Forum Index : Microcontroller and PC projects : CMM2 V5.05.06exp: Huge performance improvement - please test
Page 7 of 8 | |||||
twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1141 |
An observation regarding Welcome Tape / Lander and the firmware 5.05.06RC6. IMHO the rotation is wrong. I use this code to fix it. ' The CMM2 5.05.06 firmware fixes a "bug" present in the direction of rotation ' produced by the IMAGE ROTATE command of the 5.05.05 firmware. This code is ' intended to identify and use the correct rotation. PIXEL 0,1 ' draw one white pixel, left edge middle of a 3x3 region IMAGE ROTATE 0,0,3,3,0,0,90 IF PEEK(byte mm.info(page address 2) + 1) = 255 THEN ' test for pixel top center rotfactor = 1 ELSE rotfactor = -1 ENDIF The "ghost.bas" file gives me an error message: Error in line 16: Could not find the file Please check! |
Sasquatch Senior Member Joined: 08/05/2020 Location: United StatesPosts: 296 |
Warning: Long I2C timeouts (i.e. 1000ms or greater) can cause the dreaded system fault. -Carl |
thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 3865 |
Thanks. It would help if I knew which version of the Welcome Tape you were using. If it's a "release" version then the version number, if it's a "develop" version then the SHA from the head of the branch you are using. Also is it firmware RC6 or an experimental version you are using, in the latter case a link to the dated firmware download would help. Best wishes, Tom Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Hi Tom, cmm2-welcome-develop-r0.5. from: https://www.thebackshed.com/forum/ViewTopic.php?TID=12968&P=5#157612 Is that enough? Regards Michael |
Thanks, your probably mean the HEAD of that branch: I'll check it out when I have an opportunity. Best wishes, Tom Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Hi Tom, cmm2-welcome-develop-r0.5. from: https://www.thebackshed.com/forum/ViewTopic.php?TID=12968&P=5#157612 Firmware: 5.05.06RC6 (2020-10-26_001301_CMM2V1.5.zip) Is that enough? Regards Michael |
Thanks Michael. Tom Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 8604 |
Hopefully this is the last experimental version before the next release candidate: V5.05.06exp2. I've now tried pretty much all of the V0.5 welcome tape, zmim, gauntlet, wolf3d, defender, ffight, massive sorts, mouse, classic with mouse, non word aligned blitting to and from SDRAM pages, and so far everything works and is fast. CMM2V1.5.zip |
Hi Peter, I tested EXP2. No objection from here! Please release! A wish for the next version: MM.INFO(FreeDataMemory) would be useful. Especially because there is an OPTION RAM and an OPTION FLASH with different free memory. Thanks! Kind Regards Michael |
Womble Senior Member Joined: 09/07/2020 Location: United KingdomPosts: 267 |
@Peter ... Not sure if this belongs in the v5.05.06RC5 thread or here. I seem to have found a bug in SELECT CASE or I am completely misreading the Manual. However I try to use SELECT CASE in my program I get This is the source code that produces the error: '------------------------------------------------------------------------------------------- ' SELECT CASE Bug v5.05.06B15 and v5.05.06RC6 and EXP VERSION 2020-10-27_194858_CMM2V1.5 '------------------------------------------------------------------------------------------- 'Recommended Program Practice OPTION EXPLICIT ' Variables must be typed OPTION DEFAULT NONE ' Variables must be declared 'Global Variables and Constants CONST WIDTH% = 20 ' Number of Maze Columns (minimum 5) will be doubled+1 size CONST LENTH% = 20 ' Number of Maze Rows (minimum 5) will be doubled+1 size 'Declare Global Arrays DIM m$(2*LENTH%+1) length 2*WIDTH+1 ' Maze String Array, each string 2*WIDTH+1 chars long '------------------------------------------------------------------------------------------- ' Test Program DIM mR% ' Counter for printing a row of the maze FOR mR% = 1 TO (2*LENTH%+1) m$(mR%) = "#123456789X123456789@123456789X123456789#" NEXT mR% 'Print Maze Description CLS COLOUR RGB(WHITE) PRINT "Width:" 2*WIDTH%+1 " Length:" 2*LENTH%+1 'Display the m$() array contents COLOUR RGB(BROWN) FOR mR% = 1 to (LENTH% + LENTH% +1) ' ' ' HERE IS THE BUG, AND THE VARIATIONS I TRIED ' ' This causes the dreaded Error System Fault v5.05.06B15 nd v5.05.06RC6 and 2020-10-27_194858_CMM2V1 ' SELECT CASE m$(mR%) CASE "@" COLOUR RGB(RED) CASE "X" COLOUR RGB(GREEN) CASE ELSE COLOUR RGB(WHITE) END SELECT PRINT m$(mR%) ' ' So does this ' SELECT CASE m$(mR%) ' CASE "@" ' COLOUR RGB(RED) ' PRINT m$(mR%) ' CASE "X" ' COLOUR RGB(GREEN) ' PRINT m$(mR%) ' CASE ELSE ' COLOUR RGB(WHITE) ' PRINT m$(mR%) ' END SELECT ' ' And This ' SELECT CASE m$(mR%) ' CASE "@", "X" ' COLOUR RGB(RED) ' CASE ELSE ' COLOUR RGB(WHITE) ' END SELECT ' PRINT m$(mR%) ' ' ' ' Just printing without the COLOUR change works fine !!! No idea why? ' PRINT m$(mR%) ' ' NEXT mR% COLOUR RGB(WHITE) ' Exit Program Gracefully END '------------------------------------------------------------------------------------------- Bug_In_Select.zip This is a little self contained test program to show the error I seem to have found, with commented sections to show what I tried. I chopped this out of the program I am working on and made it selfcontained for easier testing (same code posted above). The firmware versions I tried this on were: v5.05.06B15 and v5.05.06RC6 and EXP VERSION 2020-10-27_194858_CMM2V1.5 Hopefully this is just me misunderstanding the instructions, or a simple bug fix. Regards Womble |
This appears to be an MMbasic bug that is in all versions, at least on the CMM2. I've contacted Geoff about it. In 5.05.05 the system just locks up and ctrl-C doesn't recover it. In 5.05.06 I've implemented a hardware watchdog so you get the watchdog timeout error. The issue seems to be in the use of an array element in the select case. The workaround is to copy the array element to a simple variable for the select case t$=M$(mR%) SELECT CASE t$ Edited 2020-10-28 01:22 by matherp |
@Peter ... Many thanks for the clarification, workaround, and for replying so fast. This was the first time I had used SELECT CASE on the CMM2 and it had me completely foxed. Your help is as always, Greatly Appreciated Womble |
@womble I don't understand. Is it this what you wanted to code: SELECT CASE mid$(M$(mR%),mR%,1) ?? Michael |
That also works without crashing but if you can use SELECT A$ then logically you should be able to use SELECT ARRAY$(I%) . In both cases the match won't happen if the CASE string and the SELECT string aren't the same. So the code was probably functionally incorrect but shouldn't have crashed. |
I can only guess. Maybe that's what Womble means? Something like that? 'Global Variables and Constants CONST WIDTH% = 20 ' Number of Maze Columns (minimum 5) will be doubled+1 sizeCONST LENTH% CONST LENTH% = 20 ' Number of Maze Rows (minimum 5) will be doubled+1 size 'Declare Global Arrays DIM m$(2*LENTH%+1) length 2*WIDTH+1 ' Maze String Array, each string 2*WIDTH+1 chars long DIM mR% ' Counter for printing a row of the maze DIM mC% ' Counter for printing a col of the maze FOR mR% = 1 TO (2*LENTH%+1) m$(mR%) = "#123456789X123456789@123456789X123456789#" NEXT mR% 'Print Maze Description CLS COLOUR RGB(WHITE) PRINT "Width:" 2*WIDTH%+1 " Length:" 2*LENTH%+1 'Display the m$() array contents 'COLOUR RGB(BROWN) FOR mR% = 1 to (2*LENTH% +1) For mC% = 1 to (2*WIDTH% +1) SELECT CASE mid$(M$(mR%),mC%,1) CASE "@" COLOUR RGB(RED) CASE "X" COLOUR RGB(GREEN) CASE ELSE COLOUR RGB(BLUE)+&HA000 END SELECT PRINT mid$(M$(mR%),mC%,1); NEXT mC% NEXT mR% COLOUR RGB(WHITE) ' Exit Program Gracefully END Edited 2020-10-28 03:17 by twofingers |
Odd, with "exp2" Most of the time Lunar Lander seems to work correctly, but just once it started up with controls reversed and some minor colour changes in the lander sprite. I don't see that problem with "ghost.bas", but I believe Peter has. Tom Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
OK, I've now seen it twice. I think the controls are fine because if you ignore the sprite the thrust occurs in the correct direction ... I think it's a graphical glitch and the sprite is being horizontally flipped for some reason - WTF! If it's a graphical issue it may also explain why the sprite colour looks off. Tom Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Hi Tom, with EXP2 this IF PEEK(byte mm.info(page address 2) + 1) = 255 THEN ' test for pixel top center works for me. rotfactor = 1 ELSE rotfactor = -1 ENDIF |
With the last firmware, a little more complex SELECT CASE sequence makes the CMM2 reset with system fault error. PS.: Iīm trying to get when it causes the error on the Into The Darkness, as Wolf3D uses almost the same engine and works perfectly. PS2.: Itīs not related to the SELECT CASE, itīs something with BLIT command that I canīt reproduce (yet). Edited 2020-10-28 08:45 by MauroXavier |
Mauro A bug has been discovered with select case when using strings. This is throughout MMbasic on all platforms as far as I can see. I think I have a fix but am waiting on Geoff's opinion. In the meantime avoid using select case with strings - use if, elseif etc. |
Page 7 of 8 |
