Local Time 02:25 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : An attempt to port ChemiChaos to the Armmite F4.
Posted: 06:59pm 31 Jan 2021
I thought it might be fun to try to port vegipete's excellent ChemiChaos to the Armmite F4 (which, to my mind, remains the best and least expensive of the all-in-one ports of MMBasic (though lacking in the graphics capabilities of the CMM2)).
For those not familiar, the F4 is based on a STM32F407VET6 board , includes USB programming, an RTC, a micro SD socket, a winbond flash chip, and a high-speed, 16-bit LCD interface. Board and LCD can be had for around $25US. Larger LCDs up to 7 or even 9 inches are possible.
I've never written a game, and prior to CMM2 had not played one since arcade Pac-Man and Space Invaders on a Xerox Alto/Bravo in the early 80s. So it would be a learning experience.
I downsized Pete's "ChemiChaosSprites.png" file to a 320 pixel width, keeping the aspect ratio, and turned it into a bmp file. Downloaded with XMODEM RECEIVE and then LOAD IMAGE "ChemiChaosSprites320b.bmp". So far, so good.
(Note: the LCD is crisp compared to this photo.)
I cleared some space on that image and did some BLITs:
box 180,0,140,240,0,rgb(black),rgb(black)
blit 27,0,250,0,46,120
blit 0,0,259,10,26,26: blit 0,26,259,36,26,26: blit 0,104,259,62,26,26: blit 0,156,259,88,26,26
Again excellant.
There is no F4 manual, so documentation of the commands chain back to the Armmite H7 manual, the Micromite Plus, and the original Micromite manual. The H7 says "The BLIT and SPRITE commands can be used interchangeably. All Micromite Plus functionality is preserved with minor functional changes."
However, for the F4, SPRITE 27,0,250,0,46,120 yields "Error: Unknown command", so BLIT it is, and as far as I can tell, only the Micromite Plus commands.
BLIT READ #1,0,0,26,26: BLIT READ #2,0,26,26,26: BLIT READ #3,0,52,26,26: BLIT READ #4,0,78,26,26
The above works to save 26x26-pixel bit areas into 4 numbered buffers (sprites?!). It turns out because of the resizing, some of the balls are 26 pixels high and some are 25.
After fiddling, I am able to make 9 BLIT buffers (7 balls, one arrow, one test tube. Then I can produce this:
Here's the code.
Dim integer lx%,ly%, li%,lj%,lK%
Load IMAGE "ChemiChaosSprites320b.bmp"
On error skip
Blit CLOSE #1:Blit CLOSE #2:Blit CLOSE #3:Blit CLOSE #4:Blit CLOSE #5
Blit CLOSE #6:Blit CLOSE #7:Blit CLOSE #8:Blit CLOSE #9
Blit READ #1,0,0,26,26: Blit READ #2,0,25,26,26: Blit READ #3,0,51,26,26
Blit READ #4,0,76,26,26: Blit READ #5,0,102,26,26
Blit READ #6,0,127,26,26: Blit READ #7,0,152,26,26
Blit READ #8,26,126,26,26
Blit READ #9,27,0,46,120
CLS RGB(white)
ly%=100: lx%=20
For li%=1 To 6
 Blit WRITE #9,lx%,ly%,46,120
 Blit WRITE li%,lx%+9,ly%+90,26,26
 lx%=lx%+46
Next li%
lx%=29
For li%=1 To 6
 ly%=110
 For lj%=1 To 3
   lk%=Rnd()*6+1
   Blit WRITE lk%,lx%,ly%,26,26
   ly%=ly%+26
 Next lj%
 lx%=lx%+46
Next li%
Blit WRITE #8,75,70,26,26
Do : Loop
The images aren't perfect, but should be good enough so that I can try to start in on Pete's game code. I still need to produce a down arrow (probably on the PC), since I can't see that there is a way to rotate the BLIT buffer.
RetroJoe
Posted: 07:16pm 31 Jan 2021
Wow! Tres cool !!
Enjoy Every Sandwich / Joe P.
Posted: 06:44pm 01 Feb 2021
Success. ChemiChaos on youtube.
My porting method was brute force. After setting up the 12 sprites (blit buffers) and changing the text to be output with the TEXT command, I simply ran the program on the F4 until it crashed, usually at a BLIT command with invalid parameters or a SPRITE command. I then fixed that and ran until the next "Invalid syntax".
I made most changes on the PC and did "XMODEM R "ccf4.bas", but if the change was simple (a value or a statement or two) I used the MMBasic editor (and also made the change on the PC). I probably used XMODEM R 50 times or more.
I tried to make it so it would run on either the CMM2 or Armmite F4. I set up a variable, cputype%, initialized it to 0 for CMM2, and checked for mm.device$="ARMmite F407" to set it to 4. Then at each necessary point, I checked cputype% and executed either CMM2 or F4 code. I have not yet gone back to see if the code works on the CMM2.
As I expected, except for the graphics parts, vegipete's game code just worked. They may be some exceptions I haven't tested yet. The bottoms of the balls (black) are transparent on the CMM2. I saw some suggestion that transparency might work on some LCDs, but didn't investigate when it didn't on this 320x240 model.
I didn't make allowance for the 480x272 or 800x600 LCDs which can be fitted (with an adaptor) to the F4--I just plugged in magic numbers for the 320x240. I may fix that later.
Code is attached, along with the ChemiChaos320b.bmp file.
Thanks, Pete, for the fine and fun code example.
ChemiChaosF4.zip
Posted: 03:22am 02 Feb 2021
Playing through to the end revealed a few more bugs.
I shifted the vials left, but the 7th one shows up distorted. The balls appear correctly, though. For the games which have an 8th and 9th vial, they are off the edge of the screen, but the program handles them properly and you can complete the round.
Among the non-graphics things I had to change because the CMM2 commands are not supported by the F4 were MATH SCALE and MOD$ on the left of the "=" sign.
ChemiChaosF4.zip
Chopperp
Posted: 01:18pm 03 Feb 2021
FYI
ChemiChaos screen grab on an F4 with 7" display stuck at Level 6.7
Only taking up about half the screen at this stage. More work to be done.
This would not be compatible with the CMM2 without further changes. Just playing at this stage. I didn't try to resize any of the graphics.
A number of changes done to lizby's great effort to get to this stage.
The Keystrokes table was off screen & had to be moved up. It then got partially erased in use after "Safe" came up & a key hit.
I could not work out why so I eventually modified the ShowCounts & ToggleCounts routines to refresh the table & still make it selectable On/Off.
The Level indicator was changed to a fixed text & relocated as the original moved down the screen if the "R" key was pressed.
Not sure where the spurious down arrow came from.
Thanks again vegipete for the great game.
Brian
ChopperP
Posted: 02:51pm 03 Feb 2021
Chopperp--good work carrying on. As you saw, I didn't implement any display of the statistics.
That round you're showing is the most difficult one. It took me 6 or 7 retries to solve it.
vegipete
Posted: 07:01am 04 Feb 2021
Nice work you guys!
I'm glad my program is providing you with entertainment, and is written cleanly enough that you can figure out how to attack it and modify it and bend it to your will.
Awesome!
Posted: 07:29pm 23 Apr 2021
ChemiChaos on the F4 with the IPS/OTM8009A 800x489 LCD. Couldn't use the code posted above because the F4 does not have enough memory to BLIT WRITE all the balls and other graphics, so the balls are just filled circles:
F4 on Fruit of the Shed
   'OPTION EXPLICIT  ' all variables must be defined before use - HAH! Bite me.
   ' ChemiChaos
   ' by vegipete, December 2020
   ' required support files (place in same directory):
   ' CCRedHand.spr
   ' Sort the Chemical Balls in the Test Tubes
   ' Move with the arrow keys
   ' Pick and place with the space bar
   ' Restart level with R  (upper or lower case for letter commands)
   ' Toggle stats with C
   ' Quit with Esc
   ' Replace picked up ball with Z (undocumented)
   '   v 1.2   Mouse improvements, more levels, key press & mouse click counting
   '   v 1.1   Mouse control, change to level numbering
   '   v 1.0   Original release, graphics tweaks, more levels + counter, intro text
   '   v <     development
   'option console screen
   dim cputype%=0, f4%=4, cmm2%=0, ls$, ipsFlag%=0
   if MM.Device$="ARMmite F407" then cputype%=f4%
   if cputype%=f4% then ' armmite F4
     dim integer clr(9)
     clr(0)=rgb(red): clr(1)=rgb(green): clr(2)=rgb(blue): clr(3)=rgb(Yellow)
     clr(4)=rgb(cyan): clr(5)=rgb(magenta): clr(6)=rgb(brown): clr(7)=rgb(white)
     clr(8)=rgb(gray): clr(9)=rgb(black)
     dim integer i,j,k,l,xm,n,x,y,x2,y2,x3,y3
     dim integer cR=0,cG=1,cB=2,cY=3,cC=4,cM=5,cO=6,cW=7,cGR=8,cBK=9
     dim integer BLK=clr(cBK)
     dim integer ballRad=33
     const UPARROW=1,DOWNARROW=0
     cls
     F4_setup ' establish 12 sprites (blit buffers #1-12)
   else ' CMM2
     mode 1,16   ' more colours for better ball shading
   endif
   dim keypress
   dim fname$
   dim levelnum
   dim movingball
   dim vials(9,4)     ' 9 vials, each can hold 4 balls
   dim vialsbak(9,4)  ' 9 vials, restore copy
   dim ballcols(6) = (0,1,2,3,4,5,6) ' allow shuffling of ball colours
   dim m$,a$
   dim integer movecount(8)
   dim countvisible = 0
   if cputype%=cmm2% then ' CMM2
     sp = 1    ' sprite page
     page write sp : cls
     load png "ChemiChaosSprites.png"
     sprite read 1,36,180,36,36,sp    ' up arrow
     open "CCRedHand.spr" for random as #1
     seek #1, 324
     movecount(7) = val(input$(12,#1))
     seek #1, 342
     movecount(8) = val(input$(12,#1))
     close #1
    gui cursor load "CCRedHand.spr"
     mport = mm.info(option mouse) + 1
     if mport then
       controller mouse open mport-1, LeftClick
       gui cursor on 2
       settick 50, PeriodInt   ' periodic interrupt to move mouse pointer
     else    ' no mouse set so try find one
       mport = 4
       do
         on error skip
         if MM.ERRNO then
           mport = mport - 1
         else
           gui cursor on 2
           exit do
         endif
       loop until mport = 0  ' no mouse found anywhere
     endif
     pause 1000    ' screen sync time
     page write 0 : cls rgb(white)
   endif
   levels = 1
   levelnum = 0
   levelball = 0
   restore gamelevels
   ShuffleBCols
   xpos = 1
   gameover = 0
   handx = MM.HRES/2
   handy = MM.VRES/2
   newclick = 0
   charx = 245 : chary = 10
   if mport then gui cursor hide
   PutString("CHEMICAL CHAOS")
   if cputype%=CMM2% then
     line 240,37,545,37,4,0
     text 565,20,"v1.2 by vegipete, Jan 2021","LT",1,1,0,rgb(white)
   else
     if ipsFlag% then: font 4: else: font 2: endif
     ls$="v1.3 by vegipete, Jan 2021 (F4 by lizby)"
     ly%=mm.fontheight+2
     lx%=mm.hres/2 - len(ls$)/2*mm.fontwidth
     text lx%,ly%,ls$,,,,,rgb(black),rgb(white)
     ly%=ly%+mm.fontheight+2
     putstring("")
   endif
   charx = 0 : chary = 50
   '          12345678901234567890123456789012345678
   PutString("There is chaos and confusion all")
   charx = 0 : chary = chary + 30
   PutString("through the chemistry lab! The")
   PutString("chemicals have been mixed. Your task")
   PutString("is to combat the chaos and restore")
   PutString("order by sorting the chemicals.")
   PutString("Move the coloured balls one by one")
   PutString("until each test tube contains a single")
   PutString("colour. However, you can not drop a")
   PutString("ball on a different coloured one!")
   PutString("Use the arrow keys to move. Select and")
   PutString("drop with the space bar. Press R to")
   PutString("restart if you get stuck.")
   charx = 0 : chary = chary + 55
   PutString("Press Esc to quit and call HazMat.")
   text 30,470,"Press 'C' to toggle stats.","LT",4,1,0,-1
   ' add some colour to the info screen
     blit 0,0*36, 20,560,36,36,sp,4 ' coloured ball
     blit 0,1*36,175, 10,36,36,sp,4 ' coloured ball
     blit 0,2*36,685, 70,36,36,sp,4 ' coloured ball
     blit 0,3*36,750,185,36,36,sp,4 ' coloured ball
     blit 0,4*36, 70,405,36,36,sp,4 ' coloured ball
     blit 0,5*36,540,380,36,36,sp,4 ' coloured ball
     blit 0,6*36,620,500,36,36,sp,4 ' coloured ball
     if mport then gui cursor show
     pause 500
   else
     if ipsFlag% then
       circle ballRad,ballRad,ballRad,2,,clr(cBK),clr(0) ' red
       circle 760,ballRad,ballRad,2,,clr(cBK),clr(2) ' blue
       circle 650,120,ballRad,2,,clr(cBK),clr(3) ' yellow
       circle ballRad*2,440,ballRad,2,,clr(cBK),clr(6) ' orange
       circle 600,380,ballRad,2,,clr(cBK),clr(5) ' magenta
     else
       blit write #1,10,1,26,26
       blit write #3,290,1,26,26
       blit write #4,280,79,26,26
       blit write #7,10,215,26,26
       blit write #6,288,210,26,26
     endif
   endif
   charx = 0 : chary = 500
   PutString("Press a key to begin...")
   do while inkey$ <> "" : loop    ' clear any key presses
   do : loop until (inkey$ <> "") or newclick    ' wait for key press
   newclick = 0
   cls rgb(white)
   if ipsFlag% then: blit read #13,0,132,85,66: endif
   else
     if ipsFlag% then: font 2: else: font 7: endif
     ly%=mm.fontheight+2
   endif
   movecount(1) = 0  ' total keypress this run
   movecount(4) = 0
   do
     if MixVials() = 0 then exit do  ' no more levels
     ShowLevel
     movecount(2) = 0  ' total keypress this level
     movecount(3) = 0  ' total keypress this attempt
     movecount(5) = 0
     movecount(6) = 0
     ShowCounts
     do
       i = GetBall()
       if i then PutBall(i)
       if TestDone() then exit do  ' this level has been defused
       if gameover then exit do    ' player quit
     loop
     if cputype%=CMM2% then sprite hide 1
     ShowSafe
     ShuffleBCols
     levels = levels + 1
     do : loop until (inkey$ <> "") or newclick ' wait for keypress
     do : loop until inkey$ = ""   ' clear any keypresses
     newclick = 0
     xpos=1
       box 0,42,mm.hres,mm.vres-42,0,rgb(white),rgb(white)
       DrawArrow(xpos,UPARROW)
       ly%=42 ' where "Level #" will be printed
     endif
   loop
   if mport then
     settick 0, PeriodInt
     controller mouse close mport-1
     pause 20
   endif
   seek #1, 324
   print #1, left$(str$(movecount(7)) + space$(15), 12);
   seek #1, 342
   print #1, left$(str$(movecount(8)) + space$(15), 12);
   close #1
   if mport then gui cursor off
   charx = 20
   chary = 400
   if gameover then      ' player quit
     PutString("Send in the HazMat team...")
   else
     PutString("All is well. Chaos has been tamed.")
     pause 2500
     mode 1,8
   endif
   print "Type 'RUN' to play again."
   end
   sub LeftClick
     newclick = 1
     handx = mouse(x,mport-1)
     handy = mouse(y,mport-1)
     if mport then gui cursor handx,handy
   end sub
   sub PeriodInt
     if mport then gui cursor mouse(x,mport-1),mouse(y,mport-1)
   end sub
   ' Draw the pth vial, erasing anything that might be there already
   ' p = [1,nvials]
   sub ShowVial(p)
     local integer x
       blit 36,0,80*p-40,200,66,168,sp
     else
       if not ipsFlag% then
         blit write #9,46*(p-1),100,46,120
       else
         x=90*(p-1)' 10 is spacing between vial tops
         line x+10,ballRad*6,x+ballRad*2+24,ballRad*6,2,clr(cBK)
         line x+14,ballRad*6,x+14,ballRad*13+8,2,clr(cBK)
         line x+18+ballRad*2,ballRad*6,x+18+ballRad*2,ballRad*13+8,2,clr(cBK)
         arc x+16+ballRad,ballRad*13+9,ballRad,ballRad+1,90,270,clr(cBK)
       endif
     endif
   end sub
   ' Draw ball number n at yth level in xth vial (lowest first)
   ' n = [1-7] colour
   ' x = [1-9] vial
   ' y = [0-4] level (0 = above)
   sub DrawBall(n,x,y)
     local xpos,ypos
   '  print "nxy: ",n,x,y
       if y then
         ypos = 397-36*y   ' ball in vial
       else
         ypos = 120        ' ball above vial
       endif
       if n then
         blit 0,ballcols(n-1)*36,80*x-25,ypos,36,36,sp,4 ' coloured ball
       else
         blit 36,216,80*x-25,ypos,36,36,sp,4  ' blank ball
       endif
     else ' F4
       if y then ' ball in vial
           ypos = 238-26*y
         else
           ypos = ballRad*(17-(y*2))+5
         endif
       else        ' ball above vial
           ypos = 48
         else
           ypos=ballRad*3
         endif
       endif
   '    blit write #9,46*(x-1)+9,100,26,26
       xpos=(x-1)*90+16+ballRad
       if n then ' coloured ball
           blit write n,46*(x-1)+9,ypos,26,26
         else
           circle xpos,ypos,ballRad,2,,clr(cBK),clr(n-1)
         endif
       else ' blank ball
           blit write #12,46*(x-1)+9,ypos,26,26
         else
   '        circle xpos,ballRad*(17-(y*2))+5,ballRad,0,,clr(cW),clr(cW)
           circle xpos,ypos,ballRad,0,,clr(cW),clr(cW)
         endif
       endif
     endif
   end sub
   ' Shuffle the ball colours around for variety
   sub ShuffleBCols
     local i, tmp, n
     for i = 0 to 6
       n = int(rnd * 7)
       tmp = ballcols(i)
       ballcols(i) = ballcols(n)
       ballcols(n) = tmp
     next i
   end sub
   ' Show current level
   ' nvials is of interest, as is vials(9,4)
   sub ShowLevel
     local i,j
     box 0,95,MM.HRES,310,0,rgb(white),rgb(white) ' erase vials and "SAFE" message
     for i = 1 to nvials
       ShowVial(i)
       for j = 1 to 4
         DrawBall(vials(i,j),i,j+1)
       next j
     next i
     if xpos > nvials then xpos = nvials
     charx = 100 : chary = 400
     a$="Level " + str$(levelball) + "." + str$(levelnum)
       PutString(a$+"    ")
     else
       text mm.hres/2,40,a$,c,2
     endif
   end sub
   function TestDone()
     local i,j
     TestDone = 0
     for i = 1 to nvials
       for j = 2 to 4
         if vials(i,j) <> vials(i,1) then exit function
       next j
     next i
     TestDone = 1
   end function
   ' return number of ball selected,
   ' return 0 if no ball selected
   function GetBall()
     local k,j,res
     local integer x,x2,y2
       sprite show 1,80*xpos-25,160,1,0  ' arrow up
     else
         blit write #8,46*(xpos-1)+9,72,26,26
       else
         drawArrow(xpos,UPARROW)
   '      x=90*(xpos-1)
   '      x2=x+14+ballRad*2: y2=ballRad*5
   '      box x,y2-radball,85,radball*2,,clr(cW),clr(cW) ' blank the space
   '      triangle x+14+ballRad,ballRad*4,x2,y2,x+14,ballRad*5,clr(cBK),clr(cBK)
   '      box x+7+ballRad,ballRad*5,14,ballRad*.8,,clr(cBK),clr(cBK)
       endif
     endif
     GetBall = 0
     do
       k = asc(ucase$(inkey$))
   '    ? k;" ";
       CheckNewClick(k)
       select case k
         case 130    ' left arrow
           if xpos > 1 then
             AnotherKeyPress
             xpos = xpos - 1
             sprite show 1,80*xpos-25,160,1,0    ' draw up arrow
           endif
     ?"glk";str$(xpos);" ";
         case 131    ' right arrow
           if xpos < nvials then
             AnotherKeyPress
             xpos = xpos + 1
           endif
     ?"grk";str$(xpos);" ";
         case  67    ' "C"   toggle count data on and off
           ToggleCounts
         case  27    ' [ESC]
           if inkey$ = "[" then ' PC keyboard arrow
             ls$=inkey$
             if ls$="C" then ' right arrow
   ' don't count              AnotherKeyPress
                 xpos = xpos + 1
   '              sprite show 1,80*xpos-25,160,1,0    ' draw up arrow
                   blit write #12,46*(xpos-2)+9,72,26,26  ' draw blank
                   blit write #8,46*(xpos-1)+9,72,26,26 ' draw up arrow
                 else
                   DrawBlank(xpos-1)
                 endif
               endif
             elseif ls$="D" then ' left arrow
               if xpos > 1 then
                 xpos = xpos - 1
                   blit write #12,46*(xpos)+9,72,26,26  ' draw blank
                 else
   '                ? "LN458 ": do: a$=inkey$: loop while a$="": ?
                   DrawBlank(xpos+1)
   '                ? "LN461 ": do: a$=inkey$: loop while a$="": ?
                 endif
               endif
             endif
           else
             gameover = 1
             exit do
           endif
         case  32    ' [SPACE] - select top ball from this vial
           AnotherKeyPress
           j = 4
           res = 0
           do
             if vials(xpos,j) > 0 then ' found a ball
               res = xpos
               movingball = vials(xpos,j)    ' actual ball colour
               exit do
             endif
             j = j - 1
           loop until j = 0
           if res then
             vials(xpos,j) = 0   ' clear location
             DrawBall(0,res,j+1)   ' erase ball from vial
             GetBall = res
             exit do
           endif
         case 82     ' "R"   restart
           AnotherKeyPress
           movecount(6) = 0  ' total mouse click this attempt
           ShowCounts
             math scale vialsbak(),1,vials()  ' restore starting configuration
           else
             for li%=0 to 9 ' vials(9,4)
               for lj%=0 to 4
                 vials(li%,lj%)=vialsbak(li%,lj%)
               next lj%
             next li%
           endif
           ShowLevel
           exit do
       end select
     loop
   end function
   ' take top ball from src and put it somewhere
   sub PutBall(src)
     local j,k
       sprite show 1,80*xpos-25,160,1,2  ' arrow down
     else
         blit write #10,46*(xpos-1)+9,72,26,26
       else
         DrawArrow(xpos,DOWNARROW)
   '      x=90*(xpos-1)
   '      ? "box ";x;" ";y2;" ";y2-ballrad
   '      box x,y2-ballRad,80,ballRad*2,,clr(cW),clr(cW) ' blank the space
   '      ' draw down arrow
   '      triangle x+14+ballRad,ballRad*6-1,x2,y2,x+14,ballRad*5,BLK,BLK
   '      box x+7+ballRad,ballRad*4.1,14,ballRad,,BLK,BLK
       endif
     endif
     DrawBall(movingball,src,0)   ' coloured ball above vial
     do
       CheckNewClick(k)
       select case k
           if xpos > 1 then
             AnotherKeyPress
             DrawBall(0,xpos,0)            ' erase coloured ball above vial
             xpos = xpos - 1
             DrawBall(movingball,xpos,0)   ' draw coloured ball above vial
             sprite show 1,80*xpos-25,160,1,2    ' draw down arrow
           endif
             AnotherKeyPress
             DrawBall(0,xpos-1,0)            ' erase coloured ball above vial
             DrawBlank(xPos-2)
             xpos = xpos + 1
           endif
         case  90    ' [Z/z]   'undocumented' undo command - replace wrongly selected ball
           AnotherKeyPress
           DrawBall(0,xpos,0)  ' erase coloured ball above pointer
           for j = 1 to 4
             if vials(src,j) = 0 then     ' find top spot
               vials(src,j) = movingball  ' put the ball back
               DrawBall(movingball,src,j+1) ' re-draw coloured ball in vial
               exit do
             endif
           next j
           ToggleCounts
         case  27    ' [ESC]
             ls$=inkey$
                 DrawBall(0,xpos,0)   ' clear prior coloured ball above vial
                 DrawBlank(xpos)      ' clear prior arrow
                 xpos = xpos + 1
                   blit write #12,46*(xpos-2)+9,46,26,26  ' draw blank over ball
                   blit write #12,46*(xpos-2)+9,72,26,26  ' draw blank over arrow
                   blit write #10,46*(xpos-1)+9,72,26,26 ' draw down arrow
                 else
                 endif
               endif
               if xpos > 1 then
                   xpos = xpos - 1
                   blit write #12,46*(xpos)+9,46,26,26  ' draw blank over ball
                   blit write #12,46*(xpos)+9,72,26,26  ' draw blank over arrow
                 else
                   DrawBall(0,xpos,0)' clear coloured ball above vial
                   xpos = xpos - 1
                 endif
               endif
             endif
           else
             gameover = 1
             exit do
           endif
         case  32    ' [SPACE] - place ball
           else
             else
             endif
           endif
           if vials(xpos,4) = 0 then     ' there is room in this vial
             AnotherKeyPress
             top = 0
             for j = 1 to 4
               if vials(xpos,j) = 0 then   ' found a spot
                 if (top = 0) or (top = movingball) then
                   vials(xpos,j) = movingball    ' move the ball
                   DrawBall(movingball,xpos,j+1) ' draw coloured ball in vial
                   exit do
                 endif
               else
                 top = vials(xpos,j)
               endif
             next j
           endif
           AnotherKeyPress
           ShowCounts
           else ' vials(9,4)
             for li%=0 to 9: for lj%=0 to 4
               vialsbak(li%,lj%)=vials(li%,lj%)
             next lj%: next li%
           endif
           ShowLevel
           exit do
       end select
     loop
     movingball = 0
   end sub
   sub CheckNewClick(k)
     if newclick then
       newclick = 0
       if handy > 208 and handy < 350 then
         select case handx
           case  45 to  85
             PickVial(1,k)
           case 125 to 165
             PickVial(2,k)
           case 205 to 245
             PickVial(3,k)
           case 285 to 325
             PickVial(4,k)
           case 365 to 405
             PickVial(5,k)
           case 445 to 485
             PickVial(6,k)
           case 525 to 565
             PickVial(7,k)
           case 605 to 645
             PickVial(8,k)
           case 685 to 725
             PickVial(9,k)
         end select
       endif
     endif
   end sub
   sub PickVial(n,k)
     local c$
     if nvials >= n then
       DrawBall(0,xpos,0)
       xpos = n
       movecount(1) = movecount(1) - 1  ' undo keypress this game
       movecount(2) = movecount(2) - 1  ' undo keypress this level
       movecount(3) = movecount(3) - 1  ' undo keypress this attempt
       movecount(7) = movecount(7) - 1  ' remove impending spurious keycount increment
       movecount(4) = movecount(4) + 1  ' another mouse click this game
       movecount(5) = movecount(5) + 1  ' another mouse click this level
       movecount(6) = movecount(6) + 1  ' another mouse click this attempt
       movecount(8) = movecount(8) + 1
       k = 32    ' simulate space bar to grab/release ball
     endif
   end sub
   sub AnotherKeyPress
     local c$
     movecount(1) = movecount(1) + 1  ' another keypress this level
     movecount(2) = movecount(2) + 1  ' another keypress this level
     movecount(3) = movecount(3) + 1  ' another keypress this attempt
     movecount(7) = movecount(7) + 1
     ShowCounts
   end sub
   sub ShowCounts
     if countvisible then
       text 165,572," "+str$(movecount(1))+" ","CT",7,1,0,&hFFFFFF
       text 165,562," "+str$(movecount(2))+" ","CT",7,1,0,&hFFFFFF
       text 165,552," "+str$(movecount(3))+" ","CT",7,1,0,&hFFFFFF
       text 165,582," "+str$(movecount(7))+" ","CT",7,1,0,&hFFFFFF
       text 235,572," "+str$(movecount(4))+" ","CT",7,1,0,&hFFFFFF
       text 235,562," "+str$(movecount(5))+" ","CT",7,1,0,&hFFFFFF
       text 235,552," "+str$(movecount(6))+" ","CT",7,1,0,&hFFFFFF
       text 235,582," "+str$(movecount(8))+" ","CT",7,1,0,&hFFFFFF
     end if
   end sub
   sub ToggleCounts
       countvisible = 0
       box 50,530,225,62,1,&hFFFFFF,&hFFFFFF
     else
       countvisible = 1
       text 165,530,"Key","CT",7,1,0,&hFFFFFF
       text 165,540,"Strokes","CT",7,1,0,&hFFFFFF
       text 235,530,"Mouse","CT",7,1,0,&hFFFFFF
       text 235,540,"Clicks","CT",7,1,0,&hFFFFFF
       text 125,550,"This attempt","RT",7,1,0,&hFFFFFF
       text 125,560,"This level","RT",7,1,0,&hFFFFFF
       text 125,570,"This game","RT",7,1,0,&hFFFFFF
       text 125,580,"Total","RT",7,1,0,&hFFFFFF
       box 130,550,141,41,1,0
       line 130,560,270,560,1,0
       line 130,570,270,570,1,0
       line 130,580,270,580,1,0
       line 200,550,200,589,1,0
       ShowCounts
     end if
   end sub
   sub PutChar(c$)
     local cn = asc(c$) - 32
     if cn < 0 then exit sub
     if cn > 95 then exit sub
     blit 102+(cn mod 16)*21,int(cn/16)*30,charx,chary,21,30,sp
     charx = charx + 21
     if charx > MM.HRES then
       charx = 0
       chary = chary + 30
     endif
   end sub
   sub PutString(s$)
     local i
       for i = 1 to len(s$)
         PutChar(mid$(s$,i,1))
       next i
     else ' Armmite F4
       if chary = 10 then ' first line
         i=mm.hres/2 - len(s$)/2*mm.fontwidth
         text i,0,s$,,,,rgb(black),rgb(white)
         if ipsFlag% then: ly%=mm.fontheight+42: else: ly%=mm.fontheight+14: endif
       else
         if ipsFlag% then: font 3: else: font 1: endif
         text 0,ly%,s$,,,,rgb(black),rgb(white)
       endif
     endif
   end sub
   sub ShowSafe
       rbox MM.HRES/2-220, 95,360,100,50,&h00FF21,&h00FF21   ' greenish frame
       rbox MM.HRES/2-210,105,340, 80,40,rgb(white),rgb(white)
       blit 180,180,MM.HRES/2-170,110,260,70,sp
     else
         box 0,44,320,54,,rgb(white),rgb(white)
         blit write #11,130,44,190,48 ' draw SAFE!
       else
         DrawBlank(xpos) ' blank the last arrow
         text mm.hres/2,ballRad*3,"S A F E !",C,5,,rgb(yellow),rgb(green)
       endif
     endif
   end sub
   ' Read another level from the data
   function MixVials()
     local i,j,mix
     local c$
       math set 0,vials()    ' start with empty vials
     else
         for lj%=0 to 4
           vials(li%,lj%)=0
         next lj%
       next li%
     endif
     read nballs
     if nballs = 0 then
       MixVials = 0
       exit function
     endif
     if cputype%=CMM2% then page write 2    ' don't want to see prints on screen
     print levels,   ' will appear on console if attached
     if nballs = levelball then
       levelnum = levelnum + 1
     else
       levelnum = 1
       levelball = nballs
     endif
     m$ = ""
     read nvials
     if nvials = -1 then
       nvials = nballs + 2
       for i = 1 to nballs
         m$ = m$ + string$(4,str$(i))
       next i
       for i = 1 to len(m$)  ' scramble m$
         c$ = mid$(m$,i,1)
         j = int(rnd * len(m$)) + 1
   ' LB      mid$(m$,i,1) = mid$(m$,j,1)
   ' LB      mid$(m$,j,1) = c$
             ls$ = mid$(m$,j,1)
             m$=mid$(m$,1,i-1)+ls$+mid$(m$,i+1)
             m$=mid$(m$,1,j-1)+c$+mid$(m$,j+1)
       next i
       print "random   ";
       for i = len(m$) to 1 step -1
         print mid$(m$,i,1);
       next i
       print
       for i = 1 to nvials   ' fill with data from m$
         for j = 1 to 4
           vials(i,j) = val(left$(m$,1))
           m$ = mid$(m$,2)
         next j
       next i
     else
         read mix
         m$ = m$ + str$(mix)
         for j = 1 to 4
           vials(i,j) = mix mod 10
           mix = mix \ 10
         next j
       next i
       print "built in "; m$
     endif
       math scale vials(),1,vialsbak()  ' save starting configuration
       page write 0
     else
         for lj%=0 to 4
         next lj%
       next li%
     endif
     MixVials = 1
   end function
   sub F4_setup
   static integer h=69,w=65
   local x,y
   '  print "F4_setup"
   backlight 50
   if MM.INFO$(LCDPANEL)<>"IPS_4_16" then
     Load IMAGE "ChemiChaosSprites800.bmp"
     for li%=1 to 12:  On error skip: Blit CLOSE li%: next li%
     Blit READ #8,26,126,26,26 ' up arrow
     Blit READ #9,27,0,46,120 ' test tube
     Blit read #11,130,130,190,48 ' "SAFE!"
     Load IMAGE "DownArrow.bmp"
     Blit Read #10,0,0,26,26 ' down arrow
     CLS RGB(white)
     Blit read #12,0,0,26,26 ' blank sprite
     CLS RGB(white)
   else
     ipsFlag%=1
   ' NEW: but insufficient memory with IPS 800x480 LCD--must draw circles, etc.
   '  Blit READ #1,0,0,65,69: y=y+h: Blit READ #2,0,y,65,69: y=y+h: Blit READ #3,0,y,65,69
   '  y=y+h: Blit READ #4,0,y,65,69: y=y+h: Blit READ #5,0,y,65,69
   '  y=y+h: Blit READ #6,0,y,65,69: y=y+h: Blit READ #7,0,y,65,69
   '  y=y-h: Blit READ #8,w+1,165,69,26 ' up arrow
   '  Blit READ #9,66,0,118,320 ' test tube
   '  Blit read #11,326,347,460,130 ' "SAFE!"
   '  Load IMAGE "DownArrow_IPS.bmp"
   '  Blit Read #10,0,0,w,h ' down arrow
   '  CLS RGB(white)
   '  Blit read #12,0,0,w,h ' blank sprite
   '  CLS RGB(white)
   end sub
   sub DrawArrow(slot,updownFlag) ' updownFlag: 0=down,1=up
     local integer x,x2,y2,y3
         x=90*(slot-1)
         x2=x+14+ballRad*2: y2=ballRad*5: y3=ballRad*4
   '      ? "x,y3,Blank box; <CR> ";x;" ";y3;: do:a$=inkey$:loop while a$="":?
         blit write #13,x,y3,85,66
   '      box x,y3,85,radball*2,,clr(cW),clr(cW) ' blank the space
   '      print "x,x2,y2 <Enter>";x;" ";x2;" ";y2;" ";:
   '        do: a$=inkey$: loop while a$="": ?
         if updownFlag then ' up arrow
           triangle x+14+ballRad,y3,x2,y2,x+14,ballRad*5,clr(cBK),clr(cBK)
         else
          ' draw down arrow
   '        box x+1,y3,85,radball*2,,clr(cW),clr(cW) ' blank the space
   '        blit write #13,x,y3,85,66
         endif
   '      print "<Enter>";: do: a$=inkey$: loop while a$="": ?
   end sub
   sub DrawBlank(slot)
         x=90*(slot-1)
   '      box x,y2-radball,85,radball*4,,clr(cW),clr(cW) ' blank the space
   end sub
   ' data format:
   ' #balls, #vials, ball pattern for each vial
   ' if #vials = -1 then fill (#balls + 2) vials ly
   gamelevels:
   data 1,2,11,11    ' trivial one to get started
   data 2,3,1221,2112,0
   data 2,3,1212,2121,0
   data 2,5,1121,1211,2111,1112,0
   data 3,5,1231,3321,2231,0,0   ' this one can't be done in only 4 vials
   data 3,-1
   data 3,-1
   data 3,-1
   data 3,4,1213,2231,3213,0
   data 3,4,2313,2123,2311,0
   data 3,4,2313,2232,1113,0
   data 3,4,1211,3323,1232,0
   data 3,4,2132,3221,3311,0
   data 3,4,2221,2133,1133,0
   'data 3,4,1233,1212,2133,0
   'data 3,4,1232,3121,1323,0
   data 4,-1
   data 4,-1
   data 4,-1
   data 4,-1
   data 4,5,2321,1412,4412,4333,0
   data 4,5,4232,1231,2443,3114,0
   data 4,5,3124,2121,2444,3331,0
   data 4,5,1224,4232,4311,4133,0
   data 4,5,2141,4333,3242,4121,0
   data 5,-1
   data 5,-1
   data 5,-1
   data 5,-1
   data 5,-1
   data 5,-1
   data 5,6,5154,3321,4222,3415,1534,0
   data 5,6,4131,2422,5412,5313,4553,0
   data 5,6,2154,2543,5414,2251,1333,0
   data 5,6,3214,2453,2431,2135,5541,0
   data 6,-1
   data 6,-1
   data 6,-1
   data 6,-1
   data 6,-1
   data 6,7,1642,5624,4161,3623,5432,5315,0
   data 6,7,6413,5124,3531,4265,6153,6224,0
   data 6,7,6342,5265,2341,4534,6152,6131,0
   data 6,7,2151,5634,6436,6514,3431,2225,0
   data 6,7,1324,4636,5413,6132,5562,5241,0
   data 7,-1
   data 7,-1
   data 7,-1
   data 7,-1
   data 7,-1
   data 7,-1
   data 7,-1
   data 7,8,2127,4665,4231,3776,4335,6151,4572,0
   data 7,8,4311,5562,2346,7773,6245,6124,3751,0
   data 7,8,2715,2136,2761,7634,5744,6552,3431,0
   data 0,0  ' indicate end of data
Edited 2021-04-24 05:34 by lizby
