Local Time 02:21 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : No Print Zones???
toml_12953
Posted: 03:01pm 30 Nov 2020
In almost every other version of BASIC, there are pre-defined print zones (usually four or five on a line) and a comma in a PRINT statement will advance to the next print zone. This isn't the case in MMBasic. Having print zones makes it much easier to align output simply since the print after the comma doesn't depend on the length of the item before the comma. Example:
10 FOR I=1 TO 100
20 PRINT I,SQR(I),I^(1/3),SIN(I),COS(I)
30 NEXT I
will print nice, neat columns in the other BASICs but not in MMBasic. Would it be possible to implement print zones? Of course with MMBasic the number could vary depending on the screen mode but as long as the size of the print zones was constant, there should be no problem.
Posted: 03:10pm 30 Nov 2020
Whether your idea is good or bad, the fact is that a change would break many existing programs so the answer is a definite no. Look at the @() function for how to format print output.
10 FOR I=1 TO 100
20 PRINT I,@(120)SQR(I),@(240)I^(1/3),@(360)SIN(I),@(480)COS(I)
30 NEXT I
PS: line numbers are SO passé
Edited 2020-12-01 01:10 by matherp
vegipete
Posted: 06:05pm 30 Nov 2020
Oooo! Cool, I didn't know you could do that!
toml_12953
Posted: 06:58pm 30 Nov 2020
Neither did I. I thought you needed x,y coordinates. More careful reading for me!
Posted: 08:23pm 30 Nov 2020
You can always use TAB()
FOR I=1 TO 100
PRINT I;TAB(5); SQR(I);TAB(20);I^(1/3);TAB(35);SIN(I);TAB(50);COS(I)
NEXT I
but it suffers from the same problems of most when the data length varies.
I prefer STR$() as a means of getting well controlled readouts.
FOR I=1 TO 100
PRINT STR$(I,4);STR$(SQR(I),4,6);STR$(I^(1/3),4,6);STR$(SIN(I),4,6);STR$(COS(I),4,6)
NEXT I
I never liked the old FORMAT command but that's another way.
Lots of choices.
toml_12953
Posted: 01:01pm 02 Dec 2020
  matherp said  Whether your idea is good or bad, the fact is that a change would break many existing programs so the answer is a definite no. Look at the @() function for how to format print output.
10 FOR I=1 TO 100
30 NEXT I
One of the underlying philosophies of BASIC has been, "Give the
user a solution that is satisfactory most of the time. If the expert needs something
fancier, let the expert do the extra work!" - Back to BASIC by John Kemeny and Thomas Kurtz pp. 11.
Which looks more beginner friendly to you?
or
Do people programming for the CMM2 system really do that much columnar output that the CMM2 programs rely on comma being a tab? How many programs could it break? I'll bet there are a lot more BASIC programs that rely on print zones than ones that rely on a comma as a tab character.
As for line numbers, I made my living for 42 years programming in BASIC and I ain't about to change now! :^)
Posted: 02:12pm 02 Dec 2020
  Quote  Do people programming for the CMM2 system really do that much columnar output that the CMM2 programs rely on comma being a tab? How many programs could it break?
The CMM2 is part of the MMBasic family and the PRINT statement is the same in all versions.
  Quote  As for line numbers, I made my living for 42 years programming in BASIC and I ain't about to change now! :^)
Fine but be aware your programs will run slightly slower than they need as they are simply ignored unless used as gosub or goto targets. In the case of gosub or goto line numbers are many times slower than using a label
toml_12953
Posted: 02:45pm 02 Dec 2020
I have over 1500 BASIC programs that would need converting. The time that would take is much longer than any increased time my programs spend by using line numbers!
How about this:
OPTION COMMA [TAB | ZONE]
with the default being TAB?
Edited 2020-12-03 00:46 by toml_12953
mclout999
Posted: 04:09pm 02 Dec 2020
  Quote  I have over 1500 BASIC programs that would need converting. The time that would take is much longer than any increased time my programs spend by using line numbers!
 Here is a suggestion.  Why don't you start your conversions and then post them here and ask others to try to modify them to uses the more modern and efficient forms and standards?  If your contributions would benefit from the performance gains and have utility for some users then maybe they will get that TLC and later from those examples you might learn how easy it is to convert your programs when needs be.   This is a community that chips in from my experience.  We are all here to enjoy the CMM2 and any contributions can add to that. I find that I learn from almost every bit of code that is posted.
Have a great day.
Posted: 04:44pm 02 Dec 2020
Converting 1500 suggests to me to make a program to do them one by one (akin to the transpiler discussed already).
That idea works, BTW - used a converting program many years ago I know not how many times!
My experience was that there are a surprising number of "minor" differences waiting to trip you up.
toml_12953
Posted: 04:49pm 02 Dec 2020
Have a great day.
Here's a simple one. It's a projectile program that was a mess originally. I rewrote it in a structured manner and eliminated the line numbers. The ZIP file includes both versions.
Projectile.zip
Posted: 04:57pm 02 Dec 2020
OPTION BASE 0
DIM X(126),K(2)
FUNCTION FNA(X,Y,Z)
FNA=X*SIN(Y*0.01745329)*Z-16*Z^2
END FUNCTION
DO
  LET F2=0
  INPUT "MUZZLE VELOCITY AND ANGLE? "; M,A
  LET X(0)=0
  FOR T=0.2 TO 25 STEP 0.2
     LET L=INT(5*T+0.001)
     LET X(L)=FNA(M,A,T)
     IF X(L)<0 THEN EXIT FOR
     IF X(L)-X(L-1)<=0 AND F2=0 THEN
        IF X(L-1)-X(L-2)<X(L)-X(L-1) THEN
           LET K(1)=X(L-2)
           LET W4=T-0.4+J
        ELSE
           LET K(1)=X(L-1)
           LET W4=T-0.2+J
        END IF
        LET F2=1
        FOR J=0.01 TO 0.2 STEP 0.01
           LET K(2)=FNA(M,A,W4)
           IF K(1)-K(2)<=0 THEN EXIT FOR
           LET K(1)=K(2)
        NEXT J
        LET K1=MAX(K(1),K(2))
     END IF
  NEXT T
  LET W=L-1
     LET K(1)=FNA(M,A,T-0.2+J)
     IF K(1)<0 THEN EXIT FOR
  NEXT J
  PRINT "MAXIMUM HEIGHT IS ";K1;" FEET"
  LET Y=M*COS(A*0.01745329)*(T-0.2+J-0.01)
  PRINT "RANGE IS ";Y;" FEET"
  PRINT "TOTAL TIME AIRBORNE IS ";(T+J-0.01);" SECONDS"
  IF K1+14>60 THEN
     LET M1=1/(INT(K1/60+1))
     PRINT "SCALE OF HEIGHT IS 1 SPACE = ";1/M1;" FEET"
  ELSE
     LET M1=1
  END IF
  FOR D=1 TO 80
     PRINT TAB(D+19);"+";
  NEXT D
  PRINT
  PRINT " 0";TAB(20);"+"
  FOR N=1 TO W
     PRINT 0.2*N*M*COS(A*0.01745329);TAB(20);"+";TAB(X(N)*M1+20);"*"
  NEXT N
  INPUT "ANYMORE (YES OR NO)?";ANS$
LOOP WHILE ANS$="YES"
END
toml_12953
Posted: 05:11pm 02 Dec 2020
You can say that again!
It's the minor differences that would prevent creating a program to do much of the work. The bulk of CMM BASIC is the same as traditional versions so no work would be needed. In some cases (see below) the difference can be bridged with a mechanical substitution but in others, not.
Original:
DEF FNA(X,Y,Z)=4*X^2-3*Y/Z
Translation:
FUNCTION FNA(X,Y,Z): FNA=4*X^2-3*Y/Z: END FUNCTION
The above is simple for a program to change automatically. For print zones, single line PRINT statements aren't too bad, just use @((printzone-1)*120) but if the program depends on automatic line feeds, to get to the next print zone on the next line, it can get complicated.
Posted: 05:41pm 02 Dec 2020
OK. I did it (years ago) and it worked.  Cut a HUGE problem down to middling.
  toml_12953 said  It's the minor differences that would prevent creating a program to do much of the work. The bulk of CMM BASIC is the same as traditional versions ...
The "traditional versions" vary a lot to the point where really it's almost meaningless to say they are traditional.
