Local Time 20:15 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 right shift is unsigned?
epsilon
Posted: 12:27pm 04 Jan 2021
I was doing some fixed point arithmetic experiments and I noticed that right shift appears to be implemented as an unsigned shift even though the document says it's signed:
Documentation:
These operate in a special way. << means that the value returned
will be the value of x shifted by y bits to the left while >> means the
same only right shifted. They are integer functions and any bits
shifted off are discarded. For a right shift any bits introduced are set
to the value of the top bit (bit 63). For a left shift any bits introduced
are set to zero.
On 5.06 FW:
> PRINT HEX$(&H8000000000000000>>1)
4000000000000000
Is there way to make it signed?
Thanks,
Ruben/Epsilon.
Epsilon CMM2 projects
Posted: 12:46pm 04 Jan 2021
Hi Epsilon,
Normally all shifts are unsigned since they are binary operations. They don't care if the content of a memory location is a character, or an integer number, or a float.
If you want to shift to the right and treat it as a numeric, then you have to do a numeric operation on it. So a divide by 2 replacing the right shift.
jirsoft
Posted: 12:55pm 04 Jan 2021
You can by-self protect the highest bit:
DIM INTEGER a
a = 1 << 63
and then when you need shift right:
DIM INTEGER b = a AND (1 << 63)
a = (a >> 1) OR b
Jiri
Posted: 01:36pm 04 Jan 2021
Sorry didn't see the original post. This is either a manual error or a bug depending on what is preferred. The origin of this is that on the PIC32 all shift right operations on 64-bit numbers are signed - there is no choice even though Geoff's C source asks for unsigned
  Quote  void op_shiftright(void) {
   iret = (long long int)((unsigned long long int)iarg1 >> (long long int)iarg2);
The CMM2 uses the same C source but the STM32 implements it properly so it gives an unsigned answer. I can either change the source to match the documentation or visa-versa
Thoughts?
epsilon
Posted: 01:46pm 04 Jan 2021
  matherp said  I can either change the source to match the documentation or visa-versa
Thoughts?
Although I would prefer a signed shift, since MMBasic integers are signed, correcting the documentation is probably the best option at this point. Changing the source would break compatibility.
In Java >>> is unsigned and >> is signed. Maybe you can do it the other way around in MMBasic? Or maybe add an ASR function?
Posted: 02:12pm 04 Jan 2021
  Quote  In Java >>> is unsigned and >> is signed. Maybe you can do it the other way around in MMBasic?
I can do that - watch for 5.07.00b2
epsilon
Posted: 02:25pm 04 Jan 2021
That's great! Thank you!
