Forum Index : Microcontroller and PC projects : CMM2: Mode 8,12 and Right Edge
MMBasic Version 5.07.00b2 With the above firmware, I notice a problem trying to draw on the very right edge of the screen in mode 8,12 mode 8,12 cls box 0,0,320,200 do:loop The right side of the box doesn't appear. Works fine in mode 3,8 Likewise, nothing appears with "line 319,0,319,199". And no, it is not the monitor. (I'm not sure where to report bugs right now...) Visit Vegipete's *Mite Library for cool programs. |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6606 |
I assume you mean MODE 3,12 not 8,12 I agree that the right hand column appears to be missing in mode 3,12 but visible in mode 3,8 and 3,16 mode 3,12 cls line 318,0,318,199,1,rgb(green) line 319,0,319,199,1,rgb(red) 'box 0,0,319,199 do:loop Jim VK7JH MMedit |
Whoops, yes, mode 3,12. Visit Vegipete's *Mite Library for cool programs. |
Thanks for the report - will have a look UPDATE Fixed in b12 Edited 2021-02-09 02:19 by matherp |
| Pilot352 Newbie Joined: 12/08/2020 Location: United StatesPosts: 34 |
If the right side is drawn, wouldn't that mean the width of the screen is 201 pixels? You are starting at 0. Range should be 0-199 not 0-200. Or am I wrong? |
Yes BOX x,y,w,h LINE x1,y1,x2,y2 |
