Local Time 03:58 01 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pi-cromimte
lew247
Posted: 08:25am 04 Sep 2020
Hi
Are there any newer versions of Pi-Cromite ?
There's no single thread with all the versions on it, the last one I have doesn't work properly on Buster
Posted: 08:57am 04 Sep 2020
I'm sorry to report that I have given up on the Pi-cromite. The repeated new versions of both the Pi and Raspbian that break existing code make it impracticable to maintain.
I did have it working on the original release of Buster but one or more of the updates to Buster means I can't get it to work reliably and there aren't enough hours in the day to fight a continuously moving target.
If anyone wants the source code and would like to try and maintain it going forward then as long as they stick to Geoff's approach to licensing then I am happy to hand it over.
lew247
Posted: 08:32am 05 Sep 2020
That's a real shame because it's the only thing that can use MMBasic that has WiFi onboard
If someone does take this on then make it for one version of Pi operating system even if it's Stretch with no updates when they change up and no further models of Pi past Pi 3+ ie it can't be used on Pi4 versions
That should make it easier to find bugs and problems
hitsware2
Posted: 03:23pm 05 Sep 2020
If you explicitly want ( need ) MMBasic then yes .
There are other Basics that do OK on RPi though .
my site
lew247
Posted: 02:39pm 06 Sep 2020
Matherp
What was the last working version of Pi-Cromite for Stretch?
capsikin
Posted: 03:55pm 06 Sep 2020
You could also try the latest picromite on older versions of Buster.
The older versions were released as raspbian, I think they are here: http://downloads.raspberrypi.org/raspbian/images/
This looks like the first "buster": http://downloads.raspberrypi.org/raspbian/images/raspbian-2019-06-24/
and the newer versions were released as raspberry pi os http://downloads.raspberrypi.org/raspios_armhf/
Posted: 07:24am 07 Sep 2020
Best way forward is if someone on the forum has a working raspbian with working MMBasic, is that they draw an image of that SD card and use that.
Only thing you need to do is
- shrink the image (raspbian floods the whole SD card, but essentially needs only 2 Gbyte) to 3.5 Gbyte or so (so it will alway fit on any 4Gbyte+ SD card). Can be done with Gparted.
- use dd to draw a .img from that card (on another linux system).
- never ever update raspbian, or you will break MMbasic.
lew247
Posted: 11:58am 07 Sep 2020
I can get the older Raspbian images easily they are available online
What I need to know is what is the latest MMBasic for Pi that worked with Stretch
Posted: 12:22pm 07 Sep 2020
  Quote  What I need to know is what is the latest MMBasic for Pi that worked with Stretch
You could try using the forum search. But of course it is easier to let someone else do it
https://www.thebackshed.com/forum/ViewTopic.php?TID=10798&PID=127557#127557
lew247
Posted: 12:39pm 07 Sep 2020
I did use the forum search
But there are so many posts with different versions in different threads it's really hard to tell what the latest one was
Edited 2020-09-07 22:41 by lew247
