Local Time 17:11 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Is there a memory map ?
Posted: 10:49pm 15 Mar 2021
... there doesn't seem to be one in the manual.
Given that poke-ing in the wrong place is liable to cause the CMM2 to hang I'd like to put some protection in SPForth so that it can't perform store operations to such addresses.
Posted: 07:39am 16 Mar 2021
Look at a .map file / linker script / read the ST doc?
(I'd expect anything in a manual to be along the lines of "reserved for use by MMBasic" or "may change in future releases".)
Posted: 09:49am 16 Mar 2021
Thanks for the well deserved RTFM John
I'll be honest I'm lazy and if there is a possiblity that someone will point me to the correct FM and the appropriate page then I will almost always ask first.
Also I'm a desktop application developer and I struggle to read the data sheet for a 4000 series CMOS chip so the ST documentation is probably not a great place for me to start. Probably best if I just poke around in the CMM2 firmware as I believe I have seen it display some sort of POKE protection.
epsilon
Posted: 10:10am 16 Mar 2021
In memedit (which is really just a peek/poke frontend) I defined the following ranges:
'--> Mapped address ranges: Can be referenced in goto command.
CONST SRAM% = &H38000000
CONST SRAM_END% = &H38010000 - 256
CONST RAM1% = &H30000000
CONST RAM1_END% = &H30040000 - 256
CONST RAM2% = &H40000000
CONST RAM2_END% = &H59000000
CONST AXI_RAM% =     &H24000000
CONST AXI_RAM_END% = &H24080000
CONST ROM1% = &H08000000
CONST ROM1_END% = &H08200000
CONST ROM2% = &H10000000
CONST ROM2_END% = &H20000000
Epsilon CMM2 projects
Posted: 02:10pm 16 Mar 2021
Thanks @epsilon, that looks like the information I need.
where did you get these from ?
and would you briefly expand on what each range is for ?
epsilon
Posted: 03:06pm 16 Mar 2021
The bulk of it came from our resident oracle Peter Maher of course:
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=12887#156351
The stm32h743ii datasheet has a great block diagram. Docs can be found here:
https://www.st.com/en/microcontrollers-microprocessors/stm32h743ii.html#
Also very helpful is a copy of the CMM2 FW source code. The comments in there combined with the datasheet block diagram give good info about the different memory regions.
Now I'm a bit confused about whether I'm allowed to post here info that I learned directly from the FW source code, so I guess I shouldn't until someone can clear that up for me.
The FW source code has comments describing the meaning of the different memory regions.
Posted: 03:39pm 16 Mar 2021
Thanks for the links @epsilon and "no worries" regarding the FW as I have access to the source code. Now I have some hints on where to look I will do so for myself.
Posted: 01:55am 17 Mar 2021
  epsilon said  Now I'm a bit confused about whether I'm allowed to post here info that I learned directly from the FW source code, so I guess I shouldn't until someone can clear that up for me.
Please feel free to post.
We (or more properly I) don't want the whole source code openly published because in the past that encouraged forks and alternate versions which caused confusion and trouble for the user base.  But excerpts (or any other info) is fine.
epsilon
Posted: 08:54am 17 Mar 2021
  Geoffg said  We (or more properly I) don't want the whole source code openly published because in the past that encouraged forks and alternate versions which caused confusion and trouble for the user base.  But excerpts (or any other info) is fine.
Thank you for clearing that up, Geoff.
So, in that case, this is the info I was referring to:
#define D1_AXISRAM_BASE           (0x24000000UL) /*!< Base address of : (up to 512KB) system data RAM accessible over over AXI                */
AXI-SRAM is embedded SRAM
#define PERIPH_BASE               (0x40000000UL) /*!< Base address of : AHB/APB Peripherals
This is memory-mapped peripheral space
#define D2_AHBSRAM_BASE           (0x30000000UL) /*!< Base address of : (up to 288KB) system data RAM accessible over over AXI->AHB Bridge    */
#define D3_SRAM_BASE              (0x38000000UL) /*!< Base address of : Backup SRAM(64 KB) over AXI->AHB Bridge
More SRAMs in other 'domains' of the chip. Domains are power management domains, i.e. areas that can be powered-up / down / put in standby separate from the other domains in the chip.
#define D1_AXIFLASH_BASE          (0x08000000UL) /*!< Base address of : (up to 2 MB) embedded FLASH memory accessible over AXI
#define D2_AXISRAM_BASE           (0x10000000UL) /*!< Base address of : (up to 288KB) system data RAM accessible over over AXI
AXI, AHB and APB are the different buses used internally by ARM. AXI is the main bus, AHB is a bit more limited/older, and APB is for peripherals.
Now that I'm looking at it, I noticed that two important ranges are missing:
* 0xd0000000-0xd2000000: SDRAM: External memory, accessed through the FMC memory contoller
* 0x38800000-0x38801000: Backup-SRAM. Backup SRAM retains data in low power mode
Note that there are more RAMs, e.g. ITCM and DTCM, Tightly Coupled Memories with very low-latency access, but those are not made accessible to MMBasic. The FW reserves this memory for itself, for performance-critical work.
Posted: 12:13pm 18 Mar 2021
  epsilon said  So, in that case, this is the info I was referring to:
Thanks @epsilon, I still don't know what most of that means but hopefully I will in time.
