Local Time 16:42 05 May 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 5.06 Basic Play Tone
Mattsaintdev
Posted: 01:57pm 31 Dec 2020
Hi
playing with my cmm2 (at last) and experimented with play tone.
From the prompt something like
> play tone 500,550,1000
gives a 1 second tone on L&R somewhere around middle C
But putting the same line in a .bas file and i hear nothing.
Ive played with "play volume" too. Worth noting that volumes over 85 distort.
Any suggestions, ive looked over the manual.
Matt
johnd
Posted: 02:14pm 31 Dec 2020
That's probably because the program stops immediately after the play statement.  Try putting a "PAUSE 1000" after the play or do something else in the program that takes some time, and you will hear the tone.
I think it does make sense to stop all sound after a program finishes.  That way, programmers don't have to clean up after themselves.  :)
Posted: 02:15pm 31 Dec 2020
  Quote  But putting the same line in a .bas file and i hear nothing.
That's because the program is finishing and that terminates any output. Put PAUSE 2000 after the play tone command
  Quote  Worth noting that volumes over 85 distort.
That is a function of your amplifier input overloading. The output is correct and swings between about 0.1V and 3.1V
Mattsaintdev
Posted: 02:51pm 31 Dec 2020
Ahh thanks, didnt realise it was ASYNC. yes pausing worked.
Just got passive headphones on audio port.
Matt
Posted: 04:07pm 31 Dec 2020
  Quote  Just got passive headphones on audio port.
From the manual
  Quote  This is a 3.5mm stereo phono socket.  The tip is the right channel, the ring is the left channel while the sleeve is ground.  The signal level at full volume is about 1V RMS (approx 3V peak to peak).  The output is high impedance suitable for feeding into an amplifier.  It cannot directly drive a loudspeaker, headphones or any low impedance load and might be damaged if that was attempted.
Edited 2021-01-01 02:12 by matherp
Posted: 09:12pm 31 Dec 2020
Matt
Put 4.7k resistors in series with each output channel.
It will make little difference to the volume level and eliminate the overloading.
RetroJoe
Posted: 09:22pm 31 Dec 2020
The Altoid Amp should also do the trick, and it is a good gadget to have around the house when your iDevice just isn’t putting out enough juice. If you are reading this, the project is almost certain to be within your technical skills!
Enjoy Every Sandwich / Joe P.
