Local Time 18:14 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Run without overwriting in memory program
elk1984
Posted: 03:06pm 13 Sep 2020
I'm not sure if anyone else has done this, but I'd like to have a set of functions and constants available (using autostart or similar) when starting my CMM2 without overwriting the currently loaded program (similar to a default #Include or being able to run from the Path except without actually loading the program for edit.
Is this possible?  Apologies for such a newbie question, but I've not seen anything in the programming manual that describes this.
Edited 2020-09-14 01:11 by elk1984
mkopack73
Posted: 04:16pm 13 Sep 2020
Are you asking if there is a way to do this so that those options and constants and such are there and exist in memory  so you can access and use them when programming on the command line (vs in the editor)?
If that's what you're asking, you could set them up in a BASIC program, run that program and let it complete and then from that point on in the command line (at least until you type new) I BELIEVE they should still be active (but haven't confirmed this, don't have my CMM2 near me) in the command line after the program ends.
I seem to recall there being something in the manual about auto-launching a .bas at power up, but I could be wrong. It's not something I've had a need for...
If you're just wanting an include that does these things in your programs (like a standard set of settings you always want to use in your code) just make a .inc with them and always include that at the start of your programs.
I don't know of any way to do it where you run something without blowing away the currently loaded program though.
Edited 2020-09-14 02:18 by mkopack73
CircuitGizmos
Posted: 04:17pm 13 Sep 2020
This is a pretty cool feature available in the -MicroMite- via the LIBRARY. There can be routines that are stored "permanently" (survives NEW, etc) in flash that run before the code runs.
The CMM2 does not do this.
elk1984
Posted: 04:27pm 13 Sep 2020
  CircuitGizmos said  This is a pretty cool feature available in the -MicroMite- via the LIBRARY. There can be routines that are stored "permanently" (survives NEW, etc) in flash that run before the code runs.
Yes, that's exactly the functionality I was looking for.
Posted: 05:07pm 13 Sep 2020
  Quote  This is a pretty cool feature available in the -MicroMite- via the LIBRARY.
This won't ever be available in the CMM2 before anyone asks
elk1984
Posted: 05:46pm 13 Sep 2020
I can understand why.  There are limited resources available and it's a niche use case.  The CMM2 is a great retro device and I've had more fun than in years of using more modern development languages and tools in my professional work.
It's a bit like popping the SD card out and sticking it my PC becuase it's the quickest way to do file manipulation - it breaks the retro feel for me.
So to give the use case (rather than a soluton   )
Is there a way of running a set of commands / a program without losing the currently loaded file?  I would even be open to my things having to save / reload the file that was loaded when the command was launched.
Posted: 06:03pm 13 Sep 2020
  elk1984 said  Is there a way of running a set of commands / a program without losing the currently loaded file?  I would even be open to my things having to save / reload the file that was loaded when the command was launched.
I'm hoping someone will tell me I am wrong, but I believe the answer is "No".
Either your programs have to know about each other and agree on a common mechanism to interchange data and launch each other, or as a special case of the former you have to write a "shell" and all the programs have to know how to behave when launched by the shell and return control to the shell when they exit.
Related to this I've been pondering the possibility of porting the pre-UNIX Software Tools Users Group Virtual Operating System from Ratfor to MMBasic and thus filling in many of the missing OS pieces from the CMM2. It looks possible and I think I have the skills, but currently not the time.
CircuitGizmos
Posted: 06:25pm 13 Sep 2020
Would you mean this?
Editing fred.bas (in memory)
On the command line type:
*flip
(This loads and runs whatever the flip program is)
Continue editing and it would be fred.bas
There would need to be a mechanism that when the * is encountered, the filename for the current file is saved, and then before the command prompt returns, that file is restored.
elk1984
Posted: 06:28pm 13 Sep 2020
*flip
It's a very BBC Micro way of looking at it (which is cool with me!) - commands extended via *, but yes - essentially that syntax with the ability to restore what was previously running.
For a set of constants etc, I'll have to get used to *setupMyStuff
Posted: 06:33pm 13 Sep 2020
*flip
Hence the need for a shell program. You would use it instead of the command line and it would try to handle all this. More likely than persuading Peter to engage in major extensions to the firmware. However I suspect it would be very challenging to implement and assume it would still need limited additional firmware support, e.g. a mechanism to return to the shell program if a program you run from it craps out.
Posted: 06:37pm 13 Sep 2020
  elk1984 said  It's a very BBC Micro way of looking at it (which is cool with me!) - commands extended via *, but yes - essentially that syntax with the ability to restore what was previously running.
The * syntax already exists, the other bit doesn't.
elk1984
Posted: 06:41pm 13 Sep 2020
Thanks - I'd aleady spotted that and was using it (in fact that's what got my hopes up).
elk1984
Posted: 06:42pm 13 Sep 2020
*flip
Agreed - like every product there's only a case for the time and effort if it's a core use case and this is a very edge case (talking myself out of an extension even if it would be considered here   )
Posted: 06:51pm 13 Sep 2020
You may know all this already, but in case you don't you can be the first person to give a damn about this post http://www.thebackshed.com/forum/ViewTopic_mobile.php?TID=12409
elk1984
Posted: 06:53pm 13 Sep 2020
  thwill said  You may know all this already, but in case you don't you can be the first person to give a damn about this post http://www.thebackshed.com/forum/ViewTopic_mobile.php?TID=12409
Definitely do!
CircuitGizmos
Posted: 07:09pm 13 Sep 2020
How about this convoluted scheme?
Editing fred.bas (in flash memory)
*flip
Parsing * changes to RAM mamory, loads and runs whatever the flip program is, then changes back to flash where fred.bas still is.
It would be like * shells out to the RAM setup.
Edited 2020-09-14 05:10 by CircuitGizmos
Posted: 07:24pm 13 Sep 2020
  CircuitGizmos said  How about this convoluted scheme? ...
I suspect that is a non-starter given switching between FLASH and RAM and vice-versa involves a restart ... something to do with fixing up the address space IIRC.
CircuitGizmos
Posted: 07:27pm 13 Sep 2020
Ah. Good point.
