mclout999 Guru Joined: 05/07/2020 Location: United StatesPosts: 417
Posted: 01:23pm 09 Aug 2021
Thank you that was the info I needed. It works fine now. I had no idea. I was misinterpreting the info from the first post here.
You need to substitute your own wifi login details and your own openweathermap api username and key
I was putting my user name in there. Thanks.
On to my next bit of needed info on your second listing. It runs and then says connected. Then what do I need to do to access it. I am trying to find what IP it has taken but my router is not showing me anything but several ESP listings with no IPs. Do we need anything else? I tried to add a line after connected that would list the IP but no go
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 7739
Posted: 02:08pm 09 Aug 2021
open "com2:115200,4096" as #1 IF NOT Command(0, "AT",obuff(), 500) THEN END IF NOT Command(0, "AT+RST",obuff(), 10000,"WIFI GOT IP") THEN 'reset and check for valid connection PRINT "Set up WIFI on SSID: ",SSID$ IF NOT Command(0, "AT+CWMODE_DEF=1",obuff(), 5000) THEN END 'set device mode (1=client, 2=AP, 3=b IF NOT Command(0, "AT+CWLAP",obuff(), 30000) THEN END 'scan for WiFi hotspots longstring print inbuf() 'output the list of valid networks IF NOT Command(0, "AT+CWJAP_DEF="+SSID$+","+SSIDPassword$,obuff(), 20000,"WIFI GOT IP") THEN END IF NOT Command(0, "AT+CIFSR",obuff(), 5000) THEN END 'check IP address ENDIF print #1,"AT+CIFSR"+chr$(13)+chr$(10); pause 500 print input$(100,1)
IF NOT Command(0, "AT+CIPMUX=1",obuff(), 5000) THEN END IF NOT Command(0, "AT+CIPSERVER=1,80",obuff(), 5000) THEN END Print "Connected"
toml_12953 Guru Joined: 13/02/2015 Location: United StatesPosts: 314
Posted: 03:02pm 09 Aug 2021
I'm not getting a response to CIPSTART today from api.openweathermap.org so can't help. Perhaps they have an issue or have changed something - anyone got anything working with openweathermap?
Today I'm having a CIPSEND issue. Has anyone figured out what's happening? Edited 2021-08-10 01:10 by toml_12953
Posted: 07:50pm 09 Aug 2021
matherp posted how he fixed it and it workded for me as well.
UPDATE - did a AT+RESTORE on the ESP and now working with the posted code Edited 2021-08-09 01:29 by matherp
I edited an earlier posted program that printed out the version to just send that command to the ESP01.
Posted: 07:57pm 09 Aug 2021
matherp, Thank you for the update. It works flawlessly.
Posted: 06:37am 23 Sep 2022
V5.07.00b11 now available for download
This release also supports a json parsing function.
Examples taken from api.openweathermap.org
I used to be able to run this weather station program but now I bomb out at
AT+CIPSEND
every time. This means I can log onto my network and connect to the openweathermap website but then it gets hung up somehow. Has something changed since this was first written?
Posted: 10:51am 23 Sep 2022
Just tested and works fine for me. Check version of the ESP
Posted: 02:20pm 23 Sep 2022
Thanks for checking! It's V 1.7.4 Edited 2022-09-24 02:35 by toml_12953
