Forum Index : Microcontroller and PC projects : HC-12
Hi, Has anyone worked with HC-12 modules ? They default to 9600baud, and using AT commands you can change the baudrate. Question is: do they memorize the baudrate ? I have a remote system that cannot send data (init the HC-12) at 9600baud, so I need a PC to set the HC-12 to 2400baud, disconnect, and need it to cold boot after that running 2400 baud. Thanks in advance for your response, Volhout PicomiteVGA PETSCII ROBOTS |
See this thread (and more threads): http://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=12927 Micromites and Maximites! - Beginning Maximite |
Thnx PicomiteVGA PETSCII ROBOTS |
Yes, they remember the set baudrate. Pull the SET line low to enter programming mode, when you pull the SET line high again, the new settings take effect, and are used if you cycle the power. Smoke makes things work. When the smoke gets out, it stops! |
