Local Time 16:43 05 May 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : bug in latest firmware release?
johngill
Posted: 11:38am 26 Nov 2020
Hi all,
I'm currently running on CMM2V5.06.00b4 and I'm tinkering with a bit of a text-adventure interpreter so I can write my own text adventures (drawing rather heavily on ZIL)
If you type the following line as a program:
exit$="(EAST TO KITCHEN)(WEST TO STRANGE_PASSAGE IF CYCLOPS_FLED ELSE 'sorry but the wooden door is nailed shut.')"
and run it, you get this:
Error in line 1: No DO loop is in effect
This must be a firmware bug yes?
johngill
Posted: 11:41am 26 Nov 2020
_update_
apologies, I've only just noticed that the latest firmware is B6!!
Downloading now
johngill
Posted: 11:47am 26 Nov 2020
_update_
B6 firmware installed, this error is still displayed.
  johngill said  ... I'm tinkering with a bit of a text-adventure interpreter so I can write my own text adventures (drawing rather heavily on ZIL) ...
Hi John,
Are you writing an "interpreter" ? or are you writing a "compiler" ? As I understand it ZIL (Zork Implementation Language) is a Lisp like language that was complied to Z-machine code.
Posted: 11:50am 26 Nov 2020
Your issue goes away if you put DIM infront of it, but I agree it otherwise looks like a bug.
I really recommend starting your MMBasic programs with OPTION EXPLICIT ON, explicit variable declaration will save you from so many bugs later on.
Posted: 12:30pm 26 Nov 2020
exit is a reserved word and when it appears as the first thing in the line it is interpreted as a command
Edited 2020-11-26 22:38 by matherp
johngill
Posted: 12:46pm 26 Nov 2020
  matherp said  exit is a reserved word and when it appears as the first thing in the line it is interpreted as a command
ah! many thanks, it's just me being a numpty then :-D
Posted: 01:01pm 26 Nov 2020
  johngill said  ah! many thanks, it's just me being a numpty then :-D
I wouldn't have said that, it's the interpreter not being as friendly as it could be ... possibly a legacy of compromises made both for performance and in order to fit it into the flash on the earlier/smaller 'mites.
johngill
Posted: 01:09pm 26 Nov 2020
Hi John,
Hi Tom,
I already have your excellent zmim (along with colossal cave and zork I to keep me going... ;-) fantastic job- thanks for that!
Yes, I want to be able to write my own adventures in something approximating ZIL. I'm more of a "hobbyist" coder, this won't be a full-on implementation of ZIL, just my simplified version, running the entire adventure from just one ZILish text file.
eg,
<ROOM LIVING_ROOM
 (DESC... etc etc.)
 (ACTION.... >
<OBJECT LAMP
 (FDESC.... etc etc..)
 (ACTION...>
(VERB TAKE
 (SYNONYM.... etc etc)>
In fact I think I'm going to call it ZILish. ;-)
But rather than writing this as a compiler to convert the zil into z code to run on zmim, I want to write it as an interpreter, so I can run the source text file directly.
I've already got the parser to extract a verb, direct object and indirect object from the player's input. It's keeping me entertained anyway!
thanks
Posted: 01:12pm 26 Nov 2020
  johngill said  I already have your excellent zmim (along with colossal cave and zork I to keep me going... ;-) fantastic job- thanks for that!
Thank you.
  Quote  But rather than writing this as a compiler to convert the zil into z code to run on zmim, I want to write it as an interpreter, so I can run the source text file directly.
Sounds cool, good luck with it.
CaptainBoing
Posted: 01:48pm 26 Nov 2020
deleted
Edited 2020-11-26 23:49 by CaptainBoing
