Local Time 22:49 23 Oct 2026 Privacy Policy
Forum Index : Guest Book : CMM2 - Sprite Swap Error
shaputer
Posted: 07:46pm 31 Aug 2020
My program works perfectly until I put this command to swap a sprite:
SPRITE SWAP 1, 2 'CAUSES "ORIGINAL BUFFER NOT DISPLAYED" ERROR
I don't know what the error message means.  Sprite 1 is on the screen.  Just want to swap the PNG Sprite image which is identical but mirrored.
Any ideas why this is happening  ? Thanks !
I'm using firmware ver. 5.05.05
Edited 2020-09-02 00:57 by shaputer
If what you are doing is bringing out the worst in you than stop doing it.
capsikin
Posted: 01:56pm 05 Sep 2020
I only just saw this - didn't notice the guest book before.
Maybe you did SPRITE WRITE instead of SPRITE SHOW?
You'd probably get more CMM2 people see the question in the "Microcontroller and PC projects" forum.
shaputer
Posted: 02:44pm 05 Sep 2020
Ooops !   I thought I did post it in the right place.  Wish I could move this post to that area.
I figured it out.
I was not using PAGE WRITE and PAGE COPY along with the SPRITE comannds.
Here is my solution:
CLS
 SPRITE LOADPNG 1, "CarR.png"
 SPRITE LOADPNG 2, "CarD.png"
'THE LOOP BELOW FLIPS THE SPRITE FROM ONE IMAGE TO ANOTHER USING 2 DIFFERENT SPRITES
DO
 SPRITE SHOW 1, 50, 50, 1 'SPRITE 1 ON PAGE 1
 PAUSE 200
 SPRITE SWAP 1, 2
 PAGE WRITE 0
 SPRITE SHOW 2, 50, 50, 0 'SPRITE 2 ON PAGE 0
 PAUSE 500
 PAGE COPY 0 TO 1 'REPLACE SPRITE 1 WITH SPRITE 2
 PAUSE 500
 PAGE COPY 1 TO 0  'REPLACE SPRITE 2 WITH SPRITE 1
 SPRITE SWAP 2, 1
LOOP
Edited 2020-09-06 00:44 by shaputer
