Forum Index : Microcontroller and PC projects : Maximum font size?
| MustardMan Senior Member Joined: 30/08/2019 Location: AustraliaPosts: 175 |
I would like to create a custom font to display probably four or five large, single colour images (ie: 4 or 5 characters). A font is defined such (pseudocode): DefineFont #n where aa = number of characters, bb = first character, cc = height, dd = widthaabbccdd xxxxxxxx ... End DefineFont which implies a maximum character size of 256x256 pixels. FontTweak (to my knowledge) won't allow fonts anywhere near this big, so I was wondering if there was a size limit other than the sort-of-implied 256? Cheers, Edited 2020-11-15 08:08 by MustardMan |
FontTweak has a sanity check which stops you creating fonts that large but it will open and allow you to edit them if required. The biggest I have tried is 240 x 64 Jim VK7JH MMedit |
Hi Jim, Thanks for the quick reply! I wonder what you guys do all day - it seems whenever something is posted, everyone is onto it straight away! I wish I had time for that Using FontTweak I can open my bitmap (256x256) which it then defaults to import at 79x92, then double size and re-import, giving a size of 158x184. I think that will look quite nice. When I was creating my font I noticed that adding a character (^N) duplicated the first character into the second (or was that the other way around?). Anyway it was not a big deal as once I noticed that I just created a font with everything empty, then went through and filled in the correct symbols. Cheers, Edit: It would appear the initial size (79x92) was simply because that was the last font size I edited and had nothing to do with the imported bitmap size. Unusual size... would have expected multiples of 8... Edited 2020-11-15 12:46 by MustardMan |
Hi, for playing with the fonts, you can modify my simple app, I used it for the creating the font for Napoleon Commander from Atari ST bitmap> OPTION DEFAULT NONE OPTION EXPLICIT OPTION BASE 0 CONST INP.FNT = "AtariST.BMP" 'input file name CONST OUT.FNT = "AtariST.FNT" 'output file name CONST CHR_W.FNT = 8 'char width in pixels CONST CHR_H.FNT = 16 'char height in pixels CONST BMP_W.FNT = 128 'BMP width in pixels CONST TOPLEFT.FNT = 32 'first char read from BMP CONST BOTRIGHT.FNT = 255 'last char read from BMP CONST FIRST.FNT = 32 'ACII of first char CONST INVERT.FNT = 1 '0=WHITE on BLACK, 1=BLACK on WHITE (can be used to invert font) convChar END SUB convChar LOCAL INTEGER ww = BMP_W.FNT / CHR_W.FNT LOCAL INTEGER hh = 32/CHR_W.FNT LOCAL INTEGER x, y LOCAL INTEGER xx, yy, col, bright, b, ch, cpl = 0 LOCAL STRING h = "" LOAD BMP INP.FNT OPEN OUT.FNT FOR OUTPUT AS #1 ?#1,"DefineFont #8" ?#1," "HEX$(BOTRIGHT.FNT-TOPLEFT.FNT+1,2)HEX$(FIRST.FNT,2)HEX$(CHR_H.FNT,2)HEX$(CHR_W.FNT,2) ?#1," "; FOR ch =TOPLEFT.FNT TO BOTRIGHT.FNT x = (ch MOD ww) * CHR_W.FNT y = (ch\ww) * CHR_H.FNT FOR yy=0 TO CHR_H.FNT-1 b = 0 FOR xx=0 TO CHR_W.FNT-1 col = PIXEL(x + xx, y + yy) bright = ((col AND &hFF0000) >> 16) + ((col AND &hFF00) >> 8) + (col AND &hFF) IF INVERT.FNT THEN IF bright < 382 THEN b = b + 2^(CHR_W.FNT - xx - 1) PIXEL x + xx, y + yy, RGB(RED) ENDIF ELSE IF bright > 382 THEN b = b + 2^(CHR_W.FNT - xx -1) PIXEL x + xx, y + yy, RGB(RED) ENDIF ENDIF NEXT xx h = HEX$(b,2) + h IF LEN(h) = 8 THEN ?#1,h" "; h = "" cpl = cpl + 1 IF cpl = 8 THEN IF ch < BOTRIGHT.FNT THEN ?#1 ?#1," "; ENDIF cpl = 0 ENDIF ENDIF NEXT yy NEXT ch ?#1 ?#1,"END DefineFont" CLOSE #1 END SUB Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), Â CMM2.fun |
Double post... Edited 2020-11-16 19:43 by jirsoft Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), Â CMM2.fun |
