Local Time 03:28 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: GETSCANLINE
Posted: 12:05am 28 Nov 2020
I have been investigating GETSCANLINE
GETSCANLINE zero is always the start of the vertical sync pulse.
First, I found the maximum value returned for each mode.
It is of note that for some modes the maximum is half that of similar modes.
mode 3.8 maximum is 499 while mode 3.12 is 249
That will make life interesting if you want to cater for more than one mode.
Next, I measured the time from the start of the sync pulse to the start of video appearing.
This was done visually on the CRO so not very precise.
I converted this into lines.
Next was the time between the end of video to the start of the sync pulse.
This is also listed in uS and lines.
In both cases, if the maximum scan line for a particular mode is half it's neighbours, you have to halve the line number.
Most mode take between 20 and 30 uS per line so something like
IF GETSCANLINE = 0 is not going to work reliably.
You need to allow a range of values to be sure that your code will see the value.
IF GETSCANLINE < 5
is a safe way to initialise an action and will work for all modes.
Alternatively, you can sit in a tight loop waiting for your chosen line to arrive. That could be a full vertical trace period.
If you really need the maximum time to setup the display, using
IF GETSCANLINE > 460 AND GETSCANLINE < 470
will give you ~2.5mS to do your thing in mode 2.8
 maximum getscanline     display start      display end
    8     12    16         uS  lines          uS  lines
1   627   627   627        700    26           50    626
2   499   499   499       1600    60         1100    460
3   499   249   499       1600    60         1100    460
4   499   499   499       1150    43          700    475
5   499   249   499       1150    43          700    475
6   499   249   499        500    18            0    498
7   499   249   499        500    18            0    498
8   499   499   499        500    18            0    498
9   805         805        700    33          100    801
10  516   516   516       1000    30          200    510
11  749         749        500    25          100    745
12 1124         562        550    36           50   1116
13  627   313   627        700    26           50    626
Posted: 08:35am 28 Nov 2020
  Quote  t is of note that for some modes the maximum is half that of similar modes.
This is because you had write page set to a page other than 0 (probably 1). I'll make it consistent in the next beta so it will always be like 12-bit colour.
To get the best out of this you need also to know the front and back porch info for each mode. In particular for modes 2,3,4,5 there is lots more time available. I'll post something later in the day on this thread that perhaps can be included in the graphics manual
Posted: 10:44am 28 Nov 2020
  [ said  QUOTE=matherp
I hadn't thought about different pages having any effect.
Now I think about it, I think I see why.
I will do it again sticking to page 0
Posted: 11:40am 28 Nov 2020
  Quote  I will do it again sticking to page 0
Wait for the next beta as it will change to be the smaller value for all colour modes as was the case in 5.05 (I think?)
Edited 2020-11-28 21:42 by matherp
Posted: 11:21pm 30 Nov 2020
Recent updates have changed GETSCANLINE a bit (for the better)
GETSCANLINE zero is always the start of the first visible linee.
The maximum value returned for each mode varies depending on the mode..
The table below contains the maximum value returned by GETSCANLINE for each mode.
Finally it lists the time in microseconds for the time between the end of the last line and the start of the first line.
IF GETSCANLINE = MM.VRES might take a few video frames before triggering.
You need to allow a range of values to be sure that your code will see the value at the earliest opportunity..
IF GETSCANLINE > MM.VRES and GETSCANLINE < (MM.VRES+5)
is a safer way to initialise an action and will work for all modes.
            GETSCANLINES
mode   display    maximum      uS of
      lines    scan lines   blanking
1       600       627         750
2       400       499        2690
3       200       249        2690
4       432       499        1800
5       216       249        1800
6       240       249         540
7       240       249         540
8       480       499         540
9       768       805         800
10      480       516        1190
11      720       749         670
12      540       562         670
13      300       313         750
All colour depths now report the same number of scan lines again and starting with zero equal to line zero makes a lot of sense.
George H
Posted: 02:56am 01 Dec 2020
Timely post!  I was just wondering about this.  So easy to make things work on this thing!
George H
Posted: 09:24pm 04 Dec 2020
So to make sure I'm understanding the chart above:
mode 1
 do
loop while getscanline > mm.vres and getscanline < mm.vres+5
Should run the code in the do/loop in the blanking interval, provided it doesn't exceed 750 uS to execute? (27 scan lines)
Or is a do/loop not the best construct for this.  Goal is smooth screen drawing in the interval.
Thanks!
George
Posted: 09:36pm 04 Dec 2020
Most of the time, you can write to a page other than zero and use
PAGE COPY x TO 0 ,B
and let MMBasic do the timing.
If you can't use that, how you wait until GETSCANLINE is greater than MM.VRES  depends on you program flow.
The sooner you do the write after the scan line reaches the start of the blanking period, the more time you have available.
If your code takes longer than the blanking period, there 'may' be some visible artifacts. It depends on too many tings to know if that is a problem.
vegipete
Posted: 01:16am 05 Dec 2020
There are 3 versions of "PAGE COPY n,0[,B/D]"
(Note "," seems to work the same as "TO")
1) PAGE COPY n,0  => copy the page now, pause the program until done,
2) PAGE COPY n,0,B  => pause the program, wait for the next vertical blanking, then copy, then program continues,
3) PAGE COPY n,0,D  => program continues execution, copy happens in the background at next vertical blanking.
#1 is likely to get tearing.
#2 is the safest visually.
#3 is great if you have much computation to do before you start redrawing the image on page n.
Method 3 would be safer to use if there were a way to test when the copy has finished.
George H
Posted: 01:42am 05 Dec 2020
Thanks for the info, 'D' seems to work the best in my case, it's smooth and the program is much quicker.  I'm using mode 1 here, just messing around.
I'm guessing the other modes (2-5, 10) should be quicker with I or B, because of more blanking time?  I'll give them a try.
