Local Time 02:23 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Beta 5.06 Problem?
toml_12953
Posted: 01:59am 25 Nov 2020
At
Demo X Video
Demo X has an excellent demo of the CMM2. I'm using MMBasic 5.06.00b5.
When I run his demo, I get some lockups and when it does run through, I get
an index out of bounds in DEMO_RACING.INC line 238.
Has anyone else run this combination of MMBasic and this demo successfully?
Edited 2020-11-25 12:00 by toml_12953
markboston36
Posted: 03:12am 25 Nov 2020
i get the same error running V 5.05.06RC21. must be a hidden bug he didn't find??
vegipete
Posted: 05:06am 25 Nov 2020
Fails for me too using 5.06.00b4.
Not an ideal fix but if you change line 209 to
speed=975
then it runs without the "Index out of bounds" error. Seems to be because the newer firmware is faster. Hopefully Mauro can figure out a proper fix because this change messes up the draw timing at the bottom of the screen slightly. Maybe a number slightly larger than 975 would be better. (Original value is 1000)
Lock-ups could be due to a less than ideal SD card.
MauroXavier
Posted: 03:08pm 25 Nov 2020
Even with the FPS capping, the Demo X blows out but I found another way to fix this definitively (as I fixed it in the past but the problem comes back again).
I will fix it this weekend and will upload to GitHub.
The new version will run more smoothly and will use some commands of the new firmware to make some effects more impressive.
It will be called Demo X+, as the differences will be really perceptive.
