Local Time 22:49 23 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: difficulty with MID$
capsikin
Posted: 10:37am 30 Aug 2020
This test program crashes when I try to set the last character in the string. I can't see anything I'm doing wrong.
option base 1
dim s$
s$="123"
print s$
mid$(s$,1,1)="."
print s$
mid$(s$,2,1)="."
print s$
mid$(s$,3,1)="."
print s$
Posted: 10:51am 30 Aug 2020
I doesn't crash it just gives an incorrect error
Chopperp
Posted: 11:20am 30 Aug 2020
Try these
s$ = "123"
s$ = left$(s$,2) + "."
print s$
12.
s$ = "123"
s$ = left$(s$,1) + "." + right$(s$,1)
print s$
1.3
s$ = "123"
s$ = S$ + "."
print s$
123.
BTW I think matherp was hinting that you should check the usage of MID$.
Edited 2020-08-30 21:41 by Chopperp
ChopperP
capsikin
Posted: 02:08pm 30 Aug 2020
  Chopperp said  Try these
s$ = "123"
print s$
12.
s$ = "123"
print s$
1.3
s$ = "123"
s$ = S$ + "."
print s$
123.
I guess I'll reread it in case I missed something.
From the manual:
MID$( str$, start [, num]) = str2$
The characters in 'str$', beginning at position 'start', are replaced by the characters in 'str2$'. The optional 'num' refers to the number of characters from 'str2' that are used in the replacement. If 'num' is omitted, all of 'str2' is used. Whether 'num' is omitted or included, the replacement of characters never goes beyond the original length of 'str$'.
so in my use, the characters in s$ (initially "123", and "..3" by the time of the last change) beginning at position 3, are replaced by the characters in ".". 1 character from "." is used in the replacement. Looks correct.
Did you see there's a command version as well as a function version?
  matherp said  I doesn't crash it just gives an incorrect error
I think I might understand the distinction you're making. But I don't know if you mean it shouldn't give an error or should give a different error.
Posted: 03:15pm 30 Aug 2020
  Quote  But I don't know if you mean it shouldn't give an error or should give a different error.
It was a bug in the error checking - fixed in the 5.05.05 version Geoff has just uploaded
capsikin
Posted: 03:22pm 30 Aug 2020
Excellent!
