Forum Index : Microcontroller and PC projects : CMM2: Option <foo> "Invalid in a program"
Hi folks, I've been using a file called "config.bas" to reconfigure the CMM2's Options for a while now: SEARCH_PATH$ = "/bin/" s$ = Mm.Info$(Search Path) If LCase$(Mm.CmdLine$) = "reset" Or LCase$(Mm.CmdLine$) = "clear" Then Print "OK" Option Reset ElseIf LCase$(Mm.CmdLine$) = "list" Or s$ = SEARCH_PATH$ Then Option List ElseIf Mm.CmdLine$ <> "" Then Error "Unknown command line option" ElseIf s$ = "" Then Option F11 "chdir " + Chr$(34) + "/zmim/src" + Chr$(34) + Chr$(13) + Chr$(10) Option F12 "chdir " + Chr$(34) + "/sptools/src" + Chr$(34) + Chr$(13) + Chr$(10) Option Search Path "/magic/" Print "Please run *config again to complete setup" ' This will cause a reset option SD Timing Fast ElseIf s$ = "/magic/" Then Option Search Path SEARCH_PATH$ Print "OK" ' this will cause a reset Option RAM Else Error "Unknown state" EndIf But since the release version (or possibly one of the last betas that I missed) of 5.05.05 this has reported the error "Invalid in a program" for the setting of "SD Timing" and "RAM". Is this deliberate ? Is there an alternative ? On a related note, when I started my CMM2 this evening the red LED was flashing intermittently and the SD card would not read. I switched to OPTION SD TIMING CONSERVATIVE and it started working ... I then switched back to OPTION SD TIMING FAST and it was still working. Any ideas ? or was it just cosmic rays ? Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Turbo46 Guru Joined: 24/12/2017 Location: AustraliaPosts: 1693 |
On the SD card issue, Peter Mather said here: Bill Keep safe. Live long and prosper. |
All option changes that force a restart are not allowed in a program as it makes no sense and will confuse the majority. Some were missed previously but hopefully they are all now caught |
OK, but these options are still reset when the firmware is updated ? Should EXECUTE workaround the limitation or is it just something I need to accept ? It's not a big deal, but as you have observed before I seem to work on my CMM2 in an atypical manner. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
