Forum Index : Microcontroller and PC projects : The Great Colour Maximite 2 Octahedron Prize Challenge
| Page 1 of 11 |
I'm interested to see how the CMM2 can facilitate 3D graphics and what additional features might be useful to help. I'd therefore like to challenge everyone to see how fast they can rotate a solid octahedron on-screen The rules are: CMM2 V5.05.06RC14 MODE 1,8 No CSUBS or other assembler by the backdoor No GOSUBs or GOTOs No ON ERRORs X, Y , Z vertices at 0,250,0, 250,0,0, -250,0,0, 0,-250,0, 0,0,250, 0,0,-250 Each face should be coloured differently and the correct faces should be hidden. Assume the viewer is at 0,0,0 and the octahedron centred on 0,0,1000 with a viewplane at 0,0,800 Each iteration should rotate the octahedron 2 degrees about the x axis (pitch), 1 degrees about the y axis (yaw) and 0.5 degrees about the z axis (roll) around the centre of the octahedron. Timing is from starting the program to completion of a complete rotation around Z (720 iterations) The final position must be visually indistinguishable from the starting position Code to be posted to this forum for me to test on the same CMM2 to establish the winner. Please post your times (use TIMER) on this thread as you develop. 480MHz users can multiply their times by 1.18 to allow comparison with 400MHz CMM2 (my benchmark ratio from a similar application) The competition closes at 17:00UTC on Friday 20th November. The judges (me) decision is final The judge cannot compete but will post reference times when available Prize for fastest program |
| johnd Newbie Joined: 22/10/2020 Location: United StatesPosts: 30 |
During each iteration, do we rotate the x, then y, then z separately; or can we do a combined single rotation for each iteration? |
Whatever you want as long as you fully update the display after every iteration |
| LeoNicolas Guru Joined: 07/10/2020 Location: CanadaPosts: 625 |
I loved this challenge. As probably you know I'm working on a 3D API for the CMM2. There are some features we can incorporate into the CMM2 API that will help a lot with 3D rendering. * Copying arrays with different dimensions... something like MATH COPY In(), Start,End,Out() * Calculate 2 vectors intersection This is my last code with the polygon clipping algorithm (not optimized): https://github.com/leonicolas/cmm2-3d-api/blob/master/api-3d.bas Edited 2020-11-07 05:35 by LeoNicolas |
| qwerty823 Newbie Joined: 30/07/2020 Location: United StatesPosts: 30 |
Peter, Are there any other rules then what you've outlined above? At a bare minimum, I can probably get this down to around ~720ms for all 720 iterations (give or take a few... and that's on a 400mhz). Granted, it would be cheating IMHO, but within the rules as you've laid them out. My idea is to precalc all the data in another program, then just iterate over the precalc data and draw triangles to the screen, although I assume that goes against the spirit of the challenge. Obviously, depending on if we write directly to page 0, or write to page 1 and do a copy to 0, can vary this greatly depending on if we pass B, I or D. Any thoughts on a minimal set of "must haves" for this? Maybe a simple basic program outlining how this should be done, perhaps? option explicit option default none option base 0 timer=0 Mode 1,8 '' Define any variables or other subs Sub Init ' Add any initialization code here End Sub Sub Rotate ' Rotate your octahedron here End Sub Sub Draw ' Draw your octahedron here End Sub Init Page Write 1 For i = 0 To 720 Rotate Draw Page Copy 1 To 0, B Next i Print timer End Something like that? Feel free to adapt this to something you think makes more sense, or if you feel like you want this to be more open ended, then that is fine too. :) I assume at a bare minimum that we want this to do the compute work in real time. |
Can you just draw on page 0 as fast as you can, even if the display can't keep up. Technically, that would still be updating the display. However, if we have to wait for vertical sync every iteration, then we can't do any faster than 720*(frame-draw-time), even if the algorithm is much faster. |
For the avoidance of doubt, entries that use pre-calculation of anything outside of the MMBasic program will be discounted. You do not need to use PAGE COPY. The challenge is to do the calculations and update the video memory as fast as possible. The transfer of the video memory to VGA output is asynchronous in the background and outside of your control so is not relevant. |
Will a flickering image be accepted? |
Peter Is this what you are expecting? ![]() Octahedron rendering with page copy (125 FPS): https://youtu.be/OFFE4AApq4U Octahedron rendering directly to page 0 (250 FPS): https://youtu.be/vvfzPPXxBUQ No optimizations yet, but it's being very cool |
Looks too small. I'm expecting the octahedron will be about 400 pixels high ((250+250)/1000*800) More clarification on the rules: Please print out the coordinates of all 6 vertices after 650 iterations. Do not use specific characteristics of a tetrahedron for hidden face analysis (i.e. only 4 faces can ever be showing). Please make the techniques for hidden faces fully generic. Should also have said to centre the output on MM.HRES\2, MM.VRES\2 angles to be considered as follows: X + 2 degrees rotates the top of the tetrahedron away from you Y + 1 degrees rotates the left of the tetrahedron away from you Z + 0.5 degrees rotates the tetrahedron clockwise from the perspective of the viewer If you are using Euler angles then rotate in the order x,y,z Before any rotation the screen should look something like this. The white border is the edge of the 800x600 display area (BOX 0,0,MM.HRES,MM.VRES) ![]() Edited 2020-11-07 21:31 by matherp |
| mkopack73 Senior Member Joined: 03/07/2020 Location: United StatesPosts: 261 |
Might be a good idea to also dictate the screen mode and color depth so comparing apples to apples. |
| PeteCotton Guru Joined: 13/08/2020 Location: CanadaPosts: 653 |
I know this is a competition, but just in case it helps anyone, if the above vertices are numbered 0 to 5, then the numbering for the right hand rotated planes is: 0,5,2 0,1,5 0,2,4 0,4,1 3,2,5 3,5,1 3,1,4 3,4,2 |
Mode 1,8 (from the original post). |
Be interesting to see if cross products to determine which faces to output will be faster than "painters" My current time for 720 iterations, with the area to be drawn cleared each time (mandatory), but no page copy is 3.449 seconds or 208FPS using Euler angles and Painters. The screen output seems to be taking just under half of the time so that could be nearly halved if hidden planes are not output , albeit at the expense of possibly more calculation. Of course without page copy the video output is a complete mess but the challenge is to do the calculations and display the output on a clear page as fast as possible. Video with page copy for reference This is running at 132 FPS In first post |
I'm using normals calculation for polygon occlusion. I have some questions: What are the expected coordinates at the 650th iteration? Are you expecting a code that can render any kind of polygon or can it be extremely optimized for octahedron? |
I guess I'll go first I have no idea if these vertices (from the 650th iteration) actually match anyone elses? 1759ms (409 frames per second) With Page Copy it drops to 5485ms (131 fps) ![]() Edited 2020-11-08 07:52 by PeteCotton |
Amazing Pete I'm near 400 FPS. I have some optimizations to implement :) I didn't understand this calc: "480MHz users can multiply their times by 1.18 to allow comparison with 400MHz CMM2" Shouldn't it be the inverse, 400MHz might multiply by 1.18? |
Matherp wants the time for 720 iterations, not frame rate. ============== This is perplexing. While experimenting with geometry and perspective, I created the following program which crashes my CMM2. Can anyone see what I'm doing wrong? In line 14, I loop through different perspective values. The max number of loops is 35 iterations, which suggests I'm nesting too many subroutines, but I can't see where I'm doing that. Maybe the restore command? mode 1,8 cls timer = 0 '====================================== rho = 20 d = 1500 theta = 0.3 phi = 1.3 cx = MM.HRES/2 cy = MM.VRES/2 s1 = sin(theta) : s2 = sin(phi) c1 = cos(theta) : c2 = cos(phi) for rho = 10 to 100 ' crash past 45 - ie 35 iteration max cls restore cubeshape read x,y,z transform for j = 1 to 9 bx = sx by = sy read x,y,z transform line bx,by,sx,sy next j for j = 1 to 3 read x,y,z transform bx = sx by = sy read x,y,z transform line bx,by,sx,sy next j print @(250,50) rho pause 20 next rho end sub transform xe = - x * s1 + y * c1 ye = - x * c1 * c2 - y * s1 * c2 + z * s2 ze = - x * s2 * c1 - y * s2 * s1 - z * c2 + rho sx = d * xe / ze + cx sy = cy - d * ye / ze end sub cubeshape: data 1, 1, 1 data 1,-1, 1, -1,-1, 1, -1, 1, 1, 1, 1, 1, 1, 1,-1 data 1,-1,-1, -1,-1,-1, -1, 1,-1, 1, 1,-1 data 1,-1, 1, 1,-1,-1 data -1,-1, 1, -1,-1,-1 data -1, 1, 1, -1, 1,-1 Also, I see after the BSOD that the colour map has changed. The white text is "whiter-than-white." Error: System fault - possible causes - Incorrect use of POKE - Faulty CSUB - Reserved words used as variables - Firmware problem > map reset > Edited 2020-11-08 10:07 by vegipete Visit Vegipete's *Mite Library for cool programs. |
I managed to creep mine up to 1642ms (438 FPS). Mine is a 480mhz, so I guess my adjusted time is 1,937ms. Edited 2020-11-08 11:12 by PeteCotton |
Wow... I'm still optimizing my code... |
| Page 1 of 11 |
