Local Time 18:10 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C vs I2C2 vs I2C3
elk1984
Posted: 04:23pm 06 Nov 2020
This may be a stupid question, but what was the reasoning behind using I2C2 and I2C3 as commands rather than extending the I2C command to accept a <port> parameter?  Wouldn't combining and changing the parameters on the I2C command free up two tokens for other BASIC keywords?
Posted: 01:49am 08 Nov 2020
Like many things MMBasic, it just grew over time.
While testing the HT mouse versus my Arduino version, I needed a simple way the swap I2C ports so came up with this SUB
SUB I2Cx p%, I2Ccmd$
 SELECT CASE p%
   CASE 1
     EXECUTE "I2C "+I2Ccmd$
   CASE 2
     EXECUTE "I2C2 "+I2Ccmd$
   CASE 3
     EXECUTE "I2C3 "+I2Ccmd$
 END SELECT
END SUB
The full test program which has been tested on ports 1 and 2
 ' ht_mouse test
 CLS
 MODE 1
 mousePort = 2
 initmouse
 SPRITE LOAD "mouse.spr",1
 'pause 100
 DO
   readmouse
   TEXT 0,0,STR$(x,6,0," ")+STR$(y,6,0," ")+STR$(lb,2,0," ")+STR$(rb,2,0," ")+STR$(sb,2,0," ")+STR$(xs,4,0," ")+STR$(ys,4,0," ")+STR$(ss,6,0," ")
   SPRITE SHOW 1,x,y,1
   PAUSE 30
 LOOP UNTIL INKEY$ <>""
 SPRITE HIDE 1
 I2Cx mousePort, "CLOSE"
SUB initmouse
 I2Cx mousePort, "OPEN 100,1000"
 I2Cx mousePort, "WRITE 41,0,3,20,INT(MM.HRES \ 256),INT(MM.HRES MOD 256)"
 I2Cx mousePort, "WRITE 41,0,3,22,INT(MM.VRES \ 256),INT(MM.VRES MOD 256)"
 I2Cx mousePort, "WRITE 41,0,3,24,INT(MM.HRES \ 512),INT((MM.HRES\2) MOD 256)"
 I2Cx mousePort, "WRITE 41,0,3,26,INT(MM.VRES \ 512),INT((MM.VRES\2) MOD 256)"
 I2Cx mousePort, "WRITE 41,0,2,28,10"
END SUB
SUB readmouse
 DO
   I2Cx mousePort, "WRITE 41,1,1,0"
   I2Cx mousePort, "READ 41,0,10,s$"
   x=STR2BIN(UINT16,LEFT$(s$,2),big)
   y=STR2BIN(UINT16,MID$(s$,3,2),big)
   lb=ASC(MID$(s$,5,1))
   rb=ASC(MID$(s$,6,1))
   sb=ASC(MID$(s$,7,1))
   xs=STR2BIN(int8,MID$(s$,8,1))
   ys=STR2BIN(int8,MID$(s$,9,1))
   ss=ss+STR2BIN(int8,MID$(s$,10,1))
 LOOP UNTIL x>=0 AND x<MM.HRES AND y>=0 AND y< MM.VRES 'trap missreads
END SUB
 SELECT CASE p%
   CASE 1
   CASE 2
   CASE 3
 END SELECT
END SUB
