Forum Index : Microcontroller and PC projects : syntax error?
| markboston36 Regular Member Joined: 27/10/2020 Location: United StatesPosts: 76 |
ok so i decided to try some of the programs in the manual. the days program i get a syntax error on line 28 and for the life of me i cannot see what its complaining about unless there is an issue with the code. ' Example program to calculate the number of days between two dayes OPTION EXPLICIT OPTION DEFAULT NONE TRACE ON dim STRING s dim FLOAT d1, d2 DO print : print "Enter the date as dd mmm yyyy" print "first date"; input s d1 = GetDays(s) if d1 = 0 then print "invalid date:" : continue do print "second date"; input s d2 = GetDays(s) IF d2 = 0 then print "invalid date!" : continue do print "Difference is" ABS(d2 - d1) " days" loop 'calculate the number of days since 1/1/1900 function GetDays(d$) as float local string Month(11) = ("jan", "feb", "mar", "apr", "may", "jun", "jul", "aug", "sep", "oct", "nov", "dec") local float Days(11) = (0,31,59,90,120,151,181,212,243,273,304,334) local float day, mth, yr, s1, s2, 'find the seperating space character within a date s1 = INSTR(d$, " ") if si = 0 then exit function s2 = INSTR(s1 + 1, d$, " ") if s2 = 0 then exit function 'get the day month and year as numbers day = VAL(MID$(d$, 1, s2 - 1)) - 1 if day < 0 or day > 30 then exit function for mth = 0 to 11 if LCASE$(MID$(d$, s1 + 1, 3)) = Month(mth) then exit for next mth if mth > 11 then exit function yr = VAL(MID$(d$, s2 + 1)) - 1900 if yr < 1 or yr >= 200 then exit function ' calculate the number of days uncluding adjustment for leap years GetDays = (yr * 365) + FIX((yr - 1) / 4) if yr MOD 4 = 0 and mth >= 2 then GetDays = Getdays + 1 GetDays = GetDays + Days(mth) = day end function |
You have a spurious comma at the end of the line and the interpreter is looking for another variable name. Also check the function EPOCH for this application Edited 2020-11-21 05:34 by matherp |
its always the easy ones that allude me. im looking for something complicated and it was a typo :P. |
ok now its running but its not doing what its suppose to. when i type in the first day i get a bunch of numbers then it says enter first date and keeps repeating. |
fixed that now im stuck in the first date loop. for some reason it thinks what im typing in is 0 because i keep getting invalid date. |
I copied the program from the "Introduction..." PDF. The only line I changed was to remove the linebreak in line 21 IT runs correctly and tells me I am 25044 days old. (Time flys when you are having fun) There will be a few typos in your code. Jim VK7JH MMedit |
I see a typo si for s1 No doubt others. John |
si instead of s1 on line 33 and the second = should be a + on line 53 VK7JH MMedit |
This is the complete program (with no errors). You should be able to copy and paste from this webpage. ' Example program to calculate the number of days between two dates OPTION EXPLICIT OPTION DEFAULT NONE DIM STRING s DIM FLOAT d1, d2 DO PRINT : PRINT "Enter the date as dd mmm yyyy" PRINT " First date"; INPUT s d1 = GetDays(s) IF d1 = 0 THEN PRINT "Invalid date!" : CONTINUE DO PRINT "Second date"; INPUT s d2 = GetDays(s) IF d2 = 0 THEN PRINT "Invalid date!" : CONTINUE DO PRINT "Difference is" ABS(d2 - d1) " days" LOOP ' Calculate the number of days since 1/1/1900 FUNCTION GetDays(d$) AS FLOAT LOCAL STRING Month(11) = "jan","feb","mar","apr","may","jun","jul","aug","sep","oct","nov","dec") LOCAL FLOAT Days(11) = (0,31,59,90,120,151,181,212,243,273,304,334) LOCAL FLOAT day, mth, yr, s1, s2 ' Find the separating space character within a date s1 = INSTR(d$, " ") IF s1 = 0 THEN EXIT FUNCTION s2 = INSTR(s1 + 1, d$, " ") IF s2 = 0 THEN EXIT FUNCTION ' Get the day, month and year as numbers day = VAL(MID$(d$, 1, s2 - 1)) - 1 IF day < 0 OR day > 30 THEN EXIT FUNCTION FOR mth = 0 TO 11 IF LCASE$(MID$(d$, s1 + 1, 3)) = Month(mth) THEN EXIT FOR NEXT mth IF mth > 11 THEN EXIT FUNCTION yr = VAL(MID$(d$, s2 + 1)) - 1900 IF yr < 1 OR yr >= 200 THEN EXIT FUNCTION ' Calculate the number of days including adjustment for leap years GetDays = (yr * 365) + FIX((yr - 1) / 4) IF yr MOD 4 = 0 AND mth >= 2 THEN GetDays = GetDays + 1 GetDays = GetDays + Days(mth) + day END FUNCTION Geoff Graham - http://geoffg.net |
amazing how one typo can cause a big issue. thanks for all your help guys. |
