elk1984 Senior Member Joined: 11/07/2020 Location: United KingdomPosts: 232
Posted: 11:04pm 12 Sep 2020
Very newbie question (sorry!), but I can't find a way to keep my contants declared outside the main body of my code.
I've tried putting them in a SUB (not found as they're declared local) and in an include file (no effect).
Is this possible?
Thanks in advance for any help.
Posted: 12:08am 13 Sep 2020
Solved my own issue. Two things I'd done wrong.
1. When trying to include my constants, I'd used
#Include "Constants.lib"
Having two leading spaces meant the #Include directive was ignored.
2. When I removed the leading spaces, I got an error saying the file must be a .inc file
Renaming my .lib to .inc and the constants are working like a charm!
mkopack73 Senior Member Joined: 03/07/2020 Location: United StatesPosts: 261
Posted: 01:53pm 13 Sep 2020
Interesting that the 2 leading spaces caused it not to work. Let Peter know. Might be something he can fix quickly (might not be, probably some annoying quirk of the parser...)
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11882
Posted: 01:58pm 13 Sep 2020
Fixed in V5.05.05
Posted: 02:52pm 13 Sep 2020
Thanks - now I've got a long enough data cable, I'll flash the firmware tonight. I'm liking the flexibility hooking the CMM2 up over serial is giving. One keyboard and the ability to send files without spending £100 on a Wireless SD Card (although that would be cool)
Womble Senior Member Joined: 09/07/2020 Location: United KingdomPosts: 267
Posted: 07:26pm 18 Sep 2020
... without spending £100 on a Wireless SD Card (although that would be cool)
Don't do it. Wireless SD cards DO NOT WORK in the CMM2.
Someone has already tried, and failed.
Posted: 09:21am 19 Sep 2020
Thanks for the tip. That's £100 to spend on other gadgets. Like a video capture card Edited 2020-09-19 19:23 by elk1984
