Forum Index : Microcontroller and PC projects : CMM2 Not Playing Audio Files
| JohnD Newbie Joined: 23/08/2020 Location: New ZealandPosts: 6 |
I guess that I'll get better at this! I have a colour maximite 2 running MMBasic Ver 5.05.05. I have a manual for MMBasic Ver 5.05.04. I'm following this manual. In the direct mode the following command strings work: Play tone 100,200,200 Play wav "basin street blues" Play wav "" to play all wav files on the SD card Play modfile "T1" I have a separately powered desktop stereo speaker system that works well when the commands are made in the direct mode but there is no sound when the commands are made through a single line Basic programme. When I write a single line basic programme for each of these, the screen shows run a blank line and then the > cursor on the next line. If I try to play a file with a name that does not exist, the CMM2 reports "Error in line 1: Could not find the file. What am I doing wrong? |
Perhaps your program is ending before it has time to play the sounds. Try DO:LOOP until inkey$ <> "" before the end VK7JH MMedit |
That Fixed it. I didn't think of that. I expected it to work as if was called in the immediate mode. I'll have to write longer programmes. Many thanks. |
