Local Time 17:12 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Is it possible for MM.ver to give full details
Andrew_G
Posted: 09:16pm 20 Mar 2021
Hi all,
In the recent discussion about the F4 Backlight function I found that I was having to re-flash updates just to make sure I really was on the version I thought I was because:
  ? MM.VER only gives "5.07"
Is it possible to get the full description, eg:
  "ARMmite MMBasic Version 5.07.00b8"
(On the F4, on my PC, the startup banner disappears before I have time to connect MMEdit to view it - initiating the startup banner without resetting the F4 might be another solution)
Cheers,
Andrew
CircuitGizmos
Posted: 05:46pm 21 Mar 2021
Suggestion:
Leave MM.VER as is.
Implement MM.something that would provide startup banner info.
RetroJoe
Posted: 06:26pm 21 Mar 2021
"MM.PLATFORM" or similar.
Enjoy Every Sandwich / Joe P.
MauroXavier
Posted: 06:55pm 21 Mar 2021
Try this:
PRINT MM.DEVICE$ + " - Version " + STR$(MM.INFO(VERSION))
Andrew_G
Posted: 09:20pm 21 Mar 2021
Thanks guys, all good suggestions.
I'll add "MM.BANNER" - but only as a suggestion.
Cheers,
Andrew
Posted: 09:43pm 21 Mar 2021
  Andrew_G said  Thanks guys, all good suggestions.
Cheers,
Andrew
The majority of 'mites are able to do a reset without having the USB also reset. This makes MM.BANNER of limited benefit.
What happens if you use TeraTerm instead of MMEdit?
I am interested in trying to work out why your system clears the serial buffer on connection while my MMEdit on Windows 10 leaves the buffer (with banner) intact.
Andrew_G
Posted: 11:41pm 21 Mar 2021
Hi Jim, and thanks,
The question was more of a suggestion - that showing the banner without resetting the device might be useful - but maybe not?
Yes TeraTerm shows the full banner (I prefer MMEdit).
But so does MMEdit sometimes. I was getting caught out if I had to Clear the connection, then Select the COM port and then connect to the MM.
If I close the chat window first, then reset the mite, I can then Connect to the MM (without Clearing, or Selecting the COM port) as soon as the PC blings - and the full banner is there.
(I suspect it was the time taken to clear, select and connect that was the problem).
Does that make sense?
Andrew
Posted: 01:40am 22 Mar 2021
Yes, that makes sense.
If you forget to close the terminal window (and therefore the com port), Windows has a tissy fit when the com port gets removed/reinserted.
You may have to close MMEdit fully to make Windows happy again.
In MMEdit, if you don't change the com port settings, just close it before power cycling the 'mite, the com port buffer should be intact.
Andrew_G
Posted: 02:00am 22 Mar 2021
Thanks Jim.
Andrew
