andrew_G
Posted: 04:33am 30 Aug 2020
Jim,
Thanks you are a marvel!
1) Fixed - I hope I don't have to give up on "colour" etc.
2) Thanks - it is clear once pointed out (is it in a manual or something?).
3) Thanks. The CMM2 VGA monitor and MMEdit chat window give the line number of the error (and that was the basis of my question) BUT, and here is the answer, when you EDIT on the CMM2 the cursor is positioned at the faulty line - THAT solves my problem.
Many thanks again Jim.
Andrew
Posted: 07:44am 30 Aug 2020
Hi Andrew, All,
I have just (literally 5 minutes ago found out why) finished building 2 more CMM2 and I used b22 firmware and was testing them when BOTH came up with the swap " and @ and an OPTION LIST Always showed keyboard UK and I could not change it.. Spent 30 or 40 minutes flashing this and that and then it dawned on me..
I had Jim's resistor test PCB plugged in at power-up and the CMM2 were being defaulted to UK keyboard..
I know that could happen but fell for it.
Small world..
Kind Regards
Posted: 08:08am 30 Aug 2020
  bigmik said  H
That's enough to drive a man to drink!
Sorry
paceman
Posted: 10:42am 30 Aug 2020
Mick,
I'll bet you're one of many, certainly me too. Until Jim just said that I didn't know either. I just put a sticker on each of the keys to remind me, thank heavens Andrew asked the question.
Greg
vegipete
Posted: 08:54pm 30 Aug 2020
  Andrew_G said  2) In the OPTION LIST there is a line "CURRENT DISPLAY 48, 102" what is DISPLAY in this context and what are the two numbers? (I have the default mode at 9 - for other modes the values change)
The OPTION DISPLAY numbers seem to be reversed from what you would expect. Screen resolution is given as X by Y yet text resolution is given as Y,X.
Posted: 09:36pm 30 Aug 2020
Option Display is same as MM+. Don't know why its that way - just is.
