Local Time 02:23 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic and string handling with non-integers
vegipete
Posted: 06:28am 19 Dec 2020
Is this the expected behaviour?
> a$ = "123456789"
> print left$(a$,1.4)
1
> print left$(a$,1.5)
12
What is happening, you ask?
The number part of the left$ function is being ROUNDED, not truncated.
This is with a CMM2, although I presume other MMBasic devices do the same.
Comments?
Posted: 06:47am 19 Dec 2020
That is what happens when you get a float to integer conversion.
If you prefer to truncate, use INT or FIX
dim integer x
dim float y
for y = 0 to 2 step 0.1
x = y
print x,y
next y
vegipete
Posted: 07:05am 19 Dec 2020
Okey-dokey. FIX it is.
