Forum Index : Microcontroller and PC projects : Minor issue with MMEdit
Page 2 of 2 | |||||
robert.rozee Guru Joined: 31/12/2012 Location: New ZealandPosts: 2292 |
try the below, note the extra SINGLE quote marks: QUIT this (single quotes around just 'DOS Basic') should also work: QUIT cheers, rob :-) |
Turbo46 Guru Joined: 24/12/2017 Location: AustraliaPosts: 1594 |
Thanks Rob, that may well work, although I don't know how. But I've moved on and removed the space in the path, put a copy of MMBasic.exe in the same folder as the BASIC files. My system command now is: QUIT Having done that, I think it was working without the long path to asssa.bas anyway. Probably because it was in the same folder from which the system command was issued. Bill Keep safe. Live long and prosper. |
Hi Jim, In MMEdit 4, I was researching the #INCLUDE function and, while looking in the HELP file under 'Using MMEdit', I found a small typo. In the line near the bottom starting with: I think you may have mis-spelled 'Shift'. Bill Keep safe. Live long and prosper. |
TassyJim Guru Joined: 07/08/2011 Location: AustraliaPosts: 5915 |
I think you may have mis-spelled 'Shift'. Bill I am surprised that the spell checker didn't find that! VK7JH MMedit MMBasic Help |
Jim, Not really an MMEdit problem but I was searching for 'Clipclean', but couldn't remember its name and couldn't find it on my PC. Finally found it on the 'Forum upgrade' post, and then armed with the name, I found it on my PC. I for one have found it useful and I was thinking it would be easier to find if it was on your website. Bill Keep safe. Live long and prosper. |
Not really an MMEdit problem but I was searching for 'Clipclean', but couldn't remember its name and couldn't find it on my PC. Finally found it on the 'Forum upgrade' post, and then armed with the name, I found it on my PC. I for one have found it useful and I was thinking it would be easier to find if it was on your website. Bill Will do. Glad you find it useful Jim VK7JH MMedit MMBasic Help |
Thank Jim, I do, because sometimes I type a post in the word processor before copying into TBS. I hope you fixed that typo too. When first read it I had just come in from cleaning up after my dog and the mental image was not good. Bill Keep safe. Live long and prosper. |
Page 2 of 2 |
