Local Time 03:27 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help on Play Sound - Variable Question - String ?
TweakerRay
Posted: 02:58pm 14 May 2021
Hi! I was just working on some Soundprogramm and wondered
is it possible to put a variblename like SOUND$
in the command :
play sound
for example:
Play Sound 1,B,Sound$,frq,vol
Because When I try to do this it does not work...
only if there are hard written Variables like Q for squarewave
N for noise or S for Sine...
I was wondering if I can use a varible for the type of sound ?
The varible for frequencie frq does work and also vol is no problem , but the type of sound can't be changed with a string like I tried...
Any help from you cool smart programmers ? thanks in advance...
http://tweakerray.bandcamp.com
Posted: 03:20pm 14 May 2021
I suspect not, you would need a wrapper subroutine something like the following (untested):
Sub play_sound(sound_no%, channel_no%, type$, frequency%, volume%)
 If volume% = 0 Then volume% = 25
 Select Case UCase$(type$)
   Case "N" : Play Sound sound_no%, channel_no%, N, frequency%, volume%
   Case "O" : Play Sound sound_no%, channel_no%, O, frequency%, volume%
   Case "P" : Play Sound sound_no%, channel_no%, P, frequency%, volume%
   Case "Q" : Play Sound sound_no%, channel_no%, Q, frequency%, volume%
   Case "S" : Play Sound sound_no%, channel_no%, S, frequency%, volume%
   Case "T" : Play Sound sound_no%, channel_no%, T, frequency%, volume%
   Case "W" : Play Sound sound_no%, channel_no%, W, frequency%, volume%
   Case Else : Error "Unknown sound type"
 End Select
End Sub
vegipete
Posted: 03:48pm 14 May 2021
Mauro solved this in his Hope Robot Programming Contest entry:
EXECUTE "PLAY SOUND "+STR$(C)+",B,"+P$+","+STR$(F)+","+STR$(V)
Posted: 04:13pm 14 May 2021
  vegipete said  Mauro solved this in his Hope Robot Programming Contest entry:
That's neat, wonder what the performance comparison is like, though it probably doesn't matter.
TweakerRay
Posted: 04:42pm 14 May 2021
Thanks a lot guys. Thats exactly what I was looking for ! Thank you very much !
Cheers TweakerRay
vegipete
Posted: 06:23pm 14 May 2021
PS to Tom
This is exactly why I shuddered a while back when you voiced your support for _named_ parameters for commands, instead of numeric ones. A name is certainly easier to remember, but as a result, contortions are needed to use variables.
Posted: 06:47pm 14 May 2021
  vegipete said  PS to Tom
This is exactly why I shuddered a while back ...
That's a very compelling argument although I have no recollection of what you are talking about .
Edited 2021-05-15 04:58 by thwill
