Local Time 22:50 23 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Sprite maker written in basic.
capsikin
Posted: 10:35am 30 Aug 2020
I've made a simple sprite editor (I called it a sprite "maker" because it can't load a sprite file for further editing)
It edits a single sprite. Filename and size are hard coded in the program.
There's a bug when you try to edit the right hand column.
sprite-editor.bas.zip
capsikin
Posted: 10:39am 30 Aug 2020
Simple test case with the same bug
Update: Bug is apparently fixed with new CMM2 firmware, 5.05.05
Edited 2020-08-31 01:18 by capsikin
capsikin
Posted: 05:27am 05 Sep 2020
New version. improvements:
Takes advantage of 12 bit mode transparency in 5.05.06 beta. (change the program to use 8 bit mode if using earlier version, to avoid a bug)
Clears transparent pixels when displaying sprite after changes.
Allows using arrow keys.
sprite-editor.zip
capsikin
Posted: 06:31am 05 Sep 2020
Can reload it's output file for editing. If you copy another sprite file over the output file, it could probably edit the first sprite in the file (and not save all the other sprites, which is part of why you use a copy)
Keeps cursor location when saving and loading files.
sprite-editor.zip
