Local Time 03:29 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: MaxiCalc - Spreadsheets!
vegipete
Posted: 01:03am 05 Jan 2021
My oscillator mod a while back made the 1024 x 768 video mode so beautiful and stable that I had to think up something to use the vast screen space.
And the result is ....
Yes, a rudimentary working spreadsheet program!
Why? Well, why not? Bricklin and Frankston wrote the original in 6502 assembly language over the course of a couple of months. I wanted to see what I could quickly do in MMBasic. The result is remarkably usable, which is a testament to the STM32H7 chip and fine programming of Geoff and Peter.
Like Visicalc from 40 odd years ago, now your CMM2 too can enjoy a 63 column wide and 255 row high field of calculations. Built-in MMBasic functions should work in your equations.
Press F1 for the help page.
Error checking is indubitably less robust that it should be but oh well.
Missing at this point is file saving and loading.
Have fun!
MaxiCalc-v06.zip
LeoNicolas
Posted: 02:44am 05 Jan 2021
Amazing Vegipete.
Are you having time to sleep?
Posted: 06:45am 05 Jan 2021
Impressive.
I made one change to line 1034
k$ = ucase$(inkey$)
I don't think the UCASE$() has done any damage and saves me remembering to use shift.
Now you 'just' have to add mouse support.
JohnD
Posted: 01:26am 27 Mar 2021
Very interesting. Is it possible for the cells to read/write the state of digital I/O and is it possible to read an analogue input?
I'm just starting to program the CMM2.
In the days of Microbees I wrote a basic program that was a process control simulator that required the correct P, I and D values to be applied to control a choice of processes with different characteristics.
I'd like to have a layout similar to your spreadsheet to enter/edit the process and controller parameters. I was wondering how to do this using cursor control.
vegipete
Posted: 02:17am 27 Mar 2021
  JohnD said  Very interesting. Is it possible for the cells to read/write the state of digital I/O and is it possible to read an analogue input?
Interesting thought. There is a good chance that that already works. Might need to set pin directions first in the program itself at the very start during initialization.
JohnD
Posted: 02:40am 27 Mar 2021
Thanks for that I'll give it a go. I'll have to check out that I can set or read the pins first.
vegipete
Posted: 04:45am 27 Mar 2021
I doubt outputs will work, but inputs should.
RetroJoe
Posted: 05:44pm 27 Mar 2021
Vegipete, I couldn't help but notice that MaxiCalc hasn't made it onto CMM2 Fun. You would have the "Business" category all to yourself :)
Enjoy Every Sandwich / Joe P.
jirsoft
Posted: 09:53pm 27 Mar 2021
I put it there now...
Jiri
