Forum Index : Microcontroller and PC projects : CMM2: Keyboard Codes - Arrows and Shift
vegipete
Posted: 01:33am 18 Dec 2020
I've been experimenting a bit with reading the keyboard and have puzzled myself slightly.
The following will display the ascii code of any key pressed, along with the state of the modifiers: (left and right shift/ctrl/alt/gui)
do
   do : k = asc(inkey$) : loop until k <> 0
   print @(400,100) k, bin$(keydown(7),8) "    "
loop
The arrow keys give 128,129,130,131 as expected.
However, holding a SHIFT key and pressing arrows is giving unexpected results:
L_SHIFT+LEFT    130  00001000  fine
L_SHIFT+UP      128  00001000  fine
L_SHIFT+DOWN    161  00001000  huh? Why not 129?
L_SHIFT+RIGHT   163  00001000  huh? Why not 131?
Are the codes for shifted down and right just weird for my keyboard or is something else going on?
Shift-numberpad-arrows gives the expected results, as do other modifiers. It's only shift-down and shift-right that are weird.
Do others see the same?
(Using MMBasic Version 5.06.00RC4)
Edited 2020-12-18 11:34 by vegipete
Posted: 02:56am 18 Dec 2020
  [ said  QUOTE=vegipete
I get the same results here
If you try playing at a command prompt in Windows, you will find that shift-right and shift-down are used for selection extend so I don't think it is purely a MMBasic thing.
Posted: 07:09am 18 Dec 2020
You can add shift-delete = 160 and shift-tab = 159 to the list
As far as I can see, there are 4 undocumented
shift-tab     159
shift-delete  160
shift-down    161
shift-right   163
Numeric keypads are always going to be strange so I have left that alone.
Edited 2020-12-18 17:18 by TassyJim
Posted: 08:37am 18 Dec 2020
  Quote  As far as I can see, there are 4 undocumented
No, only two undocumented - check appendix F. I'll ask Geoff to update with the missing 2
jirsoft
Posted: 09:03am 18 Dec 2020
And 159+160 are my favarites
Jiri
vegipete
Posted: 10:07pm 18 Dec 2020
So all (USB) keyboards are supposed to work this way? Jolly good, I will write my program according to this behaviour.
