Local Time 02:20 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Variable Scope
vegipete
Posted: 12:30am 09 Oct 2020
(This pertains to the CMM2 but probably applies to others too.)
A quick test shows that LOCAL variables are only visible in the subroutine or function in which they are declared and not in subroutines or functions called by said sub or function.
For example, in the following
test1  ' call first subroutine
? " main:v1 =" v1
end
sub test1   ' first subroutine
 local v1
 test2    ' call second subroutine
 ? "test1:v1 =" v1
end sub
sub test2   ' nested subroutine
 v1 = 5544  ' set a value for test1 to use - sorry, denied
 ? "test2:v1 =" v1
end sub
there is no way for the second subroutine to set the value of v1 for use by the first subroutine. Instead, test2 can only alter the global v1.
I suppose that is the way of things and there is no way around this without using global variables...
mkopack73
Posted: 12:33am 09 Oct 2020
Correct... If you want/need it accessible/modifyable by the 2nd level function, you have to pass it in as a parameter...
