Local Time 18:05 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : FW for ESP on CMM2 (deluxe)
jirsoft
Posted: 04:20pm 17 Jan 2021
as part of Napoleon Commander need, I have written new firmware for ESP8266 connected to the serial port on CMM2, CMM2ESP. It can all serial functions needed for NC and already few things usable in general:
@datetime
 gets date and time in format yyyy-mm-dd hh:mm:ss
@ver
 gets version of this firmware
@mac
 gets MAC address of WiFi
@netinfo
 gets info about connection to AP in format SSID, BSSID, RSI, gateway IP, network mask, own IP
 needs to be connected
@scan
 scans WiFi networks and returns:
 number of networks found (n)
 for every network number (0...n-1), SSID, BSSID, RSI
 doesn't need to be connected
@disconnect
 disconnects from current AP
 returns info Disconnected
@connect(SSID, password)
 connect to AP
 returns info Connected to SSID, BSSID, RSI
@httpget(url|split)
 split is not mandatory, default split is 250 characters
 send HTTP GET request to server
 returns HTTPGET url|number of batches (n) and then n times split characters with answer
 SEND @httpget(scooterlabs.com/echo?ip)
 HTTPGET http://scooterlabs.com/echo?ip|1, follows just 1 packet (used default split is 250 characters)
 1.2.3.4
 SEND @httpget(scooterlabs.com/echo?ip|3)
 HTTPGET http://scooterlabs.com/echo?ip|3, follow 3 packets (split was set to 3 characters per batch)
 1.2
 .3.
 4
Jiri
Posted: 09:01pm 17 Jan 2021
The one 'must have' command from the ZIMODEM is
  Quote  ATD"[HOSTNAME]:[PORT]" : This opens a streaming connection between the terminal and the given host/port. Use "+++" to disconnect and exit back to command mode.
jirsoft
Posted: 09:46pm 17 Jan 2021
  TassyJim said  The one 'must have' command from the ZIMODEM is
OK, thanks. I will take look on it...
Jiri
