Forum Index : Microcontroller and PC projects : LINUX: Upgrade from ext2 to ext4....
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10038 |
Hi all. ![]() Is there any way to convert an ext2 volume to ext4 WITHOUT wiping the drive? I have four HDD's that were setup originally in NASlite2 that used ext2. I now use Puppy Linux for pretty much all my SAMBA servers, and choose ext4 by default when setting up a new NAS. The old ext2 drives from the NASlite2 setup work just fine inside of Puppy Linux, but I would prefer to change the filesystem to ext4 now, as ext2 is getting on a bit, and has those nightmarish fsck checks that take HOURS to complete, whereas ext4 does not. If this is simply not possible without reformatting and rebuilding, fine. But I know that Linux has many tricks up its OS sleeve for all sorts of things, and I am kinda hoping that a non-destructive FS upgrade is something you can do. ![]() Smoke makes things work. When the smoke gets out, it stops! |
| LeoNicolas Guru Joined: 07/10/2020 Location: CanadaPosts: 625 |
Yes, there is a way to do it. Please backup all your data before starting the process. https://wiki.archlinux.org/index.php/ext4#Migrating_from_ext2/ext3_to_ext4 |
| HellbentHorse Regular Member Joined: 08/07/2020 Location: AustraliaPosts: 55 |
You can do this, you just can't convert it while the drive is mounted. This is a pretty good guide. https://www.howtoforge.com/tutorial/migrate-ext2-ext3-filesystem-to-ext4/ |
Lovely, thanks chums - I will read those links. ![]() Smoke makes things work. When the smoke gets out, it stops! |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6104 |
If you back up all your data, please do the backup on an EXT4 drive. That solves your problem. Volhout PicomiteVGA PETSCII ROBOTS |
| SimpleSafeName Guru Joined: 28/07/2019 Location: United StatesPosts: 351 |
Exactly what I was thinking. :) I still have some drives that pre-date ReiserFS holding all of my important stuff. You know, like my Netscape email from the 90's. On my Iomega Zip drive... |
