Forum Index : Microcontroller and PC projects : CMM2: in some circumstance ERROR is not printing the context
Posted: 10:12am 31 Jan 2021
Good morning Peter,
Suspect this is long-standing and possibly one for Geoff, but anyway here goes:
400MHz Colour Maximite 2
MMBasic Version 5.07.00b11
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> list "error-bug.bas"
Dim s$ = "foo"
Select Case s$
 Case "foo" : Error "foo"
 Case Else : Print "bar"
End Select
End
> run "error-bug.bas"
foo
... edit the file to:
Dim s$ = "foo"
Select Case s$
 Case "foo"
   Error "foo"
End Select
End
> run "error-bug.bas"
Error in line 4: foo
As you can see you get the "Error in line X:" prefix in the second version, but not in the first.
Posted: 12:30pm 31 Jan 2021
Thanks - I'll put it in the known bugs file and given the limited use and severity and easy workround it will get fixed one day/never
