Local Time 18:08 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : AUTORUN
romba6
Posted: 07:59pm 31 Oct 2020
I have a small program autorun.bas (below) to clear my I2C units.
I have OPTION AUTORUN ON
print "Reset I2C bus"
i2c open 100,1000
i2c write &h20,0,1,255
i2c write &h21,0,1,255
i2c close
print "Finished"
When I power up or hit RESET button, the response is :-
Reset I2C bus
Finished
print "Finished"'|7
If I just run the program on its own it's fine.
Where does the last line come from? What am I doing wrong?
Version = CMM2V5.05.05RC9.bin
twofingers
Posted: 02:09am 01 Nov 2020
Hi romba6,
as s first step I would update to the latest firmware update.
RC9 means "Release Candidate 9" the release version is CMM2V5.05.05.
I would this version test: https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=12998&LastEntry=Y#158101#158101.
For me - on the first glance - it looks like a minor old bug.
Without your I2C device I can't fully test your code.
Michael
Posted: 02:40am 01 Nov 2020
I don't think it should be needed but it is a good idea to end your program with END
  Quote  PRINT "Finished"
END
It fixed the problem for me.
Edited 2020-11-01 12:40 by TassyJim
romba6
Posted: 10:06am 01 Nov 2020
  TassyJim said  I don't think it should be needed but it is a good idea to end your program with END
Thank you Jim - it fixed the problem for me too !!!
What threw me was the fact that the program works perfectly when run on its own but not in AUTORUN
