Local Time 03:27 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Graphics Commands, Arrays, and Terminating Conditions
NPHighview
Posted: 06:23am 23 Oct 2020
Folks - I'm writing a CMM2 implementation of Conway's Game of Life using some of the techniques from Michael Abrash's excellent Graphics Programming Black Book - Special Edition.
Since many of the graphics operators in MMBasic can use arrays, I'd like to set up a draw list for cells in Game of Life that are changing (dead --> alive, or alive --> dead).  This would be in the form of change_x(~10,000), change_y(~10,000) and change_color(~10,000), something like
   PIXEL change_x(), change_y(), change_color()
It's not clear to me whether the graphics operators will march unconcernedly through the arrays, heedless of value, or whether there is some "go no further" value that the operators will detect, and stop.
I could conceivably release and re-dimension the arrays each generation, but unfortunately, I won't know just exactly how many cells are changing state until the entire field is evaluated, and I'd rather not have to go through the same process twice to build the lists to pass to the PIXEL command.
Help please?!?
(Right now, I've got the program working, finding changes and immediately drawing or erasing pixels.  For a 500x250 field, this is 16-17 seconds per generation, even with Peter's excellent recent hashing-based Release Candidate.)
Edited 2020-10-23 16:40 by NPHighview
NPHighview
Posted: 03:56am 24 Oct 2020
OK - I've rewritten the Life program to clear and use a change list.  As I mentioned above, the list is composed of three arrays, draw_x(), draw_y(), and draw_c(), and each is (x-extent * y-extent) in size.  So, for the field shown in the drawing above, 500x250, that's 125,000 elements each (huge!!).  I use the MATH MAP function to rapidly clear the list after each generation.
Also, as I suspected, the PIXEL command happily zips through the list, drawing all of the changed pixels.  Unfortunately, my first attempt puked when I filled the list arrays with "-99" values, in hopes that the code would stop when it encountered an out-of-bounds value (can't use -99 as a color).  Unfortunately, it errored out, and "ON ERROR SKIP" skipped the entire PIXEL command, drawing nothing.
The actual number of changing cells, which, when randomly filled at a 10% probablility, goes something like this:
Out of 125,000 cells,
Gen 1: ~15,000 change, or 12%
Gen 2: ~ 5,000 change, or 4%
Gen 3: ~ 2,500 change, or 2%
after that: ~3,500 change, or ~3%
after ~450 generations, the amount of change is negligible:
So, for a huge fraction of the time, 95+% of the array extent is not used.  I don't exactly know what the PIXEL assembly code does when it finds coordinates off the screen, but it wasn't any faster than traversing the list step by step myself.
Unfortunately, both approaches turned out to be about a second slower than just setting the pixels as soon as the change was detected.
My request: alter the assembly code to terminate when an off-screen coordinate is encountered.
vegipete
Posted: 05:01am 24 Oct 2020
  NPHighview said  My request: alter the assembly code to terminate when an off-screen coordinate is encountered.
Eeek, no!  :-)
An off-screen coordinate is, in my view legitimate and quite valuable. Instead, a 'silly' value makes more sense, such as the value "10000" used in some of the sprite functions.
NPHighview
Posted: 04:03pm 24 Oct 2020
That works for me!  I could initialize the arrays with the silly value, then populate the arrays from 0 on up (sorry, non-C coders!), leaving only silly values after the "legit" list.
If I'm dreaming, I could also wish for a "linear transform" MATH function that applies both slope and intercept to an array of values (a current MATH function will only multiply, not add a value).  It would look like this:
MATH LINEAR a, b, old_array(){, new_array()}
where each element of new_array(i), if specified, is set to b + a*old_array(i).  That would allow me to apply scales and offsets to my floating-point values for X and Y and map them into a region of the integer coordinates of the physical screen.  (Maybe I can do this with quaternions - I'll have to check it out)
And if I'm really dreaming... clipping windows!
Edited 2020-10-25 02:48 by NPHighview
vegipete
Posted: 05:43pm 24 Oct 2020
I was dreaming about clipping regions too. Most of the clipping effect can be accomplished by drawing on a different page and then blitting the region of interest into view.
The only part that doesn't work with this method is printing text. Clipping would force the text to wrap and scroll inside the region but for now, we dream, and code it in basic.
I like your MATH LINEAR dream. Let's go nuts with our dreams and have a MATH ROTATE that takes as input theta, x() and y().
Posted: 07:57pm 24 Oct 2020
  Quote  MATH ADD in(), num, out()
This adds the value 'num' to every element of the matrix in() and puts the answer in out(). Works for arrays of any dimensionality of both integer and float and can convert between.
Setting b to 0 is optimised and is the fastest way of copying an entire array
MATH SCALE in(), scale ,out()
This scales the matrix in() by the scalar scale and puts the answer in out(). Works for arrays of any dimensionality of both integer and float and can convert between.
Setting b to 1 is optimised and is the fastest way of copying an entire array.
Put those two together and I think you have what you are after.
NPHighview
Posted: 09:19pm 24 Oct 2020
MATH ADD, MATH SCALE, and BLIT will do the trick - thanks to VegiPete and TassyJim (I'm going to have to find some catchy two syllable / one syllable nickname for the forum!)
- Steve "NPHighview just doesn't scan" Johnson
NPHighview
Posted: 10:20pm 25 Oct 2020
OK - strange stuff!
I first tried doing all of the plot graphics off-screen (to Page 1), and got weird artifacts when blitting from Page 1 to Page 0 to display.  Instead of this:
I got this on the screen (note jaggies whereas previous was very smooth):
and this is what the SAVE command produced (note the excursions beyond the plot area; I expected this, as I was using Blitting to copy just the plot area to screen 0):
So, I tried using the framebuffer instead.  This got even weirder, resulting in this:
which I got both using the "normal" PAGE WRITE FRAMEBUFFER syntax and the otherwise documented FRAMEBUFFER WRITE syntax.
Oh - I'm using Screen Mode 9, and Peter Mather's recent "hashing" firmware 5.0506RC5
Insights?  Suggestions?
Edited 2020-10-26 08:33 by NPHighview
Posted: 10:41pm 25 Oct 2020
  Quote   got this on the screen (note jaggies whereas previous was very smooth):
Please try the very latest experimental version. Another user found an issue when both the display page and Blitting page are in SDRAM and the copy involved non-word-aligned memory copies. This seems to be a H/W limitation that I've tried to code round
Edited 2020-10-26 08:42 by matherp
NPHighview
Posted: 11:07pm 25 Oct 2020
I just tried yesterday afternoon's firmware ("lots of diagnostic messages"), no joy, same jaggies, same System fault message when I tried using framebuffer.  The sign-on message still shows 5.05.06RC5, though; is there a different one I should try?
- Steve
Posted: 11:25pm 25 Oct 2020
This one is the latest (I think)
https://www.thebackshed.com/forum/uploads/matherp/2020-10-26_052139_CMM2V1.5.zip
NPHighview
Posted: 01:21am 26 Oct 2020
With the latest pointed to by TassyJim (above), trying BLIT commands,
* works: 2, 4, 6, 7 but too coarse to be useful
* fails: : 1, 8, 9, 10, and 13 shows jaggies, and doesn't draw vertical lines (width=1)
* fails: 11, 12 no extra video pages
* too coarse to tell: 3, 5
Or, if you prefer:
1 : Jaggies, vertical width=1 lines not drawn, text OK
2 : Works fine (but too low resolution to be useful)
3 : Too coarse to tell
4 : Works fine (but too low resolution to be useful)
5 : Too coarse to tell
6 : Works fine (but too low resolution to be useful)
7 : Works fine (but too low resolution to be useful)
8 : Jaggies, vertical width=1 lines not drawn, text OK
9 : Jaggies, vertical width=1 lines not drawn, text OK
10 : Jaggies, vertical width=1 lines not drawn, text OK
11 : Fails due to no extra video page(s)
12 : Fails due to no extra video page(s)
13 :  Jaggies, vertical width=1 lines not drawn, text OK
Sasquatch
Posted: 01:43am 26 Oct 2020
Warning - Long I2C timeout (i.e. 1000ms) can cause the dreaded system fault.
Update: sorry wrong thread!
Edited 2020-10-26 11:44 by Sasquatch
-Carl
Posted: 08:59am 26 Oct 2020
  Quote  With the latest pointed to by TassyJim (above), trying BLIT commands,
Please post simplest possible test code showing the issue. I think I have a fix but need to test properly.
Please particularly try and demonstrate the crash when trying to use the framebuffer
Edited 2020-10-26 20:52 by matherp
NPHighview
Posted: 05:40pm 26 Oct 2020
Here you go:
' blit_artifacts.bas - Demonstrates BLIT issues with mmBasic 5.05.06RC5
' Steve "NPHighview" Johnson      October 2020
OPTION Y_AXIS UP      ' Note upright Bitmap capture requires v.5.0506RC4 and up.
DIM INTEGER vres%, hres%
DIM INTEGER x%, y%
DIM INTEGER h0min%, h0max%, h0ctr%, h1min%, h1max%, h1ctr%
DIM INTEGER vmin%,  vmax%, vctr%
DIM STRING  key$
FOR Vmode% = 1 to 10
 FOR Cdepth% = 8 to 16 STEP 8
   Mode Vmode%,Cdepth%                   ' Set video mode and color depth
   hres% = MM.hres : vres% = MM.vres
   h0min% = 0         : h0max% = hres%/2-5 : h0ctr% = h0min%+(h0max%-h0min%)/2
   h1min% = hres%/2+5 : h1max% = hres%     : h1ctr% = h1min%+(h1max%-h1min%)/2
   vmin%  = 16        : vmax%  = vres%-15  ' leave room for text boxes
   PAGE WRITE 1 : CLS ' Clear the slate for blitting
   PAGE WRITE 0 : CLS ' OK - write to left half of screen directly.
   BOX  h0min%, vmin%, h0max%-h0min%, vmax%-vmin%, 4, &H7F7F00, &H400000 ' dark grey background
   FOR x% = h0min% to h0max% STEP 10 : LINE x%,     vmin%, x%,     vmax%, 1, &H606060 : NEXT x%
   FOR x% = h0min% to h0max% STEP 40 : LINE x%,     vmin%, x%,     vmax%, 2, &HA0A0A0 : NEXT x%
   FOR y% = vmin%  to vmax%  STEP 10 : LINE h0min%, y%,    h0max%, y%,    1, &H606060 : NEXT y%
   FOR y% = vmin%  to vmax%  STEP 40 : LINE h0min%, y%,    h0max%, y%,    2, &HA0A0A0 : NEXT y%
   TEXT h0ctr%, vres%, STR$(Vmode%)+":"+STR$(Cdepth%)+" Page 0", CT, 1, 1, RGB(yellow), -1
   PAGE WRITE 1 : CLS : BLIT h0min%, 0, h1min%, 0, hres%/2-5, vmax%, 0  ' BLIT the graph
   TEXT h1ctr%, vres%, "BLIT 0->1->0", CT, 1, 1, RGB(yellow), -1        ' Add Right Hand title
   PAGE WRITE 0 : BLIT h1min%, 0, h1min%, 0, hres%/2-5, vres%, 1        ' BLIT the right side back
   BOX 0, 0, hres%, 15, 1, &H808080, &H808080
   TEXT 0, 0, "[p] print, [q] quit, any other advances mode", LB, 1, 1, &H000000, -1
   key$ = inkey$ : DO WHILE key$ = "" : key$ = inkey$ : LOOP
   SELECT CASE key$
     CASE "q" : CLS : END
     CASE "p"
       PAGE WRITE 0 : SAVE IMAGE STR$(Vmode%)+"x"+STR$(Cdepth%)+"_Page0.BMP"
       PAGE WRITE 1 : SAVE IMAGE STR$(Vmode%)+"x"+STR$(Cdepth%)+"_Page1.BMP"
   END SELECT
 NEXT Cdepth%
NEXT Vmode%
Pressing "p" after each mode will save bitmap files from both page 0 and page 1.  Now that I can sequence through the modes and depths, it seems that it's in 16-bit color mode (I didn't run any tests at 12-bit).
In 16-bit Page 9, here are the two captured pages:
Page 0 (after blitting the left half to page 1 and then back)
and Page 1 (after blitting the left half of page 0 to the right half of page 1)
Edited 2020-10-27 03:46 by NPHighview
Posted: 05:48pm 26 Oct 2020
Great many thanks
Please try the attached
CMM2V1.5.zip
NPHighview
Posted: 05:56pm 26 Oct 2020
Just altered the program to cycle through 8, 12, and 16 bit color depths (except for mode 9, of course), and had to change explicit color values to RGB() values.  Problems not exhibited in 8-bit modes, but 12 and 16 bit in high resolution modes.  Party colors!
' Steve "NPHighview" Johnson      October 2020      sfjohnso@gmail.com
DIM INTEGER x%, y%
DIM STRING  key$
 FOR Cdepth% = 8 to 16 STEP 4
   IF Vmode% = 9 AND Cdepth% = 12 THEN Cdepth% = 16
   BOX  h0min%, vmin%, h0max%-h0min%, vmax%-vmin%, 4, RGB(red), RGB(gray) ' dark grey background
   FOR x% = h0min% to h0max% STEP 10 : LINE x%,     vmin%, x%,     vmax%, 1, RGB(black) : NEXT x%
   FOR y% = vmin%  to vmax%  STEP 10 : LINE h0min%, y%,    h0max%, y%,    1, RGB(black) : NEXT y%
   FOR x% = h0min% to h0max% STEP 40 : LINE x%,     vmin%, x%,     vmax%, 2, RGB(magenta) : NEXT x%
   FOR y% = vmin%  to vmax%  STEP 40 : LINE h0min%, y%,    h0max%, y%,    2, RGB(magenta) : NEXT y%
   BOX  h0min%, vmin%, h0max%-h0min%, vmax%-vmin%, 4, RGB(white)
   BOX 0, 0, hres%, 15, 1, RGB(white), RGB(white)
   TEXT 0, 0, "[p] print, [q] quit, any other advances mode", LB, 1, 1, RGB(black), -1
   SELECT CASE key$
     CASE "p"
   END SELECT
 NEXT Cdepth%
NEXT Vmode%
Edited 2020-10-27 04:12 by NPHighview
Posted: 06:48pm 26 Oct 2020
Sorry - not sure what I'm looking for seems to work fine for me. There will be subtle colour differences between the modes because they use different mappings onto RGB565 but I'm not seeing anything else.
I've attached the firmware again here in case the last post was the wrong version somehow
CMM2V1.5.zip
NPHighview
Posted: 07:32pm 26 Oct 2020
Yup, our postings crossed paths.  I've updated the firmware to your experimental version, and saw that the vertical line drawing now works in all modes and depths - thanks!
I'm afraid I can't characterize the color changes as subtle, however.  My 3D lissajous plot uses X, Y, and Z coordinates to create an RGB value; about one run in three, these are waaaaay off, as are the various shades of gray (now green or red) in the graph background and minor / major axis lines, and reds where there should be whites, and blues where there were cyans.  Here's how I get this behavior (behaviour - sorry!):
* Power on the CMM2 (often takes two switch throws to get video & the banner)
* Use Files command to select and immediately run the blitting Lissajous program (it has a CONST that is used to determine whether or not to use Blitting).  It uses mode 9 by default.
* The program runs - all is fine; colors look good.  This is true whether or not blitting is turned on.  Generally I lose patience and [ctrl]-[c] out, but sometimes I'll let it complete.
* Edit the program to "flip" the CONST - in the editor, the usually vibrant keyword coloration is muted.
* F1 to exit, F2 to run.  I get this on-screen; the captured bitmap file looks fine.  (I did check my VGA cables to make sure I didn't have any loose connections)
and
I'll poke around my little demo program to see if I can get it to do the same.
- Steve
NPHighview
Posted: 07:45pm 26 Oct 2020
More info:
* Repeating the steps above gets me the weird colors.
* Then, I exit, use Files to find my little demo program, run it through its modes (all look fine), then go back to the Lissajous plotter, and it looks fine.
* Wait until it's done, then enter editor (colors show muted).  Exit with no changes.
* Run - colors are completely messed up again.
Hope this helps.  Sorry, I haven't got to the Framebuffer issues yet :-)
