Forum Index : Microcontroller and PC projects : CMM2 Floppy Drive, Is it possible?
Page 3 of 3 | |||||
Vampire05 Regular Member Joined: 06/12/2020 Location: GermanyPosts: 88 |
Ok, thank you guys for the information! Today i finished the case for my external CMM2 Floppy Drive: Here some Pics: The next Step is to mount an IDE (40 Pin) Connector on the backside for the CMM2 Connection. Edited 2021-07-28 02:21 by Vampire05 |
Kingeorg Newbie Joined: 28/12/2020 Location: United StatesPosts: 11 |
Wow. That looks ROBUST! |
these wooden panels and aluminuim sheets are the only material i have lying around here. |
Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 5742 |
It won't blow off the table anyway. :) Actually, I think it looks really neat. Your cutting and assembly look very precise. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
Good work Vampire05, It won't be long before we hear the buzzing and sizzling of the floppy.... I remember the excitement when my old Acorn Atom was reading disks with a home-brew disk interface (5 1/4 back then). The 160k back ten was sufficient for 20-50 programs. Good that we have 1.44Mb now with the CMM2. Volhout Edited 2021-07-28 04:38 by Volhout PicomiteVGA PETSCII ROBOTS |
Thank you guys, i will keep you up to date |
hi Guys, i have some problems with the xmodem transfer. here is the full basic file floppy.bas.zip the simple commands(dir, type, dump, rmdir, mkdir) works great but the xmodem command did not. what i do: i open the serial connection open "com1:115200, 256, get_floppy_output, 1" as #1 then i send the arduino dos command: print #1, "receive " + args(2) and then the xmodem send on cmm2: xmodem send "floppy.bas", #1 i tried also xmodem send "floppy.bas",1 xmodem send "floppy.bas" after longer waiting i see the empty file specified in args(2) is created on the floppy drive with the size 0. The cmm2 says "Remote did not respond". Any ideas how i can debug this problem? |
Page 3 of 3 |
