Local Time 22:49 23 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Updated Colour Maximite 2 Firmware (Ver 5.05.05)
Posted: 02:17pm 30 Aug 2020
We have a new version of the Colour Maximite 2's firmware and documentation available for download from https://geoffg.net/maximite.html  (scroll to the bottom of the page).
This is Ver 5.05.05 and is a significant release which wraps up all the changes made in the recent beta versions from Peter.  It is worth upgrading, even if you are running the latest beta version.
The source code at http://mmbasic.com  has been updated and if you have downloaded any previous versions of the source you can use the same link to download this version.
Enjoy!
chris
Posted: 11:10pm 30 Aug 2020
Checked out the release note. Sounds brilliant. Really appreciate 320 x 240, which gives me a nice 8-bit like 4:3 aspect ratio to work with.
Do you think that 512 x 384 could be added as an additional mode (double the ZX Spectrum resolution) or do the chip timings not work out?
Andrew_G
Posted: 12:01am 31 Aug 2020
Hey Geoff, "King of the Manuals",
I just looove the front cover.
(and of course many thanks to Peter too )
Andrew
berighteous
Posted: 09:55pm 31 Aug 2020
hi!
Does any usb A to usb A cable work?  I just got one in the mail.  I plugged it into the keyboard connector and the computer like the manual says and cube programmer says "No DFU detected" under port.
What am I doing wrong?  Does the USB-A to USB-A need to be a certain kind?
I've only ever updated the firmware with the regular usb-b cable
I had the cmm2 on, I type "update firmware" then the screen goes black like always, I plug the usb-a to usb-a into the keyboard port and into the computer.  I don't hear the device plugged in sound.  The maximite is still plugged in with the usb-b cable. cube programmer doesn't see the other connection. I can update with the uart the slow way without the usb-a cable.
Edited 2020-09-01 08:34 by berighteous
darthvader
Posted: 10:33pm 31 Aug 2020
  Quote  "No DFU detected"
Do you have move the switch to "SYSTEM" before connecting the USB to the KB port ?
berighteous
Posted: 10:36pm 31 Aug 2020
I used the "update firmware" command from the keyboard.  Does usb-a to usb A only work from the switch and not from "update Firmware" command?  I don't want to have to open the case every time we get a firmware update.
Edited 2020-09-01 08:36 by berighteous
shaputer
Posted: 01:41am 02 Sep 2020
I don't think so.  I made mine by cutting off an "A" plug from another cable and soldering the wires together.  Worked fine for me.
If what you are doing is bringing out the worst in you than stop doing it.
capsikin
Posted: 01:50am 02 Sep 2020
  chris said  Checked out the release note. Sounds brilliant. Really appreciate 320 x 240, which gives me a nice 8-bit like 4:3 aspect ratio to work with.
Not answering your question, but I think the ZX Spectrum screen looks better with a bit of extra space to be used as the border. Especially text. Maybe some games would be good full screen though.
capsikin
Posted: 01:57am 02 Sep 2020
  berighteous said  hi!
From the manual "Make sure that the Type-B USB power cable to the Colour Maximite is disconnected". Although I think I needed to have it plugged in. So I would suggest trying all three ways:
USB B cable disconnected.
USB B cable connected to power supply.
USB B cable connected to same computer as USB A-A cable.
