Forum Index : Microcontroller and PC projects : Check if input data is integer or not (MMX V5.0504)
| AussieWombat Newbie Joined: 04/05/2018 Location: AustraliaPosts: 21 |
Hi all, I have an input statement, that has to be an integer. If I type a word into the input, it accepts it. I was going to use an if then statement to check if it is (NAN), I am using fontwidth: Input "Width of Font? ",fwidth% IF (fwidth% =0) then print "not a number" goto fontwidth endif but if they enter zero, that stuffs that up . Or should I add to the input statement. Input "Width of Font?(1-255) ",fwidth% regards AussieWombat |
Chopperp![]() Guru Joined: 03/01/2018 Location: AustraliaPosts: 1126 |
I did a quick prog. Needs refining fwidth% = 0 Do While fwidth% = 0 Input "Width of string ", fwidth% Print fwidth% Loop Brian ChopperP |
Brian's code is good but three extra points: You use "IF (fwidth% =0) then" without an ENDIF. This is why entering zero causes an error. As an aside, when you are asking for help on this forum it would be worth giving a clear description and listing the full error message rather than just saying "stuffs that up". If the user just hits Enter at the prompt fwidth% will be unchanged. If this is not what you want it would be worth initialising fwidth% to some default value (ie, 0 as in Brian's code). You do not need brackets around conditional tests (ie, (fwidth% =0)) but also they don't hurt. I'm guessing that you come from a C background. Geoff Geoff Graham - http://geoffg.net |
Assuming you don't want anything but digits i.e. no decimals... fontwidth: Do Input "Width of Font? ",a$ While Len(a$)<1 For n=1 to len(a$) if instr(" 0123456789",Mid(a$,n,1)<2 then print "not a number" goto fontwidth endif next fwidth%=val(a$) I always like to grab data as strings and then process into whatever form I need. Minimises errors because of data mis-matches and you maintain control of everything in the string. As an aside, I avoid Input - you drop into the guts of MMBasic while it is waiting for the enter key which is "blocking" i.e. it stops your code running (interrupts, timers etc) One of my pet likes is to convert VB functions into MMBasic. I never did IsNumeric() as I never really saw much call for it, but now... With it, you could simply have: fontwidth: Input "Width of Font? ",a$ If IsNumeric(a$) Then fwidth%=val(a$) Else print "not a number" goto fontwidth EndIf Any IsNumeric() function would be pretty much the same as the first bit of code above, but with some sanity checking and switches to allow decimals (one) etc. Happy to do it for you and add it to the library if you would like that. You might also like to look at this Constrain() function Edited 2021-02-08 00:32 by CaptainBoing |
| Schlowski Newbie Joined: 26/03/2014 Location: GermanyPosts: 29 |
Isn't jumping with GOTO out of a FOR-NEXT loop without proper ending the loop critical? I would assume that this leaves some sort of unresolved FOR-information on some sort of stack or so... |
It is bad form, yes I agree and GoTo is seen as structured programming's arch-enemy. I wanted to make the code as "look-a-like" to the original so as not to stray too much and take away from the original query - hence following up with an example using a nice function - structure restored. Regardless, MMBasic (at least on MM2 so I suspect all other platforms are the same as the core language hasn't been changed) is quite happy. True some languages use the stack for loops and this would as you suspect blow up memory, but not MMBasic (same with Do/Loop and Select/End Select). Internally they seem to act almost as if they are "aliases" for If/GoTo pairs, mimicking what CPUs do in the binary with test and Jump. Try this bit of code below, just runs happily forever Fred: For n=1 To 1000 GoTo Fred Next Edited 2021-02-08 01:23 by CaptainBoing |
For this problem, I prefer to use INKEY$ and prevent non-numeric characters from getting entered. This is written for the CMM2 but shouldn't need much change for any MMBasic platform. ' text input routines ' option console serial ' to stop messing up the display CONST FALSE = 0 CONST TRUE = NOT false 'dim n$(10) 'dim config$(10,3) DIM INTEGER tHt = MM.INFO(FONTHEIGHT), tWth = MM.INFO(FONTWIDTH) DIM FLOAT num 'dim integer k CLS num = GetNum(10,10,"42") PRINT num ' Gets valid numeric input from user ' Parameters: ' Row, Col - location to echo input ' Initial$ - default value FUNCTION GetNum(Col AS INTEGER, Row AS INTEGER,initial$) LOCAL result$, Kbd$ LOCAL INTEGER Done Result$ = initial$ Done = FALSE DO WHILE INKEY$ <> "": LOOP 'Clear keyboard buffer DO WHILE NOT Done TEXT col*tWth,Row*tHt,Result$+CHR$(95)+ " ",lt,1,1 DO Kbd$ = INKEY$ LOOP UNTIL Kbd$ <> "" SELECT CASE Kbd$ CASE CHR$(27) result$ = initial$ done = true CASE "0","1","2","3","4","5","6","7","8", "9" Result$ = Result$ + Kbd$ CASE "." IF INSTR(Result$, ".") = 0 THEN Result$ = Result$ + Kbd$ ELSE PLAY TONE 440,440,100 END IF CASE CHR$(13),CHR$(9) Done = TRUE CASE CHR$(8) IF LEN(Result$) > 0 THEN Result$ = LEFT$(Result$, LEN(Result$) - 1) END IF CASE ELSE IF LEN(Kbd$) > 0 THEN PLAY TONE 440,440,100 END IF END SELECT LOOP TEXT col*tWth,Row*tHt,Result$+ " ",lt,1,1 GetNum = VAL(Result$) END FUNCTION END Jim VK7JH MMedit |
Thanks all for the replies, I was just going through some old programs I had written for the Maximite and CMM1, and trying to get them to work in the MMX V5.0504 They will probably never see the light of day, but I thought it would be a good exercise. I like the approach of TassyJim, and use the inkey$, as then interupts would not be hindered. It was for an old font creation program, but now we can all use TassyJims FontTweak program to create fonts. Aussiewombat |
