Forum Index : Microcontroller and PC projects : CMM2: V5.07.00b6 - program profiling
Please download and try V5.07.00b6 http://geoffg.net/Downloads/Maximite/CMM2_Beta.zip This has the following changes: MODE 12 reverts to the original 960x540 where lines are duplicated in memory and the monitor sees 1920x1080 @ 60HZ A new mode 14 is introduced which has the timings for 540P, still 960x540 but with no line duplication. If your monitor can handle it this is the best default mode for a widescreen monitor The big change in this beta is a: Program profiling capability To turn on or off the profiling use OPTION PROFILING ON OPTION PROFILING OFF This is a permanent option but it defaults to OFF whenever new firmware is loaded. With profiling on you will see a performance impact of about 5% caused by the profiling data collection which happens at the MMBasic statement level. In addition you will see a reduction in available variable RAM of 512KB. Note that profiling and OPTION RAM are mutually incompatible. With profiling enabled you can run your programs as usual and you should see no change in behaviour other than as mentioned above. You can see the way the program has run using the commands ![]() Some sample output is displayed above. There are 5 comma-separated fields in the output The first field is the number of times a given statement has been run The second field is the average time in Microseconds taken to execute the statement The third field is the crunched statement as stored in memory. This is quoted to make it easier to load into excel etc. The fourth field is the filename in which the statement appears. This is blank if the statement is in the main program, otherwise it gives the filename of the include file in which the statement is to be found The fifth and final field gives the line number of the statement in the source file. When LIST PROFILE CSV is used a file is created in the same directory as the main program with the .BAS extension replaced with .CSV LIST PROFILE can only be used at the command line LIST PROFILE CSV can be used in a program allowing you to create and rename multiple files while a program is running if required A program can test if OPTION PROFILING is enabled using MM.INFO$(OPTION PROFILING) This returns a string "On" or "Off" Edited 2021-01-22 22:05 by matherp |
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
Wow ! Thank you Matherp Plasma |
Hi Peter, can be tested also MMDEBUG (MM.INFO$(OPTION MMDEBUG) = "On|Off")? Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), CMM2.fun |
| RetroJoe Senior Member Joined: 06/08/2020 Location: CanadaPosts: 290 |
![]() Thanks, Peter - feels like a beta flashing weekend coming up :) Enjoy Every Sandwich / Joe P. |
The question doesn't really make sense. #MMDEBUG is a pre-processor directive. If the state of the directive is OFF lines starting MMDEBUG are not loaded into memory. There is no run-time status associated with MMDEBUG. The MMDEBUG commands are either loaded into memory or not. If they are they execute. If not they don't exist as far as the run-time is concerned |
The reason is, that MMDEBUG suports just simple PRINT and BREAK (still very valuable !!!), so at least such a way I can with help of condition do some other things (fox example calculate and prepare statements for debug output, which I will not use in production) I know here will be some time penalty for doing it so and for sure better will be if MMDEBUG statement could be used as prefix for any line and when #MMDEBUG will be OFF, these lines will be not included into crunched prg... Edited 2021-01-23 03:04 by jirsoft Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), CMM2.fun |
You can do this with #DEFINE e.g. #DEFINE "MYDEBUG","" '#DEFINE "MYDEBUG","REM " MYDEBUG print "hello" Just uncomment the appropriate #DEFINE line depending on whether you want the line to run or not Edited 2021-01-23 04:44 by matherp |
Thanks Peter, it's simply perfect, this solves my problem and has not speed penalty! I need to re-read documentation... Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), CMM2.fun |
Profiling is unreliable immediately after an AUTOSAVE Using your simple example code I first did an AUTOSAVE then <F2> to re run the program. I also tried NEW before the AUTOSAVE but still not correct. Every time I do subsequent runs with <F2> seem to be consistent. > AUTOSAVE "temp.bas" sub foobar() local j% j% = 0 print j% inc j% print j% end sub a=8 inc a inc a inc a foobar print a print 'Hello World" b=2 a=1 inc a a = a+10 b=b\100 for i = 1 to 10 page copy 0 to 1 next i list profile csv end 0 1 11 > list profile /temp.bas 2, 1.5, "Sub FOOBAR()",,1 2, 2.5, "Local J%",,2 1, 2.0, "J% =0",,3 2, 513.5, "Print J%",,4 1, 3.0, "Inc J%",,5 12, 84.7, "Print J%",,6 1, 1.0, "End Sub ",,7 1, 4.0, "A=8",,9 1, 2.0, "Inc A",,10 1, 1.0, "Inc A",,11 1, 1.0, "Inc A",,12 1, 7.0, "FOOBAR",,13 1, 1035.0, "Print A",,14 1, 1009.0, "Print ",,15 5, 0.6, "B=2",,16 1, 3.0, "A=1",,17 1, 1.0, "Inc A",,18 1, 4.0, "A =A+10",,19 1, 4.0, "B=B\100",,20 1, 6.0, "For I =1 To 10",,21 10, 2062.2, "Page COPY 0 To 1",,22 493, 0.0, "Next I",,23 18, 2001.2, "List PROFILE CSV",,24 0, 0.0, "End ",,25 > RUN 0 1 11 > list profile /temp.bas 1, 2.0, "Sub FOOBAR()",,1 1, 4.0, "Local J%",,2 1, 2.0, "J% =0",,3 1, 20.0, "Print J%",,4 1, 2.0, "Inc J%",,5 1, 17.0, "Print J%",,6 1, 1.0, "End Sub ",,7 1, 4.0, "A=8",,9 1, 2.0, "Inc A",,10 1, 1.0, "Inc A",,11 1, 1.0, "Inc A",,12 1, 7.0, "FOOBAR",,13 1, 1046.0, "Print A",,14 1, 1002.0, "Print ",,15 1, 4.0, "B=2",,16 1, 2.0, "A=1",,17 1, 1.0, "Inc A",,18 1, 4.0, "A =A+10",,19 1, 4.0, "B=B\100",,20 1, 6.0, "For I =1 To 10",,21 10, 2062.2, "Page COPY 0 To 1",,22 10, 1.2, "Next I",,23 1, 27072.0, "List PROFILE CSV",,24 1, 4.0, "End ",,25 > This one is also directly after an AUTOSAVE: > list profile /temp.bas 2, 2.0, "Sub FOOBAR()",,1 2, 4.0, "Local J%",,2 2, 2.0, "J% =0",,3 2, 522.0, "Print J%",,4 2, 2.0, "Inc J%",,5 2, 518.5, "Print J%",,6 2, 1.0, "End Sub ",,7 2, 4.0, "A=8",,9 2, 2.0, "Inc A",,10 2, 1.0, "Inc A",,11 2, 1.0, "Inc A",,12 2, 7.0, "FOOBAR",,13 2, 1039.5, "Print A",,14 2, 1002.5, "Print ",,15 2, 3.5, "B=2",,16 2, 2.0, "A=1",,17 2, 1.0, "Inc A",,18 2, 4.0, "A =A+10",,19 2, 4.0, "B=B\100",,20 2, 6.0, "For I =1 To 10",,21 20, 2062.3, "Page COPY 0 To 1",,22 20, 1.1, "Next I",,23 2, 27015.5, "List PROFILE CSV",,24 2, 37262886.0, "End ",,25 > Jim VK7JH MMedit |
The profiling buffer is cleared by the RUN command. Autosave doesn't use the run command so I need to add the clear to AUTOSAVE. In the meantime exit AUTOSAVE with F1 and then type RUN UPDATE V5.07.00b7 updated and re-uploaded Edited 2021-01-25 19:24 by matherp |
Working now with two exceptions. The time for the END statement is ridiculously long for a run started with AUTOSAVE. Everything else looks right. 1, 6061.0, "CLS ",,262 1, 2.0, "Page WRITE 0",,263 1, 109271.0, "Mode 1,8",,264 1, 468.0, "CLS ",,265 1, 7.0, "If MOUSE_PORT >=0 Then",,266 1, 6156.0, "Controller MOUSE CLOSE MOUSE_PORT",,267 1, 1.0, "GUI CURSOR OFF",,268 1, 0.0, "EndIf ",,269 1, 133000785.0, "End ",,270 1, 6057.0, "CLS ",,262 1, 2.0, "Page WRITE 0",,263 1, 106496.0, "Mode 1,8",,264 1, 462.0, "CLS ",,265 1, 7.0, "If MOUSE_PORT >=0 Then",,266 1, 5942.0, "Controller MOUSE CLOSE MOUSE_PORT",,267 1, 1.0, "GUI CURSOR OFF",,268 1, 0.0, "EndIf ",,269 1, 4.0, "End ",,270 The other issue is more serious. If I turn profiling on and immediately try a AUTOSAVE, the system hangs at the conclusion of the AUTOSAVE and before the start of the program If I do any program run before using AUTOSAVE, everything works. It seems to happen with any program. Jim Edit: Make that 3 issues. Entering LIST PROFILE at the command prompt before any code has been run, results in a system lockup. Edited 2021-01-26 12:09 by TassyJim VK7JH MMedit |
