Local Time 02:25 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.06.00b4: More "fun" functionality for testing
     Page 1 of 3
Posted: 06:43pm 23 Nov 2020
V5.06.00b4
This beta should fix the problems identified in MATH SET, PAGE_AND in addition there is some new "stuff" which you are invited to test and use.
HELP changes
Pressing F12 in the middle of a word will now load the whole word into the help system. So you don't need to be at the beginning of a command or function name to find the help for it.
When you exit help in the editor the command at the top is copied into a buffer. You can use F11 to paste this into your program. It just inserts this at the cursor so typically you would point to a blank line and press F11. Then you can replace the syntax example with your data and, assuming the help text is correct, know you have the syntax correct.
SORT changes
The syntax for SORT is now
SORT array() [,indexarray] [,flags] [,startposition] [,elementstosort]
The new parameters should have no impact on existing code which will default them to run as before.
flag values are:
bit0:  0 (default if omitted) normal sort - 1 reverse sort
bit1:  0 (default) case dependent - 1 sort is case independent
startposition defines which element in the array to start the sort. Default is 0 (OPTION BASE 0) or 1 (OPTION BASE 1)
elementstosort defines how many elements in the array should be sorted. Default is all elements after the startposition
CHOICE function
CHOICE(condition, ExpressionIfTrue, ExpressionIfFalse)
This new function allows you to do simple either or selections much more efficiently and faster than using IF THEN ELSE ENDIF clauses
The condition is anything that will resolve to nonzero (true) or zero (false)
The expressions are anything that you could normally assign to a variable or use in a command
e.g.
print choice(1, "hello","bye") will print "Hello"
print choice(0, "hello","bye") will print "Bye"
a=1:b=1:print choice(a=b, "hello","bye") will print "Hello"
Finally:
You can use MM.INFO(DIRECTORY) as an alternative to the function cwd$. There is one small difference in that the pathname in MM.INFO(DIRECTORY) will always end with the '/' character
Edited 2020-11-24 04:45 by matherp
Posted: 06:49pm 23 Nov 2020
Thank you Peter
<does a happy dance>
elk1984
Posted: 07:25pm 23 Nov 2020
Fantastic stuff. Thanks Peter!
Hi Peter,
Hmm, because we have to provide parameter N before we provide N+1 we potentially have to allocate a (large) redundant index() array for SORT(). I don't suppose it does, or can support a dummy value, e.g.
SORT a$(),0,&b11,lb%,num%
Also for user-friendliness should you consider using letters for the flags, c.f. the flag that controls the behaviour of DIR$() ?
Thanks for the enhancements,
Posted: 07:29pm 23 Nov 2020
You can miss out any of the optional parameters
SORT a$(),,2,,10 is perfectly valid
Edited 2020-11-24 05:30 by matherp
Posted: 07:41pm 23 Nov 2020
  matherp said  You can miss out any of the optional parameters
Ah, lovely.
Posted: 08:12pm 23 Nov 2020
No splash screen image on startup.
The usual text does go out the serial and the space is there where the logo etc should be.
Or is black the new black?
Sasquatch
Posted: 08:24pm 23 Nov 2020
Thanks!
Page_AND etc. Working great in 16bit modes, however now throws error complaining about parameters in Mode 1,12
-Carl
Posted: 09:08pm 23 Nov 2020
exiting out of the commandline HELP gives an assortment of errors.
Unknown command
> help
Invalid character: *
Posted: 10:55pm 23 Nov 2020
  Quote  however now throws error complaining about parameters in Mode 1,12
This is correct. You can't use page 0 as an input in any mode or or page 1 as an input in 12-bit mode to AND, OR, or XOR as they are the display pages. This will be in the documentation. They can be used as the output of course.
  Quote  No splash screen image on startup.
me trying to clear all video pages to meet previous comment but in the wrong place - easy fix
  Quote  exiting out of the commandline HELP gives an assortment of errors.
Also easy fix - should test better
Posted: 05:22am 24 Nov 2020
There is something strange with SORT
If I include index zero, the index array is correct but if I try and start the sort at 1, the sorted array is OK but the index array is "strange"
 OPTION EXPLICIT
 OPTION DEFAULT NONE
 DIM INTEGER maxFiles = 500 ' adjust to suit expected maximum
 DIM fList$(maxFiles) LENGTH 60' file names for sorting
 DIM fSort$(maxFiles) LENGTH 60
 DIM fIndex%(maxFiles)
 DIM INTEGER mf, z
 DIM f$
 mf = 1
 f$ = DIR$("*", ALL)
 DO WHILE f$ <> ""
   IF MM.INFO$(FILESIZE f$)=-2 THEN ' it is a directory
     fList$(mf) = " "+f$+" <DIR>"' the leading space keeps directories sorted first
   ELSE
     fList$(mf) = f$
   ENDIF
   mf = mf + 1
   IF mf > maxFiles THEN EXIT DO
   f$ = DIR$()
 LOOP
 mf = mf -1 ' we now know the number of entries
 ' print the unsorted list
 PRINT
 FOR z = 1 TO mf
   PRINT STR$(z,4);" ";fList$(z)
 NEXT z
 ' make a copy to use in the sort
 FOR z = 1 TO mf
   fSort$(z)= fList$(z)
 NEXT z
 'SORT fSort$(), fIndex%(),&b10,0, mf+1 ' this one works
 SORT fSort$(), fIndex%(),&b10,1, mf ' this one gives strange fIndex%()
 ' print the sorted list and the original data using the index array
 PRINT
 FOR z = 1 TO mf
   PRINT STR$(fIndex%(z),4);" "; fSort$(z);"     ";fList$(fIndex%(z))
 NEXT z
END
Posted: 08:02am 24 Nov 2020
Thanks Jim
I wasn't correctly passing the start index into the sort - will post b5 when I've tested all the fixes
Posted: 10:00am 24 Nov 2020
V5.06.00b5 posted
Should fix the HELP and SORT bugs identified above
also now allows any pages to be used for PAGE AND_PIXELS etc.
Edited 2020-11-24 20:02 by matherp
markboston36
Posted: 04:26pm 24 Nov 2020
i need to get on the ball and learn this so i can use all of these fancy new things.
Posted: 09:13pm 24 Nov 2020
  matherp said  V5.06.00b5 posted
Close but no cigar.
Fixed for string arrays but still has a problem with integer arrays when starting from an index other than zero.
 OPTION EXPLICIT
 OPTION DEFAULT NONE
 DIM fSize%(maxFiles) ' file sizes
 dim fSort$(maxFiles) LENGTH 60
 DIM fsortSize%(maxFiles)
 dim fIndex%(maxFiles)
 DIM INTEGER mf, z
 DIM f$
 mf = 1
 f$ = DIR$("*", ALL)
 DO WHILE f$ <> ""
   fSize%(mf)=MM.INFO$(FILESIZE f$)
   IF fSize%(mf) = -2 THEN ' it is a directory
   ELSE
     fList$(mf) = f$
   ENDIF
   mf = mf + 1
   f$ = DIR$()
 LOOP
 PRINT
 FOR z = 1 TO mf
 NEXT z
 ' sort by file size using numbers instead of strings
 math add fSize%(), 0, fSortSize%()
 '  SORT fSortSize%(), fIndex%(),&b10,0, mf+1 ' this one works
 SORT fSortSize%(), fIndex%(),&b10,1, mf ' this one has problems
 PRINT
 FOR z = 0 TO mf
   PRINT STR$(fIndex%(z),4);" "; STR$(fSize%(fIndex%(z)),10,0);"  "; fList$(fIndex%(z))
 NEXT z
Posted: 10:45pm 24 Nov 2020
This code doesn't run - gives a string length error
Can you come up with a simple example without involving strings if you think integer arrays are incorrect
Edited 2020-11-25 08:50 by matherp
Posted: 11:01pm 24 Nov 2020
  matherp said  Jim
I assume you have file names longer than 60 characters.
Try removing the 'length 60' of the two arrays
Or this:
 OPTION EXPLICIT
 OPTION DEFAULT NONE
 DIM INTEGER mf, z
 DIM f$
 mf = 1
 f$ = DIR$("*", ALL)
 DO WHILE f$ <> ""
   mf = mf + 1
   f$ = DIR$()
 LOOP
 PRINT
 FOR z = 1 TO mf
   PRINT STR$(z,4);" ";fSize%(z)
 NEXT z
 'SORT fSortSize%(), fIndex%(),&b10,0, mf+1 ' this one works
 ' print the sorted list (including index aero)
 PRINT
 FOR z = 0 TO mf
   PRINT STR$(fIndex%(z),4);" "; fSize%(fIndex%(z))
 NEXT z
Edited 2020-11-25 09:07 by TassyJim
LeoNicolas
Posted: 06:15am 25 Nov 2020
The MATH Q_VECTOR command signature in the manual is wrong.
The manual specifies this signature:
MATH Q_VECTOR inV(), outVQ()
and the correct is:
MATH Q_VECTOR x,y,z,outVQ()
Posted: 08:27pm 25 Nov 2020
A new bug to "blow your mind", at least it did mine.
As usual the code below is a stripped down version of something moderately sane:
Colour Maximite 2
MMBasic Version 5.06.00b5
Copyright 2011-2020 Geoff Graham
Copyright 2016-2020 Peter Mather
> list "bug.bas"
repeat()
End
Sub repeat()
 Local i$
'  Local j$
 Print "Hello"
 Pause 2000
 Run "bug.bas"
End Sub
Run whilst looking at the VGA display.
It should display:
Hello
Hello
Hello
Hello
It did this on beta 2, but in beta 5 it clears the screen between each invocation but doesn't reset the y position, so instead the text "Hello" slowly migrates down the screen.
I'm not sure if it is intended but please don't start clearing PAGE 0 automatically before/after program invocations, that will make writing programs that extend the capabilities of the BASIC console and work on the VGA display impossible.
But this isn't even the bug that blows my mind, now uncomment the Local j$ and run again, still looking at the VGA display.
The display now flashes / re-synchs / blanks, whatever the technical term is, between each program invocation and it did this in beta 2 as well.
Edited 2020-11-26 06:28 by thwill
vegipete
Posted: 09:20pm 25 Nov 2020
  thwill said  I'm not sure if it is intended but please don't start clearing PAGE 0 automatically before/after program invocations, that will make writing programs that extend the capabilities of the BASIC console and work on the VGA display impossible.
I would extend that and say, please don't clear ANY pages when a program is run. If a programmer needs a cleared page, it is the programmer's responsibility to do the clearing. Yes, my 3D maze program shows corrupted graphics when run after another program that used higher pages, but that is not the job of the firmware to fix.
As Tom says, there could be many reasons to want pre-existing data to persist between separate programs.
     Page 1 of 3
