Local Time 04:25 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Possible Bug in CONTROLLER MOUSE OPEN?
William Leue
Posted: 03:42pm 03 Feb 2021
I ran across this problem today when checking for the existence of a mouse on some I2C port:
sub CheckMouse
 local i, hasMouse
 hasMouse = 0
 for i = 1 to 3
   on error skip 1
   controller mouse open, LeftClick
   if MM.ERRNO = 0 then
     hasMouse = 1
     exit for
 next i
 if hasMouse then
   gui cursor on 1
 end if
end sub
sub LeftClick
'blah blah
end sub
I was surprised to find hasMouse being set to 1, even though there is no mouse and in fact no HobbyTronics interface. I wonder if the absence of the interface is confusing the mouse test, and that I indeed had the HobbyTronics interface but no mouse plugged in, then it would work?
Using version 5.6.00 firmware on a 'vanilla' CMM2.  (BTW this code works perfectly on my CMM2 Deluxe, which does have the HobbyTronics interface.)
-Bill
Posted: 04:49pm 03 Feb 2021
Check the mouse open syntax
William Leue
Posted: 04:59pm 03 Feb 2021
Oops! Actually my test is correct, I just left out the channel when I copied the code over to the forum. Should have said:
sub CheckMouse
local i, hasMouse
hasMouse = 0
for i = 1 to 3
  on error skip 1
  controller mouse open i, LeftClick
    hasMouse = 1
    exit for
next i
if hasMouse then
  gui cursor on 1
end if
end sub
sub LeftClick
'blah blah
end sub
-Bill
Posted: 08:26pm 03 Feb 2021
You are missing an ENDIF
This works (On 5.7Beta)
 CheckMouse
sub CheckMouse
 local i, hasMouse
 hasMouse = 0
 for i = 1 to 3
   on error skip 1
     hasMouse = 1
     exit for
   endif ' this was missing
 next i
 if hasMouse then
   gui cursor on 1
   print i
 end if
end sub
sub LeftClick
 'blah blah
end sub
vegipete
Posted: 07:22am 04 Feb 2021
Because of start-up timing and interrupts and stuff, I would recommend NOT setting an interrupt while searching for a mouse. Instead, use "CONTROLLER MOUSE OPEN i" to find a possible mouse. If one is found, close it again, set up everything else, such as GUI CURSOR ON, and then finally re-open the mouse channel with the desired interrupt routine specified.
Edited 2021-02-04 17:22 by vegipete
William Leue
Posted: 05:30pm 04 Feb 2021
Good idea, thanks!
-Bill
