Local Time 10:46 19 Jul 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : IMAGE ROTATE
     Page 3 of 4
Posted: 12:46pm 10 Jan 2021
You need to write a bigger area to the colour you want where you are going to output the text. The rotate is rotating an area that includes not just the text but the other junk as well. This is just a simple programming bug
lew247
Posted: 01:22pm 10 Jan 2021
Thanks, I'll try and work that out :)
lew247
Posted: 01:46pm 10 Jan 2021
I'm trying to get my head around this
IMAGE ROTATEx, y, width, height, new_x, new_y, angle!, remove black triangle artifact
Text 10,10,"NE"
Image rotate 6,4,30,30, new_x, new_y, angle!
that means it's picking up a rectangle 30 x 30 with the word NE in it?
Then rotating that by angle and placing it in the new position?
That's why it's using the grey colour instead of the blue because at the original location the colour is grey
Yet when I do Text 540,110,"NE" so it picks up the correct colour it Still prints a blank box with the grey colour
If I experiment and try and do as you say and use larger area to write to it just makes the grey boxes larger
It's possibly because I can't get my head around "exactly" what it's doing
Posted: 02:11pm 10 Jan 2021
  Quote  Yet when I do Text 540,110,"NE" so it picks up the correct colour it Still prints a blank box with the grey colour
Because you haven't changed the address where the rotate is sourcing the data
USE the BOX command to write a blue box at 0,0. Then use the original code. Once the rotates are done Rewrite the blue box to grey
You can see the effect with the attached
Option explicit
CLS RGB(gray)
Box 0,0,50,50,0,RGB(134,174,230),RGB(134,174,230)
Dim cx% = 785
Dim cy% = 238
Dim wid% = 105
Dim ang! = 0.087266463
Dim rad90! = 1.570796327  '90 degrees in radians
compass_rose 625,475,75
Sub compass_rose cx%,cy%,wid%
Local a%
Text cx%+9,cy%+15-(wid%+22),"N",L,4,,RGB(1,1,1),RGB(134,174,230)
Text cx%+9,cy%+15+(wid%+5),"S",L,4,,RGB(1,1,1),RGB(134,174,230)
Text cx%+wid%+18,cy%+4,"E",L,4,,RGB(1,1,1),RGB(134,174,230)
Text cx%-(wid%+5),cy%+4,"W",L,4,,RGB(1,1,1),RGB(134,174,230)
Text 10,10,"NE",L,7,,RGB(1,1,1),RGB(134,174,230)
Image rotate 6,4,30,30,cx%+(wid%-16)*Cos(.785),cy%-(wid%-16)*Cos(.785),45,1
Text 10,10,"SE",L,7,,RGB(1,1,1),RGB(134,174,230)
Image rotate 6,4,30,30,cx%+(wid%-16)*Cos(.785),cy%+(wid%-16)*Cos(.785),135,1
Text 10,10,"SW",L,7,,RGB(1,1,1),RGB(134,174,230)
Image rotate 6,4,30,30,cx%-(wid%-16)*Cos(.785),cy%+(wid%-16)*Cos(.785),225,1
Text 10,10,"NW",L,7,,RGB(1,1,1),RGB(134,174,230)
Image rotate 6,4,29,29,cx%-(wid%-16)*Cos(.785),cy%-(wid%-16)*Cos(.785),315,1
Text 10,10,"  ",L,7,,RGB(134,174,230),RGB(134,174,230) ' clear text
' tick marks, every 5 degrees (360/5 = 72)
For a% = 0 To 71
  Line (cx%+15)+(Cos(a%*ang!)*(wid%-4)),(cy%+15)-(Sin(a%*ang!)*(wid%-4)),(cx%+15)+(Cos(a%*ang!)*(wid%+1)),(cy%+15)-(Sin(a%*ang!)*(wid%+1)),,RGB(WHITE)
Next
' compass perimiter
Circle cx%+15,cy%+15,wid%
Circle cx%+15,cy%+15,wid%-4
End Sub
lew247
Posted: 02:21pm 10 Jan 2021
Thank you, that works perfectly
I don't get why it needed the box but I'll work on it and try and figure that out myself
btw that other error I mentioned is still happening, I've narrowed it down to one section of code
SUB Forecast
LONGSTRING PRINT c()
conditions$ = JSON$(c(),"current_conditions.conditions")
print conditions$
I actually thought it would do the longstring print before it went on to the JSON$
edit: if I type run straight away it then runs fine till the next time, I suspect it might be something wrong in the data being received so I'm going to do the longstring print straight after wget and see how that goes
Edited 2021-01-11 00:22 by lew247
lew247
Posted: 02:32pm 10 Jan 2021
I thought it might be the buffer for c() wasn't large enough and was not getting the end }}, I had it at 15000
I then counted the characters received and there was 93885, it should have been enough but I've upped it to 16K just in case
Posted: 03:05pm 10 Jan 2021
Maybe add a delay after each line to make sure any print buffering has finished.
Posted: 07:35pm 10 Jan 2021
Lewis
Please try the attached and see if it makes the crashing better or worse
mmbasic.zip
lew247
Posted: 07:47pm 10 Jan 2021
Sorry Peter, it crashed again first time I pressed run
I deleted the old mmbasic, and .options
transferred this version and got this immediately
Edit:
Without doing anything else I pressed run and it ran, same as before
btw it was around secs = 17 when I pressed run the first time so it shouldn't have tried to get the JSON data
Edited 2021-01-11 05:49 by lew247
lew247
Posted: 07:51pm 10 Jan 2021
Edit 2
After it collected the data It came up with this
Posted: 10:40pm 10 Jan 2021
Ok - that's useful. It looks like the json you are trying to load is simply too big and/or complex for the parser. Nothing I can do about it I'm afraid
lew247
Posted: 10:02am 11 Jan 2021
I really hate to disagree with such an expert but I have to with this.
The Pi and Picromite is definitely able to handle the data and parsing.
The old version 5.05.01 worked perfectly for days with no issues, the only thing wrong was Blit and image rotate didn't work
Blit I discovered was my fault because I didn't know it had been changed to three parameters and not 4
I checked this by loading it up again and running it overnight, over 12 hours so far with no crashes
The only thing missing was Image rotate
This version worked best out of all the ones you did yesterday, it ran for several hours before crashing and throwing this error
If I close the terminal and do screen -D -r it goes back to the error and won't do anything until I close the terminal again
The only way to gain control of the Pi again is close the terminal, log back in and reboot.
However, thank you so so much for trying :)
I can get away without the image rotate function by using miniature images with the words inside rotated to the correct angle.
Posted: 08:37am 13 Jan 2021
Lewis
Please could you try the attached. I've updated the JSON parser to the latest version. This includes bug fixes of both memory leaks and buffer overflow conditions that may relate to the issues you are seeing. I've run it on a simple test program for an extended period without issue
mmbasic.zip
lew247
Posted: 08:52am 13 Jan 2021
running it now, using the latest version of Stretch lite available, and updated fully and the latest pigpio
lew247
Posted: 11:17am 13 Jan 2021
Peter it's working perfectly for over 2 hours so far.
It did crash the very first time I press run but it was also a new install of the latest Stretch, Pigpio and python3-distutils on a clean SD card.
I took a screenshot in case it's any help
I also tried it on a new install on a clean SD card with the latest Pi OS lite on my Pi 4 but it didn't run
pi@Pi4:~ $ sudo ./mmbasic
./mmbasic: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory
Edited 2021-01-13 21:58 by lew247
lew247
Posted: 11:54am 13 Jan 2021
I spoke too soon
it crashed after almost 3 hours
Posted: 12:04pm 13 Jan 2021
Please run it on the version of stretch that you posted - any upgrades are likely to break it - this is exactly the problem with the whole Pi infrastructure
lew247
Posted: 12:15pm 13 Jan 2021
ok will do
it will take a moment to load it again
original version of pigpio as well?
Posted: 01:02pm 13 Jan 2021
  Quote  original version of pigpio as well?
Definitely - this is even more important
lew247
Ran beautifully first time
yock1960 if you see this I sent you a pm
     Page 3 of 4
© JAQ Software 2025
